Old 09-24-08, 12:56 PM   #1
slow91fj90's Avatar
Anybody ever try this and with what results?
Saw this on Downeys site and was curious.
MASS AIR SENSOR MODIFICATION*
* Tampering not legal,
should only be modified for racing use.
The following adjustment can be used to richen or lean the air/fuel mixture from the factory setting. This adjustment could be necessary when using a Big Bore Throttle Body or other EFI modifications. The mass air sensor (MAS) is found on top the air cleaner canister on 1985-95 Toyota vehicles. The sensor is an aluminum housing with black plastic lid. Cut the seal holding the black plastic lid in place. Gently pry the lid from the housing. To adjust, first mark the original location of the hold-down clamp on the gear wheel so you can return to stock setting if necessary. Loosen the clamp screw and rotate the gear wheel a few teeth as necessary. Clockwise leans the mixture, counter-clockwise richens the mixture. After adjustment, replace the top plastic lid (see Warnings below).
WARNING #1 - Use caution when cutting the top lid seal with a hobby knife so that plastic lid is not cut or damaged.
WARNING #2 - DO NOT let spring loaded gear wheel unwind, you will not be able to find stock setting/home base.
WARNING #3 - Ensure you establish a good seal when replacing top lid, moisture can destroy the sensor electronics.
WARNING #4 - DO NOT use an adhesive which creates a gas or fumes when drying, fumes will coat and destroy the sensor electronics – you’ve been warned!
91 FJ80, 3" OME, 33 PROCOMP MUD TERRAINS, ARB, GARMIN-V, 4:56'S, T-MAXX 10,OOO,NOT LOCKED,MOBILE AIR-CARD.
slow91fj90 is offline   Reply With Quote
Old 09-24-08, 01:22 PM   #2
nicholas's Avatar
I never never heard of this. I wonder if this would help solve some of the fuel management issues the 93-94's have with the S/C's
97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying.
nicholas is online now   Reply With Quote
Old 09-24-08, 01:37 PM   #3
bhmmapping's Avatar
TLCA# 18734
if you are going to open that up be very, very careful. People have accidentally cut wires, lost their mark and not been able to definitively return to factory settings... search on AFM should bring back some horror stories.
Matt
1992 FJ80 - OME 850/860, Bilsteins, ARB...
bhmmapping is offline   Reply With Quote
Old 09-24-08, 01:42 PM   #4
NLXTACY's Avatar
TLCA# 19015
I did this on my 4Runner when I had my fuel injectors blueprinted and I had my throttle body ported. It made a very noticeable difference. The newer LCs (95-97 I think) dont have this.
70 FJ40-sold, worst day of my life
79 TOY 4WD pup-stolen, 2nd worst day of my life
91 4Runner 4WD-burned to ground, 3rd worst day of my life
83 FJ60- suckiest day of my life
97 LX450, 221k, non-locked. Expedition vehicle in progress. Factory rack removed
Originally Posted by Brentbba View Post
Nah! I'll just overanalyze it for about 3-4 weeks, put up 5 posts about it, then not make up my mind.
ふざけんなよ!
Old 09-24-08, 04:44 PM   #5
slow91fj90's Avatar
NLXTACY, what did you do, lean it out or richen it up?
Internet Advertising | Internet Advertising | Compare Credit cards | Xecuter 3 Mod Chip | Remortgages
