Which fluids to replace before cold weather?
Ok, engine oil and filter without saying.
I've got 132k miles currently bought the 80 with 96k miles on it, and no real records of p/o maintenance but they took it to the dealer for the 60k mile check up. Had a full tune up, and all rubber hose replacement last year, and 4 new brakes/rotors this year. I've replaced the anti freeze last year- the dreaded HG replacement. My focus is drain/flush refill- p/s pump oil- no problems currently brake fluid- " tranny- was flushed 2 years ago at about 90k miles. and both pumpkins- have not done the repack yet. Probably next year. PS I plan to keep this vehicle for ever like everyone else here. ![]() As always, many thanks for any input. __________________ Pat Doyle 1994 White FZJ 80, CDL switch. rear winch hitch attachment .-SOLD 1996 White FZJ 80, seats 7,leathered up, CDL,Locked,LandTanks MAF.2" OME lift/Shocks. |
Lost
Get some of that low temperature windshield washer fluid. Make sure you have primed it all the way through.
__________________ '97 Land Cruiser, Locked, OME J, Metaltech Sliders, Toyo MT 315/75/16, CDL, Kenwood D700, Laptop Mounted, Landtank seat mod. For me. '97 LX450, Landtank seat mod. For my wife Land Cruiser Laptop Setup | Trip Photos | Twitter |
Corn Eater
I don't do jack.
Oil/ filter- that's it. Oh- and the anti-freeze thing is a good idea. __________________ Eric P. 1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW Tall Corn Cruisers- El Presidente. |
Just looking to head the future problems off at the pass... IE, the power steer pump leaks at some point as it did on my 94. You don't think changing the fluid will add life to the pump seals?
Or brake fluid to the brakes? __________________ Pat Doyle 1994 White FZJ 80, CDL switch. rear winch hitch attachment .-SOLD 1996 White FZJ 80, seats 7,leathered up, CDL,Locked,LandTanks MAF.2" OME lift/Shocks. |
Corn Eater
I'm not saying it won't. All I'm sayin' is that I think it's a waste of $$ to do all fluids on a yearly basis.
FWIW, you and I probobly see similar temps in winter and I haven't changed my radiator fluids in about 4 years, or flushed my brakes in 2 years.... __________________ Eric P. 1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW Tall Corn Cruisers- El Presidente. |
Easiest way is to look at the fluids.
If they're dark and nasty, change them. If they're still relatively clean/clear/colored (as appropriate), don't sweat it. __________________ '97 LX450 - The -mobile'96 LX450 - Mine! ![]() Triple locked, 315 General Grabber AT2, OME Medium, 1" body lift, belly skid plate, grey wire mod. Jefferson State Cruisers (A wholely owned subsiderary of OR/CA TACO) Forums |
Both of you have good points. I'm on it...
I don't wheel
Oil's cheaper than an engine.
ATF is cheaper than a tranny. 80W-90 is cheaper than a transfer or diffs. Grease is cheaper than birfs or bearings. Brake fluid is cheaper than hydraulic cylinders. Power steering fluid is cheaper than a PS pump. Coolant is cheaper than an engine or radiator. That said, I change my oil/filter every 3-5k mi. Tranny every 30k mi. PS fluid every 30k mi. Brake fluid whenever I replace rear pads. Coolant (I've been pretty lax on this one) every other spring. Dif/xfer oil every 30k mi. Birfs every 60k mi, (or when they need it, like when they click going straight under no load). __________________ Jonathan M. Rundlett <skadalajara@gmail.com> Copper State Cruisers #001 Member of the Happy Hour Gang and the last true conservative in the U.S. '94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper |
Ok, I'm flushing the power steering and brake fluid, while replacing the a/c condenser ( thanks Dan) and dryer....
Had the oil changed, was running basic oil, the garage changed the oil to Sunoco synthetic blend 5w 30. Can I change it back to plain ole oil now? I didn't want them to do this but they took it upon them selves with out asking. __________________ Pat Doyle 1994 White FZJ 80, CDL switch. rear winch hitch attachment .-SOLD 1996 White FZJ 80, seats 7,leathered up, CDL,Locked,LandTanks MAF.2" OME lift/Shocks. |
#10 |
What tranny fluid you guys recommend? my rig has high mileage and like you guys said before i'm planning to keep it forever!
#11 |
During Summer months, I tend to use more water in the mix (about 75/25), so when Winter rolls by, I'll be flushing again and adding 50/50
![]() I always use alky based washer fluid, so I'm good there... As for the rest, I just make sure they're all topped up and double up on the warming process... |
Job Listing | Loan | Car Credit | Myspace Comments | eBay |
