Old 09-13-08, 08:36 PM   #1
REALLY bad noise....need help!
did a little trail ride in Crested Butte, went through a bouncy mud hole in 4lo and after getting back onto the streets, noticed a really nasty scratching, s****ping, clicking noise at all speed. On or off the gas, in D or N, seems to be not as loud on left hand turn, and my buddy got out and listened and said it was in the rear. Seems the sounds comes "in and out" Quite stumped. Had a wheel bearing replaced 2k ago, had everything lubed and checked. Bad birf, bent tie rod, wheel bearing??? ALSO, it anyone can recommend a mechanic in the area that you would trust to work on your 80, would be greatly appreciated. Thanks for your help guys.
ZangMtns is offline   Reply With Quote
Old 09-13-08, 08:56 PM   #2
IH8MUD Rookie.....forever
Chaldaean's Avatar
Crud stuck in the drum of the e-brake?
1997 LX450 Factory Locks, de-racked, OME 2.5", 285/75 BFG, MetalTech Sliders, Cobra CB, Cup Holder
1988 FJ62 - R.I.Pieces due to frame rust
Chaldaean is online now   Reply With Quote
Old 09-13-08, 09:30 PM   #3
60wag's Avatar
At least pull the wheel off and see if there is something stuck in there maybe scraping the brake rotor. I have no good rec's for Breck but Slee isn't too far away in Golden.
'96 FZJ80
Member Rising Sun Chapter TLCA
KC0ZAC
60wag is offline   Reply With Quote
Old 09-13-08, 09:37 PM   #4
If you are passing through Leadville, Stop at my house?
We can look at it together...
chtucker is offline   Reply With Quote
Old 09-14-08, 01:54 PM   #5
The quick brown fox .....
Beowulf's Avatar
More than likely you have a pebble inside the brake dust shield. You should be able to remove it easily.
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Bad Credit Loan | Unsecured Loans | Remortgages | Mortgage Calculator | Mortgage
