Old 09-21-08, 12:19 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Ebag333's Avatar
TLCA# 18864
Overkill Armor Protection 101 - Belly Skid Plate
So as I've been getting into wheeling more and more, I've decided it was time to get some protection for the transfer case, as it's just begging to be hit.
Background
I initially considered going with Slee's or IPOR's, but there were a couple of draw backs that made me go a different route.
In the case of Slee's original skid plate, it doesn't cover near enough IMHO. A local cruiserhead here has Slee's original, and after the wheeling he has done (including Rubicon) the side of it is chewed up from hitting rocks at an angle.
In the case of IPOR (and Slee's new one IIRC), it's removing the factory cross member. I seriously considered removing it even for my own build, but you don't buy hardly any additional clearance (the t-case hangs below the cross member) and you have to deal with the hassle of building (and installing) a new one that matches the factory specs.
Additionally, neither Slee's original nor IPOR's attaches anywhere at the end. A hard enough hit could easily cause them to bend. Slee's new one does mount on the frame rails, but that wasn't an option when I started my build.
I also wanted coverage for the tranny. It'd be fairly difficult to hit it with a rock, but I'd much rather plunk down some cash for protection than deal with a cracked tranny on the trail. (I believe I read somewhere that Slee is coming out with a tranny plate that attaches to their new one.)
And finally, the biggest draw back to any of those options was price.
If I went with something that was pre-done already, I would have chosen Slee's new one in a heart beat. If that one wasn't an option, then IPOR's. All three of the skid plates are well designed and will function as they were intended, just none of them quite met my needs/requirements/wants.
Initial Design Decisions
I had a few basic requirements for my armor:
  • Protection of the t-case
  • Protection of the tranny
  • Frame rail to frame rail coverage (for protection from weird angle hits, for additional strength, and for easy mounting possibilities).
  • Keeping the factory cross member in place.
These design decisions basically ruled out any of the existing options.
The fellow who did most (darn near all) of the welding and cutting had built his own skid plates for his FJC. He had used 10 gauge steel, and had bent them up quite badly on Rubicon. The plates did their job that trip, but really wasn't ideal for the type of wheeling that he intended them for.
With that in mind, I had decided to aim for either 8 or 10 gauge steel, and double up the thickness in the weaker areas, along with some extra framing/bracing to prevent any bending.
Unfortunately, when I hit up the local steel yard all they had in their scrap/remnant section (in the size that I wanted) was 14 gauge. From there it dropped to 4 gauge. This was an easy decision as 10 gauge would not hold up to an FJC wheeling, there was no way that 14 gauge would survive an 80!
They did have some 2 gauge diamond plate that I briefly considered....but then I figured I wanted to keep it off the bump stops without having to catch air.
In retrospect the 4 gauge turned out to be an excellent choice. With the exception of one spot where the steel is a bit narrow (due to the positioning of the drive shaft, and being relatively close to the front lower control arm), I did not need to reinforce any areas of the plate itself.
And now for what you all really care about.....pics!
Initial Cutting
As the only thing we had to go from was a very rough cut chunk of cardboard and some rough measurements, we did a lot of cutting-fitting-cutting-fitting-cutting-fitting-cutting-fitting.
Some of the initial cuts. Plasma torches are cool!
First pass. Lots of steel yet to be removed.
This is what happens when you let your helper cut without close supervision. He goes and makes a sword.
Final Cutting
Skipping ahead about a half dozen hours of work (and did I mention test fitting?), we have what is essentially the final product.
Cutting out the access holes for drain plugs and zirks. The initial cuts were too small (and one was slightly off, due entirely to my WAG that was not quite right).
Plate finished! (View from the front of the plate, looking at the top.)
View from the drivers side.
View from the back of the plate.
(More after the cut!)
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 09-21-08, 12:20 PM   #2 (permalink)
Ebag333's Avatar
TLCA# 18864
On the truck!
This is the plate mounted, as seen from the front of the truck. There's actually more clearance between the sway bar and the plate, the angle makes it look smaller.
