Go Back   IH8MUD Forums > classifieds.ih8mud.com > Business Classifieds > Merchandise Storefront
Old 10-05-08, 03:09 PM   #121
EricG's Avatar
Originally Posted by 96r50 View Post
That's what a "limited time offer" will do to folks! I would probably still be debating this addition (wanting it, but not getting the ball rolling) if Joey didn't come along with a deal to sweet to pass up
Yep, that's what did it for me. I've been gathering parts for awhile, and figured I'd pull the trigger on the most expensive bit when I was actually ready to do the install. Then it disappeared from Slee's site and Lumpdog's system fell through So when this came around, I had to jump on it.
It is neither necessary or possible to educate someone who never questions anything. - Josephe Heller, Catch 22
93 FZJ80 - Locked & Lifted - still waiting on Loaded (CDL, 7pin, Axle transplant from Jenny Cruiser, 2" OME lift)
EricG is offline   Reply With Quote
Old 10-05-08, 04:11 PM   #122
NLXTACY's Avatar
TLCA# 19015
Limited offer also allows the poor guy to get better pricing on materials. This way he can buy once instead of several times.
As a side note, I talked to GLWJ this AM and we discussed some changes that I thought would be good and some other additions/news that will be announced soon.
70 FJ40-sold, worst day of my life
79 TOY 4WD pup-stolen, 2nd worst day of my life
91 4Runner 4WD-burned to ground, 3rd worst day of my life
83 FJ60- suckiest day of my life
97 LX450, 221k, non-locked. Expedition vehicle in progress. Factory rack removed
Originally Posted by Brentbba View Post
Nah! I'll just overanalyze it for about 3-4 weeks, put up 5 posts about it, then not make up my mind.
ふざけんなよ!
Old 10-06-08, 10:44 PM   #123
release the hounds
Scott_sFZJ80's Avatar
TLCA# 13283
Cool news on the approximate ship date! Thanks Joey for all your efforts!
1993 FZJ80 ROTW - October 23-29 2005
Snorkel install , Skid Plate install , Rear Bumper
Originally Posted by Gumby View Post
real men stick weld in flip flops
Scott_sFZJ80 is offline   Reply With Quote
Old 10-07-08, 02:36 AM   #124
NLXTACY's Avatar
TLCA# 19015
No problem. The pulleys have been started after a slight change was realized. The 1/4" steel has been ordered for the brackets. GLWJ will be making one unit first and installing it on his own truck and then fine tuning and then taking pictures. Much more info to come.
ふざけんなよ!
Old 10-08-08, 12:35 PM   #125
EricG's Avatar
Any updates, pics, drawings, etc.?!
Old 10-09-08, 12:33 AM   #126
NLXTACY's Avatar
TLCA# 19015
Ask and ye shall receive...eventually. This should make it a LOT easier to visualize. Just goes together like a puzzle and then welded.
Install pics to come as soon as GLWJ finishes the first set up and installs on his own truck.
More coolness to be announced as well once we get closer.
ふざけんなよ!
Old 10-09-08, 10:05 AM   #127
EricG's Avatar
Ha - That waterjet stuff is really cool! Now give at least one dimension and I'll print it up on some cardstock and see what it's going to look like
Old 10-09-08, 10:05 AM   #128
96r50's Avatar
TLCA# 18726
Nice! I like the dovetail/notched design. It must make it easier for him to assemble and weld. One question though, where does the tensioner fit in?
Adam
96 LC, OME 851/860, BFG AT 285, Metaltech sliders, IPOR skid, Yellowbox, Landtank seat brackets & MAF, ScangaugeII, Slee harnesses with HIRs & Hella 500s, CDL & Pin 7, George's LEDs, Slee-located washer bottle, 'MUD sticker
OME CC bushings for sale
96r50 is online now   Reply With Quote
Old 10-13-08, 06:57 PM   #129
release the hounds
TLCA# 13283
bracket
Old 10-13-08, 07:16 PM   #130
NLXTACY's Avatar
TLCA# 19015
Thanks Scott.
Ok folks that is an accurate render of the bracket.
Here is the latest and it keeps changing as we keep learning new things:
• The 1/4" sheet is being picked up tomorrow and then one unit till be built and installed on GLWJ's truck to make sure everything is aligned. If the alignment is true then its just a few days to cut out everything for all the kits.
• The pulley has been re-redesigned so that all three pulleys are now 5". This meant stopping the first run and redesigning the pulley and then re-starting machining. The 3rd pulley will be set slightly set apart from the others to align with the stock air conditioning compressor.
• The pulley size was changed to 5" so that it would bump up the revolutions on the York at idle, thus greatly reducing the need to have the truck rev'd higher or have the hand throttle on.
• The new pulley design will NOW be on the same linear alignment with the stock air compressor THUS eliminating the need for another tensioner. The York will instead use the tensioner used on the stock a/c unit.
• There is now no adjustment needed for the York set up, this will eliminate a lot of headaches.
• GLWJ will now be including (12) bolts for the York. This 4 for each side and 4 for the bottom.
• GLWJ will now be including the head bolts needed to mount the bracket to the head.
And last but not least GLWJ will NOW be including the correctly sized belt needed to run the York set up. This means you will now be supplied with EVERYTHING you will need to bolt up this kit: bracket, 12 bracket bolts, 4 head bolts, pulley, belt.
Anyone who has ordered just the bracket, I will be PM'ing you separately because this new set up will be affecting you.
I will also need to change the proposed delivery date in order to account for the new, new redesign
ふざけんなよ!
Old 10-14-08, 10:02 AM   #131
EricG's Avatar
Nice! I'm curious why the bracket wraps all the way around the york? I'd have thought that the bolts from just the engine side would be enough - or engine side & bottom?
