Old 09-24-08, 10:31 PM   #1
Cynical Optimist
fj80toyman's Avatar
TLCA# 15140
1FZ Engine Teardown w/pics
We finally got around to taking apart the 1FZ engine that came out of the '94 with 200+K miles on it. The engine was making the constant knock-knock noise, originally diagnosed as a bad piston pin, especially audible at idle and at acceleration was painfully clear.
Engine was swapped and the car is back on the road, the engine sat on the stand glaring at me. My son finally got the time and energy to disassemble it and what we found I thought was worth posting up if for nothing other than reference. Some intersting stuff.
At first, the head came off, it sure is a lot easier to pull the head when the engine's on a stand
Then we got to the business end of the noise.
Pic 1 is the culprit, no.1 piston on the left, marred and scratched, noise seems like piston slap. All of the other pistons looked like the one on the right.
Pic 2 is the bores, No.1 on the right. You can still see very nice cross-hatch in the bores, it hurts just to look at no.1. The scratches werent' too deep, I haven't had this 'mic'd to see how bad it went into the cylinder, I'm not sure if we're going to rebuild, but if we do it would probably need boring out w/new pistons. There's absolutely no ring-ridge in any of the holes.
Pic 3 is the main bearing caps, right to left is 2 through 6. Initially I thought they were in pretty good shape but on close inspection you can see a fair amount of contamination in the bearing material. The main journals are in very good shape, it's a good thing the bearing material is softer than the journals.
Pic 4 is one of the rod bearings. All of them look similar to this. Same as the mains, the rods have some noticeable contamination but overall not bad at all for 200+k miles on them.
Pic 5 and 6 are of the cam caps. Nothing special here, pretty good shape really. The head was completely gone through just before the lower end started making noise.
Pic 7 is the timing chain tensioner side. Again, not bad for 200+k miles but I would replace it for sure on a rebuild.
Pic 8 is where I am right now, deciding what to do with an engine I don't have a car for. Rebuild and keep around or what? No idea, anybody need a good rebuildable 1FZ from a '94?
Cheers, Dan.
I'm Dan and I approve this message. (KG6AJV)
1995 FZJ80 Expedition rigged, blown, OME's, L/R 44gal spare tank, other stuff
1974 FJ40, F, 4MT, 33" BFG's, HFS 4" - 1994 Pickup, 3" body lift, otherwise stock
fj80toyman is offline   Reply With Quote
Old 09-24-08, 10:35 PM   #2
Parts Shaman (per Romer)
cruiserdan's Avatar
TLCA# 11332
Depending on the condition of the #1 cylinder wall it may be possible to hone it and replace one piston.
The select-fit original assembly of the 1FZ makes for an engine with an extremely long life span. Except for the head gasket...
Old 09-24-08, 10:45 PM   #3
mall crawler
LockedLX's Avatar
TLCA# 8675309
Originally Posted by fj80toyman View Post
You can still see very nice cross-hatch in the bores, There's absolutely no ring-ridge in any of the holes.
That is impressive for over 200K miles. What's the deal with the coolant passages around 1 and 2? Thanks for the pics/info!
Pardon my ignorance, but what does this mean? Blueprinted from the factory?
'97 LX450 - 129k, the wanderer
'95 Volvo 854 Turbo - 262k, highway star
'87 Mustang 5.0 Coupe - 96k, stocker, for sale!
Originally Posted by SUMOTOY View Post
I just mathed boost is *exactly* the same as gearing Ken!
LockedLX is offline   Reply With Quote
Old 09-24-08, 10:53 PM   #4
cruiserdan's Avatar
TLCA# 11332
In essence, yes.
Each crankshaft journal, connecting rod journal and cylinder bore are select-fit pieces.
All the main and rod bearings are fitted according to the diameters of the crankshaft pins and the block journals and the connecting rods. The pistons are also fitted to the individual bores.
Old 09-24-08, 11:01 PM   #5
mall crawler
LockedLX's Avatar
TLCA# 8675309
That is awesome.. thanks!
