Old 09-30-08, 04:39 PM   #1
spartan's Avatar
Oil leak mystery question....
So I've been through all the old threads and can't find anything that points to my " leak ".
There's oil all around and about the lower rear main seal and caking on the front sway bar; but no leaks on the driveway. Not a drop.
I've removed the inspection plate and there's no oil on the flex plate of the torque converter. No leaks from the oil pan. There's oil and gunk all over the inspection plate and that genereal area.
I don't get it. Any thoughts appreciated.
1997 40th, One Owner, Front 850 OME + 30MM Poly Spacers / Rear 860 OME, Castor Correction, Bilsteins, ARB, 9000# Superwinch, Hella 1000's / 500's, Landtank seat rail extensions, Husky Liners F-R, 285 Revo's.
spartan is offline   Reply With Quote
Old 09-30-08, 04:56 PM   #2
Ebag333's Avatar
TLCA# 18864
Looks like you already know your culprit.
I wouldn't bother with it. Unless it's leaking (and more than a few drops) onto your driveway, it's usually not worth fixing.
'97 LX450 - The -mobile
'96 LX450 - Mine!
Triple locked, 315 General Grabber AT2, OME Medium, 1" body lift, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A wholely owned subsiderary of OR/CA TACO)
Forums
Ebag333 is offline   Reply With Quote
Old 09-30-08, 05:37 PM   #3
I don't wheel
hj60's Avatar
TLCA# 11004
There are 5 states of fluid passing a seal or gasket.
1) Dry. Nothing is passing. This is ideal.
2) Seeping. Very little fluid or grime is noticable. The metal around it just has a moist look to it. This is normal for high mileage/age.
3) Weeping. Some fluid or grime is visible near the seal/gasket, but nothing is left on the ground. (This sounds like your description.) This just needs to be watched to make sure it doesn't worsen.
4) Leaking. There are a few drops to a small puddle on the driveway when you're parked for a couple of hours or more. You should schedule a time to repair this at your earliest convenience.
5) Failure. Any fluid you put into the system make its way onto the ground. The seal/gasket can no longer hold fluid. This can be catastrophic and should be repaired immediately.
I hope this helps someone not worry needlessly about a little fluid around a seal/gasket.
Jonathan M. Rundlett <skadalajara@gmail.com>
Copper State Cruisers #001
Member of the Happy Hour Gang and the last true conservative in the U.S.
'94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper
Originally Posted by NLXTACY View Post
Others here can explain that a whole lot better than me but IIRC it had to do with the Vicious Coupler.
hj60 is offline   Reply With Quote
Old 09-30-08, 05:40 PM   #4
rmcmanus8a's Avatar
TLCA# 18920
Same leak, replaced rear main seal, 10k later leak is back.
After a good off-road trip it dries up for awhile.
Not worried about it.
97FZJ80, Locked, OME, ARB Bull bar
rmcmanus8a is online now   Reply With Quote
Old 09-30-08, 08:36 PM   #5
Double check the Distributor O-Ring and the front Oil pump cover. I know I have an oil leak from the front oil pump cover and it gets on the sway bar....
2007 Tundra Limited CrewMax - 4WD, 5.7L Aluminum V8, 6 spd Auto, 2.5" Revtek lift, Factory 20's (Wheels & Tire for sale),
1994 FZJ80L with Lockers, HIR Headlights., George's LEDs, Pioneer spkrs, Slee Headlight Harness, HG replaced 198K, Aatlas Two tone Grey leather seat covers, MetalTech Sliders with LineX......more to come!
slamd58 is offline   Reply With Quote
Old 10-01-08, 09:55 AM   #6
spartan's Avatar
Thanks all. I replaced the oil pump gasket some time back. No leak there. Very slight leak at distributor o-ring - basically next to nothing.
As for the point of the question, HJ60 pretty much sums it all up and very well. Until it starts dripping on the driveway, I'm not messin' with it. Been like this for at least three years. No worse. No better.
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/243309-oil-leak-mystery-question.html
Posted By For Type Date
WASALive ! Oil - IH8MUD? Forums This thread Refback 10-05-08 07:29 PM
Secured Loans | Car Credit | Secured Loans | Free phpBB forum | Personal Loans