Old 10-14-08, 10:57 AM   #132
GreatLakesWaterjet's Avatar
Time for me to chime in. I ran the original bracket for quite a while with no problems. After taking the York off and on many times, I finally stripped the 4 bolt holes on the engine side. Maybe it was just my York, maybe not. I'm not taking the chance of that happening again. The York has 12 mounting holes and I decided to use all of them. This new setup will use the tensioner on the A/C. The new belt will replace the old A/C belt. It will route around the crank pulley, the new fan pulley, the A/C pulley and tensioner, and the York. I am trying to source Toyota belts as a replacement. I am moving the York a little closer to the engine too for clearance for a second battery tray. I feel this new set-up is about as bullet proof as possible. Hope this helps explain.
94 FZJ-80 DD,lockers,850-860 with 1" spacers,37x12.50x17 Truxus M/Ts,17x10 GLW beadlocks,York OBA,GLW front and rear bumpers,Warn 9000 with blue rope,Auto window mod,GLW rear cargo bars,LED cargo lights,CDL switch and Pin-7 mod,OEM hand throttle,lots more coming!http://www.greatlakeswaterjetinc.com
GreatLakesWaterjet is offline   Reply With Quote
Old 10-14-08, 11:12 AM   #133
NLXTACY's Avatar
TLCA# 19015
Just to add to that, some Yorks have bolt holes that are already stripped before you get your hands on them. I bought a second York as a back up and mainly because it was only $10
But the one I just got has two stripped threads. The first one I got from APPLETECH had no stripped threads.
ふざけんなよ!
Old 10-14-08, 12:43 PM   #134
96r50's Avatar
TLCA# 18726
Hmm, looks like I have to fix my A/C sooner than I thought. I do like the idea of using an OEM belt though.
Adam
Old 10-14-08, 12:57 PM   #135
My A/C is broke too. Heck, I don't use it anyway.
Old 10-14-08, 02:27 PM   #136
96r50's Avatar
TLCA# 18726
My A/C clutch is seized, so I don't really have a choice if I want to use the bracket
Adam
Old 10-14-08, 02:45 PM   #137
Hate that mud...
TrickyT's Avatar
TLCA# 14435
Hmm. With this new setup will the drive belt engage enough circumference of the A/C pulley to drive it without slipping/squealing, especially when the A/C kicks on? There should be plenty of belt riding on the York pulley, but I'm not so sure about the A/C. (Going from memory here.) How can we find out if if GLWJ's A/C is broken?
Tom Ferrin
N6TEF - 2m and 70cm
1989 FJ-62 - 200K, 3" OME lift, recent engine overhaul, my daily driver
1997 FZJ-80 - 85K, lifted, bumpers, sliders, lockers, and Moab-trails tested
TrickyT is offline   Reply With Quote
Old 10-14-08, 02:50 PM   #138
NLXTACY's Avatar
TLCA# 19015
Well it will be going on my truck right after.
ふざけんなよ!
Old 10-18-08, 08:46 AM   #139
alia176's Avatar
TLCA# 15941
Just as a quick test, get the pulleys nice and wet and see if you notice any slippage.
TLCA # 15941
KE5LED
Currently working PA
alia176 is offline   Reply With Quote
Old 10-18-08, 08:23 PM   #140
chitown40's Avatar
TLCA# 14424
Tom, you're the same guy Ali and I wheeled Golden Spike with in Moab, correct?
I know exactly what Tom is saying as he probably remembers my York squealing the entire time once I got it wet and/or dusty. I used a single belt setup to capture the a/c idler, a/c pulley, water pump pulley, and crank pulley. The advantage of the single belt is that it was easy to tension up, but it squealed like a whore because there really wasn't enough surface contact on the pulleys to turn the compressor once the clutch engaged which caused a lot of noise but minor if any slippage.
I bought GLWJ's last triple groove pulley once I got home from Moab and went to an extra belt running off the water pump pulley to the York. No problems or any noise whatsoever after the change.
Just FYI. Good point Tom.
1997 FZJ80 CE - Locked, CDL, ARB, 315 MTRs, OME Heavies, Custom sliders, Custom drawers, T-Max 10K, York OBA System
TLCA #14424
chitown40 is offline   Reply With Quote
Old 10-18-08, 08:48 PM   #141
Hey guys, I'm gonna try this new set-up. If it is not correct, you won't get it. I still have all the original plans. I just feel this is a better system. I will post results before anything is shipped.
Old 10-19-08, 11:34 AM   #142
Hate that mud...
TrickyT's Avatar
TLCA# 14435
Originally Posted by chitown40 View Post
Tom, you're the same guy Ali and I wheeled Golden Spike with in Moab, correct? ...
You got it - good memory. It was your original setup that I was thinking about when I made my post, but I didn't remember all the details. Was it the fact that the belt on your first setup went around the crank pulley too that reduced the amount of contact on the A/C enough to cause the squealing? Sounds like the GLWJ triple-groove fan pulley solved your problem, and the setup being proposed on this thread includes a pulley like that.
Tom Ferrin
N6TEF - 2m and 70cm
Old 10-20-08, 07:45 PM   #143
chitown40's Avatar
TLCA# 14424
Yeah, my original setup was ala Lumpdog style. It captured the same pulleys as the a/c compressor belt and also the York. I changed to a separate belt once I got home and also used the GLWJ pulley and it works as designed now.
Tell your son 'Great Job' on the Moab videos. Once I saw them I felt the same pucker factor like I was on Launch Pad again.
TLCA #14424
Old 10-21-08, 12:00 PM   #144
Update. Just got 800lbs. of 1/4" plate delivered today. Pulleys should be done at the first of next week. So I should have the first one done real soon for testing. I will update with pics as I go.
Old 10-21-08, 07:18 PM