Front half of the plate (tranny protection) as seen from the drivers side. You can see it extends quite a bit forward.
View from the rear passengers side. You can see the t-case hanging down slightly.
Here's a shot where you can see how close the t-case is to the skid plate. I initially thought that I would be losing approx 1/2" to 1" of clearance from the factory skid plate position. I estimate I've actually gained about half an inch under the t-case.
Shot of the mounts on the driver's side. Sharp eyes will notice that these are different from the passenger's side. This is entirely due to my slightly off measurements that resulted in the passenger's side being short approx one half of an inch.
Knoll0351--who did most of the welding/cutting--does an excellent job at both. Any booger welds are entirely my fault for making him weld with the plate positioned on the truck (held up via a floor jack). Upside down. In the dark. With poor lighting. (He was even good enough to do some cuts with his plasma torch at the same time. )
Close up of the access hole for the t-case drain. We cut it quite a bit larger than just for the drain as the t-case actually was touching the plate with it mounted. Additionally, when starting or in 4 low, the t-case tends to move around a lot, so we wanted to provide plenty of room for it.
I am considering making a cover plate for that hole for that extra bit of protection. Theoretically a pointy rock could hit it. I haven't decided one way or the other yet.
And just to make it easy for people to find, you can click on the link below to see dimensions:
http://forum.ih8mud.com/3737427-post74.html
Final thoughts
Over all I am extremely pleased with the results. Huge props to Knoll0351 for his experience with his skid plate (and telling me everything he did wrong), and his skill with his welder and torch. Without him this would have never have worked (my welder can only get about 20% penetration on 4 gauge ).
There have been some questions on the weight. I haven't weighed it, but I am estimating the weight at around 75 lbs. The initial metal was 108 lbs, and we cut off about a fifth of it right away (the sheet was the right width, but way too long). Then of course we had to trim off the sides, cut holes, etc. There is no difference in ride height with it installed compared to it off the truck.
Cost Breakdown
Here's a rough cost breakdown.
Steel: ~$100
Mounting hardware (bolts/washers/etc): ~$10
There were some other misc costs (gas, buying lunch, etc). (I still owe Knoll0351 a . )
I estimate that it took about 20 hours (+-2). Now that it's done, I could use the existing skid plate as a template, and have a new one done in about 2-3 hours.
Future plans
And of course I'm not finished with it!
As mentioned above, I'm considering adding a plate to cover the t-case access hole.
I will eventually be mounting tabs on the top of the plate (in the hole between the frame rail and the t-case) to mount an air tank. It's the perfect size for one, and will be VERY well protected!
I also have an idea bouncing around in my head for tabs for some rock lights along the edges.
And of course, who knows what else the future might hold?
'97 LX450
'96 LX450
Old 09-21-08, 12:47 PM   #3 (permalink)
NLXTACY's Avatar
TLCA# 19015
EBAG, I know you showed me this last week, but you're still nuts!!! Great protection though!
ふざけんなよ!
Old 09-21-08, 12:49 PM   #4 (permalink)
Ebag333's Avatar
TLCA# 18864
Yeah, but those were a handful of crappy cell phone pics.
Didn't you say you wanted one?
By the way, the guy who helped do the welding/cutting said he's up for building another. He's already talking about how to do "Belly plate version 1.1".
'97 LX450
'96 LX450
Old 09-21-08, 01:16 PM   #5 (permalink)
livinoffroad's Avatar
"As mentioned above, I'm considering adding a plate to cover the t-case access hole."
With all that protection, you would be remiss to not make a cover plate...drill or torch a 3/8" hole on either side of the rectangular hole, weld a couple nuts on the top side of the "belly pan", and bolt thru from underneath.
Easy drop down , or swivel aside action for maintenance. This type of "belly pan" was quite common on the Caterpillar dozers, loaders, and scrapers I used to work on as a kid.
Except they used 3/8" plate.
Great job on your "belly pan".
One suggestion...you might consider welding an angled edge on the rear, so if you ever find yourself reversing out of the rocks, you won't catch on the rocks, but will ramp up over them.