Old 09-24-08, 11:01 PM   #6
when in doubt tube it out
RLMS's Avatar
TLCA# 18347
you know whats funny? A small block chevy, with a full rebuild including line boring, balancing ect... with one race season will look like that.....200,000 miles in that good if shape, how can you go wrong? Toyotas kick a**
justin
www.RedLineLandcruisers.com
NEW WEB SITE CHECK IT OUT
RLMS is offline   Reply With Quote
Old 09-24-08, 11:31 PM   #7
Cynical Optimist
fj80toyman's Avatar
TLCA# 15140
If I decide to rebuild, in other words if I can find a decent '93 or '94 with a bad engine, I will take a good look to see if that's do-able, like I mentioned, haven't take a mic to it yet, but you may be on to something.
...about that head gasket? Dr. T's gotta sell some parts.
Dan.
Old 09-25-08, 12:01 AM   #8
beno's Avatar
TLCA# 14607
Great pics and detail Dan. I am in the same position you are. I have a 1FZ long block that was taken out of a rig here and was "donated" (ahem, cough, cough) to me. I have the head at home and it looks great. The block is at American Toyota until I have time to get the sucker home and put it on an engine stand in my living room (aka: my home garage... ).
My plan is to take the whole thing apart and create a plan to make a nice, finely tuned engine with some machine work, and custom pistons/rods/etc. That way, when my 1FZ currently in my rig dies, it is merely a matter of pulling connections, unbolting some screws, pulling out the old engine and putting in the new one.
I consider the 1FZ sitting around a "rainy day fund" for my 80.
Looking forward to seeing what you decide to do.
Best.
-onur
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
It is what it is....
beno is offline   Reply With Quote
Old 09-25-08, 07:51 AM   #9
Falco80's Avatar
TLCA# 18832
Cheers for the pics Dan.
It's not often you can see the inner workings of the mighty 1FZ! They are great engines!
Dan
92 FZJ80, 5sp, Part-Time Kit, 4" Lift, Locked, 305 muds....(Selling soon)
97 HDJ80, 5sp, 1HD-FT.....Turbo-diesel multivalve music to my ears!
Falco80 is offline   Reply With Quote
Old 09-25-08, 08:01 AM   #10
(pronounced rod-ree)
Ruadhrigh's Avatar
TLCA# 16603
Thanks for sharing and nice work. I haven't many 80's for sale with bad engines, but maybe you could squeeze it into a different cruiser.
Ruadhrigh is offline   Reply With Quote
Old 09-25-08, 08:16 AM   #11
Doc
Corn Eater
Doc's Avatar
TLCA# 17266
Dude- you just basically rebuilt it last year. It's going to keep going for another 15 years at least! You won't need that 'spare' for quite a while.
I vote you build a go-kart around it.
Eric P.
1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Tall Corn Cruisers- El Presidente.
Doc is offline   Reply With Quote
Old 09-25-08, 08:33 AM   #12
Wagon Owner
calfj60's Avatar
Dan,
Thanks for posting all the pics and info....Very interesting especially to me....
Tim Coffey
87 FJ60 SBC 350 SOA and some other stuff SOLD 5-15-07
94 80 with some stuff New to me 04-28-08
05 Subaru WRX
TLCA # 6947
Parts and Carb Rebuilds
http://www.marksoffroad.net
calfj60 is offline   Reply With Quote
Old 09-25-08, 08:45 AM   #13
Ruadhrigh's Avatar
TLCA# 16603
We only rebuilt the top end, Onur isn't pleased with having "old parts" in the block.
Now that he works at Am Toy he has become a parts snob
Old 09-25-08, 09:03 AM   #14
concretejungle's Avatar
TLCA# 14646
that's exactly what i was about to say
Now a 1fzfe go cart would be one heavy biotch.
how about a kick ass lawn mower powered by a 1fzfe?
