Old 10-07-08, 03:09 PM   #1
Barbarosa's Avatar
Location: colorado front range north Lat: 40:23:57N (40.3992) Lon: 105:04:18W (-105.0718)
so i get this sound when i accelerate
1994 type 80, stock other then 285's. 177k miles. had driver side birf repacked when seal went this time last year. right now my passenger side birf needs to be opened and new bearing put in and greased up.
i was under it this weekend greasing the drive line points. when i manually turn a wheel the other front wheel lags behind in rotation then there is a light clunk as things engage.
truck has factory lockers
i will order a new bearing for the birf and open it up soon to repack and so on, it will MY first time at it, guess i should get a brass hammer huh?
question.
what else should i look for
should i just replace bearing anyway ?
what other parts should i have on hand before i start
the clunk occurs if i accelerate like a taxi driver instead of smooth and steady
what else can i check to figure out where that noise is and if somthing needs grease, needs tightening or needs replace.
i have only wheeled it hard twice so far (with 2 big dogs, 3 kids and 2 adults and camping gear) and usually ride my bikes not the truck so it does sit for week or two in row with out going anywear...
thanks for thoughts
JustinColorado aka RedBeard
1994 Yoda Type 80, lockers, 285 silent armour, ... Newguy
Purpose: Expeditions In Rockies, transoport for dog n kids and or when too icy for motorcycle
(1985 K100RS BMW <for sale) - 1999 R1100S -
1988 R100 - 1974 G4TR Trail Boss 100 Kawasaki ringadingdoo
Barbarosa is offline   Reply With Quote
Old 10-07-08, 03:16 PM   #2
Incredibly random
Rix86's Avatar
Wear on side gears/splines, inner axle splines, outer axle splines drive plates, birfields, etc.
Kinda hard to say a whole lot over the internet.
Rix86 is offline   Reply With Quote
Old 10-07-08, 03:32 PM   #3
Barbarosa's Avatar
well that does suggest ... birfield party?
anyone live near Loveland/FortCollins colorado want to do a couple trucks at same time? beer brats and grease guns?
Old 10-07-08, 09:03 PM   #4
stayalert's Avatar
I reccomend you review landtanks thread(s) on front end assessment in the 80 series FAQ.
Cheers!
stayalert is offline   Reply With Quote
Old 10-07-08, 09:34 PM   #5
I don't wheel
hj60's Avatar
TLCA# 11004
A lag between the wheels is to be expected. If you're concerned, drop the front driveshaft at the diff and rotate the flange both ways. See how many degrees it takes to get contact in each direction, but without turning the wheels. This is a rough approximation of gear lash. If it's more than a degree or 2, you might have reason to pull the 3rd and check for excessive wear. But I doubt it. Unless you ran the diff out of oil or have more than 500k miles on it.
Now if it goes 1/8 turn or more, you're definately into the diff for something.
Now, back to the issue at hand. Search for landtank's (or was it beowolf's?) writeup on front end diagnosis. It's very thorough and will lead you in the correct direction.
Jonathan M. Rundlett <skadalajara@gmail.com>
Copper State Cruisers #001
Member of the Happy Hour Gang and the last true conservative in the U.S.
'94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper
Originally Posted by NLXTACY View Post
Others here can explain that a whole lot better than me but IIRC it had to do with the Vicious Coupler.
hj60 is offline   Reply With Quote
Old 10-08-08, 11:27 AM   #6
Barbarosa's Avatar
thanks chaps, will try those key words in the FAQ ...
so no one in the Northern Colorado area want to do a birf-day beer and brats?
Old 10-08-08, 11:54 AM   #7
Barbarosa's Avatar
i must be drinking retarded coffee today, can't find jackalope scat, did the FAQ go away after the DB crash on this thing or what? ... could someone be so kind as to share a link to landtank's faq write up on front end?
i did this time around searching find some threads from 2004 about similar sounds while accelerating from hard stop... seems to be common. mentioned were lube drive axel splines, tighten from to body bolts, and the like...
Old 10-08-08, 12:22 PM   #8
Barbarosa's Avatar
landtanks write up http://forum.ih8mud.com/80-series-te...ation-faq.html
Old 10-08-08, 08:22 PM   #9
Have you checked your front U-Joint? I just unexpectedly bought an 80 while the wife, kids and I were 600 miles from home and was getting MAJOR noise while turning and serious washboard vibrations. At first I thought it was the spindle bushings so I redid those in a Hampton Inn parking lot over a half day but the noise stayed after even after driving a bit to see if it would fix it. So then, in a Target parking lot I jacked up the front end and saw that the U-Joint had major movement. Not having a vise or a press, I pulled the front shaft and the vibrations and noise disappeared.
46/71 Hybrid is offline   Reply With Quote
Home Loan | Debt | Best Credit Cards | Computer Support | Mortgages