Consider posting the dimensions for tech.
Way to go!
'95TLCFZJ factory locked on 33s, OME 863/850's w/30mm spacers in front(no stink bug),caster correction drop brackets, SS brake lines,Odyssey,DBA,CDL,HIR,FSM,scangauge II
'93 4x4runner(13yrs)
'85 4x4 mini truck/22re(15yrs)
'80 4x4 Chevy Snowplow
'86 4x4 MasseyFerguson 1045
livinoffroad is offline   Reply With Quote
Old 09-21-08, 01:35 PM   #6 (permalink)
NLXTACY's Avatar
TLCA# 19015
Oh I never said I DIDN'T want one
ふざけんなよ!
Old 09-21-08, 01:58 PM   #7 (permalink)
Ebag333's Avatar
TLCA# 18864
This is probably what I'll end up doing. I don't like the extra plate because it provides something to get rocks hung up on, but I'll end up doing it anyway.
Well I'm not that much thinner than them.
That's a good idea, and something that I will probably do once I reroute my exhaust over the frame rail. Once I reroute the exhaust that cut out for the tubing won't be needed, and I'll have some extra room for what you suggest.
I intend to take measurements in case if I ever do version 1.1. When I do, I'll post them here.
'97 LX450
'96 LX450
Old 09-21-08, 02:40 PM   #8 (permalink)
The quick brown fox .....
Beowulf's Avatar
How do you access the transfer case fill plug?
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 09-21-08, 03:47 PM   #9 (permalink)
Ebag333's Avatar
TLCA# 18864
-B-
I should be able to reach it from the back of the skid plate.
If it's too difficult to get to, I can drop the skid plate quite easily. It's only 6 bolts.
'97 LX450
'96 LX450
Old 09-21-08, 05:03 PM   #10 (permalink)
ThinkTank Waterboy
landtank's Avatar
You've got nothing supporting that metal in the back under the t-case. I'd put a jack under there and see how much it flexes. I think if the truck came down on that plate with all it's weight you might get contact.
Rick Bigelow
'96 215k
Groveland MA 01834
landtank is online now   Reply With Quote
Old 09-21-08, 05:39 PM   #11 (permalink)
wanderlust
nat88toy's Avatar
TLCA# 16379
sweet man looks great! just made one very similar and couldn't be happier
98 sr5 T100 32" procomp mtr
1994 FZJ-80 factory locked, 4" lift, Landtank caster plates, Arb bumper, warn 12,000, snorkel, 35" TrXus mt, full belly skid, extreme air, bud built HD- TR & DR, HD 1/4 wall DOM control arms
1996 FZJ-80 factory locked, 4" lift Land tank caster plates, arb bumper, warn winch, HD 1/4 wall DOM control arms,FOR parhard adjusters
nat88toy is offline   Reply With Quote
Old 09-21-08, 05:51 PM   #12 (permalink)
ONSC triad VP
jfz80's Avatar
TLCA# 16634
Great coverage and initiative to go out and tackle making your own design!!!
X2 on adding an angle up in the rear and maybe incorporating a brace at back end to framerails \_/ .
Jason---- I live vicariously..........................through myself
__________________________________________________ __________
95 80 -- Slee4''/omeJ, 37's, factory locked, full armor and a s/c too
72 55-- w/ 76 4sdp 78 f. disc 79 2F -- SOA + 3'' w/ 35's, IPOR protection
92 P/U -- no "D" light, no umph, no fun except at the pump
jfz80 is offline   Reply With Quote
Old 09-21-08, 05:53 PM   #13 (permalink)
looks good. im thinking of doing the same. for i cant aford all that expensive shit and i do no how to weld .
cruiser 51 is online now   Reply With Quote
Old 09-21-08, 05:58 PM   #14 (permalink)
Ebag333's Avatar
TLCA# 18864
I've done exactly that with no flex. My jack isn't tall enough to completely lift the tires off the ground, but the suspension is pretty well unloaded.
