09-24-08, 07:07 PM
#31 (permalink)
Originally Posted by Ebag333;3681235I
really like the IPOR. I disagree however that it buys you any ground clearance that matters. The T-Case hangs way lower than the cross member, and you're measuring your extra clearance in quarter inches.
In 99.9999999% of all situations, if that extra clearance was going to make the difference, you were likely hosed anyway.
Since my skid plate is tucked up so tightly against the t-case (maybe even too close), it has at least as much if not more clearance as the IPOR does under the t-case.
As I said before, if I didn't go my own route and if Slee's new one wasn't available, IPOR's would have been my choice easily. IPOR's plate is a great product, just a bit too pricey for me, and didn't quite fit my needs/wants.
Your replacing a box piece of steel with a flat plate. Of course you gaining ground clearance. You just wrapped a piece of steel around that box cross member. You lost a lot of ground clearance doing that. Measure your clearance. You will see it is low. I will measure mine.
<>< Hardcore Rockcrawling 80. Marks Crawl Box, 5.29's, 37's
Wrench it, wheel it, break it, repeat it.
09-24-08, 09:05 PM
#32 (permalink)
Measure from where?
At my *VERY* lowest point the plate is a hair less than 2 and a half inches under the frame rail. I could cut and angle the back up (after the lowest point of the t-case). I would probably do this in version 1.1 (though no reason I couldn't do it on this plate).
Your lowest point isn't any higher though if you do that. Maybe 1/10th of an inch.
Now the IPOR *DOES* have more clearance, since it doesn't cover as large of an area. But if you came down hard at an angle, you could also go right past your plate and hit the t-case. It's always going to be a clearance VS coverage issue.
09-26-08, 04:06 PM
#33 (permalink)
Yeah, if anyone is interested in having me assist them in fabbing up a skid plate shoot me a PM and we can talk about the details. And if there is anyone that would like to simply purchase one of these fine pieces of steel we can discus cost. I enjoy working with metal and perfecting my welding/fabbing skills.
On this version we'll call it 1.0 there were a couple of issues that I would have handled a bit differently had it been on my rig or had I been able to messure once and cut longer the second time  . I think that version 1.2 will be much more symetrical as well as coming out quite a bit cleaner. Not that there is actually anything wrong with 1.0 just a couple of minor things that I'd improve on the second time around.
We have recently started the Jefferson State Cruisers and I left an open invitation to our members that if they want to pay for materials I would love to assist them in whatever fabrication they are looking to make happen. We can be found in the TLCA Forum/Clubhouse or by clicking on the link in my signature line.
Enough advertising, please feel free to post up with any questions or PM me.
Originally Posted by Brian in Oregon
"As an American I am not so shocked that Obama was given the Nobel Peace Prize without any accomplishments to his name, but that America gave him the White House based on the same credentials." - - Newt Gingrich
07 FJC Voodoo Blue - 3" Sway Away - 33" Toyo M/Ts - Custom Skids by Knoll - On Board Air - AllPro Front Bumper/Light Bar - ARB Full Length Roof Rack - Warn M8000/Wireless Remote
Wheel it or Park It!!
09-30-08, 02:16 AM
#34 (permalink)
Did you have any other build pix?
09-30-08, 11:06 AM
#35 (permalink)
I don't, and that reminds me, I need to get some dimensions....
09-30-08, 02:06 PM
#36 (permalink)
i think it looks awesome! don't be discouraged by some web wheelers on here. I'm with you in that you build it, try it out and make adjustments as necessary. If it bends, you fix it. If it doesn't bend, you keep trying to bend it!
Creeper fo' sure needs one of those!
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
09-30-08, 03:06 PM
#37 (permalink)
If he bends that 4 guage steel I'll eat my hat...or something else equally unpleasant.
09-30-08, 03:08 PM
#38 (permalink)
Thanks Concrete.
And Creeper and I have already spoke about building him one.
09-30-08, 07:13 PM
#39 (permalink)
one more question though....
Is the T-case actually touching the plate? If it is, do you feel/hear any buzzing or vibrations?
09-30-08, 07:43 PM
#40 (permalink)
It was before we cut a hole in it. And yes, it did vibrate/buzz at times.
The hole is slightly too small. In certain instances the plate can rub against the "lip" (that surrounds the drain hole) and is making a cut into it (steel being stronger than aluminum).
