Old 09-29-08, 06:42 PM   #1
PKP80's Avatar
TLCA# 14900
Live Help need hub bolt info
Not by a cruiser and require info on the six bolts/nuts on the front axle hub of the 80 (6 w/the cone washers. I believe the bolt size is 12mm and need to know if they are fine thread or not. I'm specifically looking to get a die to redo the first threads on one of the bolts (used the wrong hammer to remove the cone washers) and have unexpectedly found myself at a shop that has metric dies. Thanks in advance.
Sam
Sam Shaya
96' FZJ80 convertable
4x4 Labs Rear end, Bengels Offroad front bumper, roll cage, etc.
other goodies, but you get the idea.
Call Sign KI6KNB
"Team Pull-OUT"
Phi Kappa Psi
PKP80 is offline   Reply With Quote
Old 09-29-08, 06:59 PM   #2
I believe they are 8mm x 1.25
Just did mine last weekend. I had to tap out two of the holes.
94 FZJ80, Factory Lockers.
CDL Switch | pin 7 mod | OME 850/863 | Kaymar w/ Duals | BFG MT 255/85R16 | 150A Alternator | Odyssey PC1700MJT | Yaesu FT-8800R Ham w/ Comet SBB1
K6EPS
Need a left side swingout for a Kaymar rear bumper - Any condition
sdnative is offline   Reply With Quote
Free Ringtone | Industrial Directory | Problem Mortgage | plus-size-clothing-istore.com | Car Loan