It wouldn't surprise me if eventually the back end started bending/bowing slightly from hits, but it's going to take a LOT of force, and I doubt it's going to move far enough that it'll become a problem (there's nothing above it that it can interfere with).
And if it does move, I can always drop it and hammer it flat. Or maybe I'll just consider it "self adjusting" to provide an angle for when I backup over a rock.
When/if I add an angle at the back, I could add in some angular bracing off that to provide support and prevent warping....
It's not difficult. If your welder can't handle 4 gauge, 6 gauge should work just as well. (I would probably add bracing in a couple of spots for extra strength.) I don't think for a plate this size anything thinner than 6 gauge would work that well, given how heavy an 80 is.
'97 LX450
'96 LX450
Old 09-21-08, 06:09 PM   #15 (permalink)
ThinkTank Waterboy
landtank's Avatar
If you think you will be able to hammer it flat if it bends, the stock isn't thick enough.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 09-21-08, 06:36 PM   #16 (permalink)
Ebag333's Avatar
TLCA# 18864
Well, maybe with a 20 lb hammer. And a much much bigger guy than me.
(I already know that my 5 lb hammer with me behind it won't even dent it. Ask me how I know...)
Yeah...it was wishful thinking.
'97 LX450
'96 LX450
Old 09-21-08, 07:03 PM   #17 (permalink)
nicholas's Avatar
TLCA# e9999
Very nice, stout, low cost alternative, I like it! Look forward to seeing the dimensions when you get around to it. Great work!
97LX450, 145K, 315CooperSTT's, OME851/860's, TRD S/C, Bump It Offorad Sliders, 4x4 Labs rear, J-Moose rack, Camping Lab RTT, CDL 7-Pin, George's LED's, Slee SS lines, 100 pads, silicone PHH, Raventai temp, Z34 Vent, Serious case of E-locker envy, CDan parts throughout. IM Scut monkey level I.
http://forum.ih8mud.com/80-series-tech/290251-rotf.html
nicholas is offline   Reply With Quote
Old 09-21-08, 07:23 PM   #18 (permalink)
IH8Mud4Life
PScottBx's Avatar
TLCA# 16251
Nice
Bx
1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag"
Good friends, a few cruisers, alot of laughs and a bunch of wives making this face -->
"If I'm off (which is rare)... I'm in!"
PScottBx is offline   Reply With Quote
Old 09-21-08, 10:09 PM   #19 (permalink)
1shot1kill's Avatar
Great work! Cheers!
IN VINO VERITAS
93 locked, Afrika Korps,sand ladders,snorkel,PIAA Arbed, 9k winch w/syn. od rope, quick release sways, OME, snorkel, Man-A-Fre rack, Lowrance GPS, 4:88s, custom drivelines by NW LC, spacers, 38s, Arb awning, K-three can , net,curtains, limb-raisers, Thule bike rack - WIP!
1shot1kill is offline   Reply With Quote
Old 09-22-08, 07:23 PM   #20 (permalink)
Russ in California's Avatar
TLCA# 13306
Instead of the usual birf party, maybe there should be a bellypan party. Make a weekend out of it. ???
VIDS
PICS
91 3FE REPOWER
DIE TRYING
Russ in California is offline   Reply With Quote
Old 09-22-08, 07:47 PM   #21 (permalink)
NLXTACY's Avatar
TLCA# 19015
ding ding ding!!
ふざけんなよ!
Old 09-22-08, 08:13 PM   #22 (permalink)
Ebag333's Avatar
TLCA# 18864
I'm game.
'97 LX450
'96 LX450
Old 09-23-08, 01:53 PM   #23 (permalink)
OHV Trail Patrol
CreeperSleeper's Avatar
TLCA# 15577
I would love to have one of those...
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 09-23-08, 02:23 PM   #24 (permalink)
Ebag333's Avatar
TLCA# 18864
The way you wheel, it might work better if your entire body was made out of 4 gauge steel.
You're not that far away from me though. If you want one, let me know, and it can be arranged.