I'm not terribly worried about it as it's not damaging anything vital, but I will be trimming the hole a bit larger to move it further away from that spot.
I do not hear/feel any buzzing or vibrations currently, I suspect that the only time it touches is when the engine is starting.
09-30-08, 07:46 PM
#41 (permalink)
Originally Posted by Beowulf
How do you access the transfer case fill plug?
-B-
B,
Here's a pic that should give you a better idea.
Sorry for the blurry/grainy pic. It was a bit on the dark side and hard to get a good angle.
As you can see, the fill plug is quite easily accessible. The end of the plate stops right about where the rear d-shaft mates up with the t-case.
09-30-08, 07:52 PM
#42 (permalink)
Hey EBAG,
Any way to get a pic that isn't so blurry, a little less dark and at a slightly better angle?
ふざけんなよ!
09-30-08, 07:55 PM
#43 (permalink)
Originally Posted by NLXTACY
Hey EBAG,
Sure! Lets slap this bad boy on yours, flop yours on your side, then take a nice, bright, clean, clear, and all around better picture!
09-30-08, 09:04 PM
#44 (permalink)
When do ya wanna come by so I can burn that hole into the right shape so it doesn't touch any longer? Before the 18th club run yeah?
09-30-08, 10:39 PM
#45 (permalink)
Subscribe today!
Great work, well done, nice to see innovation!
David Zartman
Publisher
4WD Toyota Owner Magazine
http://www.4wdtoyotaowner.com
1995 FZJ80, 1970 FJ40, 1999 Tacoma, 1979 V8 FJ40, 1986 4Runner, 1973 FJ40, 2000 4Runner, 1984 hardcore buggy, 1980 HJ47 Troopy, VIN HJ47000007 (2H diesel, soon turbo)
09-30-08, 11:45 PM
#46 (permalink)
 Interested in some pro bono marketing?
10-01-08, 12:10 AM
#47 (permalink)
Is this something you might be making, ready to go and bolt on, no welding or cutting required? Or in kit form? I like it. Even if the clearnace isn't quite as much as the others, I like the full coverage just from things like brush, trees, etc, that I'd be more likely to run over. Are the cats covered too?
10-01-08, 12:39 AM
#48 (permalink)
Cat protection from theft would be a ++++++
ふざけんなよ!
10-01-08, 08:41 AM
#49 (permalink)
I will be posting the specs here, so you could easily fab up your own.
I guess you could call that a kit.
If knoll is up for doing more, then yes, we could make one ready to go (bolt on).
Shipping will be the catch, but if you're up near Portland I head that way occasionally to my wifes folks house, or might be able to arrange a mudship up there.
Cats aren't covered as they are outside the frame rail. This covers frame rail to frame rail, front sway bar to rear d-shaft (where the d-shaft mates up with the t-case).
It would be very easy to weld/bolt on some outriggers on the top of the plate to cover the cats. I am considering doing exactly that for my sliders. (My cats will be cut and turned, which should tuck them up enough that they're pretty well protected.)
10-01-08, 08:53 PM
#50 (permalink)
The plate is an all one piece design and bolts right up with only six bolts that go right into the existing threaded holes already in the frame from the factory. As far as ground clearancce it isn't any less than the stock vehicle since it actually touches the rear cross member.
10-01-08, 08:59 PM
#51 (permalink)
As for the cats it would be relatively easy to add protection to our original design for them. We would just need to know what if any mods you have made to your exhaust system. And yes if there is a demand I would be more than willing to start up a small business...or just make a couple.
10-02-08, 05:26 AM
#52 (permalink)
Originally Posted by livinoffroad
"As mentioned above, I'm considering adding a plate to cover the t-case access hole."
With all that protection, you would be remiss to not make a cover plate...drill or torch a 3/8" hole on either side of the rectangular hole, weld a couple nuts on the top side of the "belly pan", and bolt thru from underneath.
Easy drop down , or swivel aside action for maintenance. This type of "belly pan" was quite common on the Caterpillar dozers, loaders, and scrapers I used to work on as a kid.
Except they used 3/8" plate  .
Great job on your "belly pan".
One suggestion...you might consider welding an angled edge on the rear, so if you ever find yourself reversing out of the rocks, you won't catch on the rocks, but will ramp up over them.