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
concretejungle is offline   Reply With Quote
Old 09-25-08, 10:59 AM   #15
Unleash the Beast
LX_TREME's Avatar
TLCA# 4500
Riteee 1FZ-FE lawn mower uh? plus with TRD blower and some custom mandrel bent piping 6 of them stickin out straight from the headers , hmm wondering what it sounds like ... prolly all your neigbors will give you one of these
LX_TREME is offline   Reply With Quote
Old 09-25-08, 02:00 PM   #16
Doc
Corn Eater
Doc's Avatar
TLCA# 17266
Lawn? Do they have that in New Mexico?
Eric P.
Old 09-25-08, 02:28 PM   #17
I don't wheel
hj60's Avatar
TLCA# 11004
Sure they do.
But they do have to import them.
Jonathan M. Rundlett <skadalajara@gmail.com>
Copper State Cruisers #001
Member of the Happy Hour Gang and the last true conservative in the U.S.
'94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper
Originally Posted by NLXTACY View Post
Others here can explain that a whole lot better than me but IIRC it had to do with the Vicious Coupler.
hj60 is offline   Reply With Quote
Old 09-25-08, 03:37 PM   #18
Ruadhrigh's Avatar
TLCA# 16603
Originally Posted by hj60 View Post
Sure they do.
and the water to maintain them
Old 09-25-08, 04:49 PM   #19
Tools R Us's Avatar
Other than the piston skirt, that motor looks fantastic! I have seen much worse looking bearings out of 10K mile motor, those were good for another 200K. The question becomes why the piston failure, is the oil jet for that cylinder plugged, is the pin bushing tighter than the others?
Copper State Cruisers #007
Old 09-25-08, 05:22 PM   #20
bjowett's Avatar
If you decide to build it, I have a little info in this post....
http://forum.ih8mud.com/80-series-te...e-project.html
Brian
Western Massachusetts
08 Tundra Double Cab 5.7 TRD
93 FZJ80, locked, 4.6L, 6 speed, Orion <- now driving!
04 VW Touareg V8 w/ locker (hers)
80 FJ40 , 83k, PS and AC
05 Yamaha RS Rage Snowmobile
06 Suzuki King Quad
93 VW Corrado Syncro AWD 3.0L
51 Jowett Jupiter Roadster
bjowett is offline   Reply With Quote
Old 09-25-08, 09:41 PM   #21
Cynical Optimist
fj80toyman's Avatar
TLCA# 15140
Troubleshooting is another matter. I looked carefully at each step as we took it apart and found no solid clue as to why it would have failed like this. It does look like it was under-oiled and got hot at some point, but the oiler was clear as far as I could tell.
Of course if it were to be gone through, something might be found that led to the problem - such as an oil blockage to the front cylinder in the passage, etc. If I take it that far, I could be more thorough, if so I'll definitely post the results.
My main conclusion at this point is that at some point in it's life it might not have had as frequent oil changes as necessary. I know the PO probably wasn't to blame as it looks like he took good care of it for the time that he owned it. Change yer oil and run a Blackstone every now and then.
Dan.
Old 09-25-08, 09:48 PM   #22
Cynical Optimist
fj80toyman's Avatar
TLCA# 15140
Nicely done, thanks Brian. I'll mark that and keep it in mind. Dan.
Old 09-25-08, 10:05 PM   #23
Tools R Us's Avatar
... My main conclusion at this point is that at some point in it's life it might not have had as frequent oil changes as necessary. ...
Don't agree, unless you cleaned the parts? That is one clean motor, if you hadn't said the mileage I would have guessed 50K. For it to have 200K and be that clean and have that little wear, it's had very good oil service.
Old 09-25-08, 10:15 PM   #24
Cynical Optimist
fj80toyman's Avatar
TLCA# 15140
...hmmm, point taken. I didn't mention it previously but I might suspect the cooling passages around #1 cyl as well, haven't looked.
The reason I think long time between oil changes was the horrible smell that eminated out when I un-capped the main bearings and the black goo that came out from there, but the main AND rod bearings were in reasonable shape. gurrrr, now I'm more curious, may need to dig sooner than I thought.
Dan.