'97 LX450
'96 LX450
Old 09-23-08, 03:34 PM   #25 (permalink)
Not to sound negative, but I'm with Landtank. The weight of the vehicle unloading onto a hard surface like a rock is much greater than that of it not even completely suspended by a jack.
'97 Lexus LX450 - CDL/7 Pin | Factory cup holder | Black LX wheels | 305/70 Toyo M/T | Optima Redtop | Auto-Up mod | George's LEDs | 1.5" Spacers |
F0RSAKEN is offline   Reply With Quote
Old 09-23-08, 04:07 PM   #26 (permalink)
Wrench's Avatar
I still love my IPOR. It protects so well. And I really love the added ground clearance.
<>< Hardcore Rockcrawling 80. Marks Crawl Box, 5.29's, 37's
Wrench it, wheel it, break it, repeat it.
Wrench is offline   Reply With Quote
Old 09-23-08, 04:24 PM   #27 (permalink)
Ebag333's Avatar
TLCA# 18864
I don't disagree. Force = Mass X Acceleration. We know the mass, we can guess at the acceleration, and that equals one heck of a large amount of force. Much more than lifting up the truck with a jack.
I don't think that this is going to bend much if at all however. It is better supported than other options on the market (except for perhaps Slee's new one, I'm not sure how that one is mounted up yet). It's also a thicker material than most other options.
I really like the IPOR. I disagree however that it buys you any ground clearance that matters. The T-Case hangs way lower than the cross member, and you're measuring your extra clearance in quarter inches.
In 99.9999999% of all situations, if that extra clearance was going to make the difference, you were likely hosed anyway.
Since my skid plate is tucked up so tightly against the t-case (maybe even too close), it has at least as much if not more clearance as the IPOR does under the t-case.
As I said before, if I didn't go my own route and if Slee's new one wasn't available, IPOR's would have been my choice easily. IPOR's plate is a great product, just a bit too pricey for me, and didn't quite fit my needs/wants.
'97 LX450
'96 LX450
Old 09-23-08, 07:20 PM   #28 (permalink)
OHV Trail Patrol
TLCA# 15577
My body is way too far gone to save, not even worth it anymore!
PM me a $$. I may be able to talk the into it after the 4Runner sells!
KE7VSA - MetalTech
Old 09-23-08, 07:28 PM   #29 (permalink)
:)A YELLOW MAN(:
hatman406080's Avatar
i just wonder with heat build up under form tran,cat.
hat
1989 Fj62 190,000MiFor sale
hatman406080 is offline   Reply With Quote
Old 09-23-08, 08:36 PM   #30 (permalink)
Ebag333's Avatar
TLCA# 18864
That's why you cut it all away and rebuild it from 4 gauge steel! Really kill your aerodynamics by making it one giant box!
I'd actually never intended it for resale (or to do more) but the guy who did mine said he'd like to do at least one more (to fix all the little flaws in mine)....
Cat's aren't an issue unless you've relocated them (and I'm not sure where you'd relocate them to in that area anyway). They are outside the frame rail, so not covered at all.
There will be more heat buildup from the tranny and t-case, but so far I haven't noticed any issues. I haven't gone farther than about 40 minutes (almost entirely freeway), and I could easily lay my hand on the skid plate. It was warm to the touch, but not uncomfortable.
I think that there is plenty of air getting through there. Remember a lot of folks with IFS put up skid plates that block off far more air flow to the tranny than my plate does, and they don't seem to have any issues.
If you feel it's an issue, slots could easily be added in the front half to allow more air flow through. That would of course weaken that area, but it's not likely to get a lot of hard hits to begin with.
'97 LX450
'96 LX450
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/241843-overkill-armor-protection-101-belly-skid-plate.html
Posted By For Type Date
Overkill Armor Protection 101 - Belly Skid Plate - IH8MUD Forums This thread Refback 02-05-09 10:54 PM
03 Offroad Forester - Page 3 - Subaru Forester Owners Forum This thread Pingback 10-09-08 08:57 AM