Consider posting the dimensions for tech.
Way to go!
Thank you, and sorry that I haven't been reading this thread from the begining I started at the end and may be answering a previously answered question at this point, but.
Version 1.1 will address most concerns I think. We will ensure to go fully frame rail to frame rail next time around.
Also we will use the same steel but cut the last section off...I'm thinking 6" and re attach it at a slight angle such as the front. This will actually add strength as well as give a "ramp up" if needing to revers while negotiating an obstacle.
Weight really isn't an issue I don't believe ( a passanger or cooler will out weigh this armor) but none the less I think that just thicker than 1/4" is a bit more than needed and ideally I'm thinking 3/8 will definately handle the strain that is put on it (especially if a CAT uses 3/8").
As for the protection for the T-Case access hole I'm thinking of taking a bit of scrap and cutting it to size to include front and rear approach angles as well as ground to angle so that there is no lip when it comes to contact the main armor ie \_______/ . For mounting hardware I'm thining cutting a slightly oversized hole in the acces cover for the three or four bolts to go thru. Then using scrap as a spacer between cover and main armor, providing a resess for the bolt head to be protected, drill matching holes on the main armor and as suggested tack nuts to the top of the main armor. (I really hope that made sence because it totally does in my head right now!)
With all of that being said since this is a custom build I am definately open to making any changes that a "customer" might suggest or desire. As in this case I did offer some design ideas and engineering when push came to shove the complete project was Gabe's so he had final say on all mods and design specs. Unless I get a CNC or some other seriously expensive fabbing equipment anything is doable since anything will truly be custom made from hand.
And as for strength, which I know wasn't a concern of yours but many others did mention it so, here is a stat that I found with some research:
Priced $62,000. to $200,000.
Shearing Capacity Bending Capacity
1/4" x 53" 45 tons x 53"
3/16" x 53"mild steel
Now I'm no engineer, but that sounds like one hell of a lot of force to bend quarter inch material...I'm just sayin'
10-02-08, 05:37 AM
#53 (permalink)
Originally Posted by cruiser 51
looks good. im thinking of doing the same. for i cant aford all that expensive **** and i do no how to weld .
This could be just as easily constructed using the most basic metal tools, not as quickly and a bit more painstakingly, but none the less can be done. A gas tourch will cut this material with a bit more slag and maybe less accurately (depending on how good you are) and the welds can all be done with a "Buzz Box" or even Oxy Acet if you really wanted to do it. As heavy as the material we chose is I don't even know that there would be much if any warping with even gas...although I'd rather use ARC or MIG...
10-02-08, 05:40 AM
#54 (permalink)
Originally Posted by landtank
You've got nothing supporting that metal in the back under the t-case. I'd put a jack under there and see how much it flexes. I think if the truck came down on that plate with all it's weight you might get contact.
This was a concern of mine, however, with the thick truly over kill material "we" chose  Gabe  this won't be a problem. Even if it would be the rear mounts are far enough rear that any deformation will occure rear of anything vital and provide the approach angle of version 1.1 anyway
10-02-08, 05:44 AM
#55 (permalink)
10-02-08, 05:50 AM
#56 (permalink)
Originally Posted by hatman406080
i just wonder with heat build up under form tran,cat.
With the tranny being cooled by a seperate radiator I would consider this a moot point, however, even in my FJC (that has little to no air flow underneath) overheating would not be an issue. When I did the build up on my FJC it runs fully from the All Pro front bumper to past the rear transfer case yoke and I have had no noticable increas in heat from my guages or plug in computer.
10-02-08, 10:16 AM
#57 (permalink)
my time is free...well mostly free    to all JSC members...
So....you're saying your time is free if we give you a beer, a banana, and a pimp?
10-02-08, 05:31 PM
#58 (permalink)
OHV Trail Patrol
Well, I'm still interested up here in Portland... And I'll be more than happy to put them through hell to see if it will bend.
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
10-02-08, 05:38 PM
#59 (permalink)
Woah...yeah not so much...I was getting at beer, food...that would result in me giving you the Pimp Smile. Cuz I'ze an OG gizanksta!
10-02-08, 06:05 PM
#60 (permalink)
Ok good, made it sound like Gabe offered up his
ふざけんなよ!
