Old 09-13-08, 06:46 PM   #1
AfricanToy's Avatar
Engine Knocking question?
94 LC 1FZ with a distinct knocking sound. The owner has been driving it this way for over 10k miles...how serious is this?
I believe he has a bent rod.... is it possible to replace just the rod or am I in for something major? I know someone that replaced a bearing and rod on a 2F engine and has been driving it for years without problem.
85 FJ 60; 87 FJ 60; 89 FJ62; 92 FJ80; 93 FZJ80
AfricanToy is offline   Reply With Quote
Old 09-14-08, 12:43 AM   #2
I don't wheel
hj60's Avatar
TLCA# 11004
You can replace just the rod and bearings.
Jonathan M. Rundlett <skadalajara@gmail.com>
Copper State Cruisers #001
Member of the Happy Hour Gang and the last true conservative in the U.S.
'94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper
Originally Posted by NLXTACY View Post
Others here can explain that a whole lot better than me but IIRC it had to do with the Vicious Coupler.
hj60 is offline   Reply With Quote
Old 09-14-08, 01:01 PM   #3
AfricanToy's Avatar
Is there any write up on this procedure?
Old 09-14-08, 01:42 PM   #4
The quick brown fox .....
Beowulf's Avatar
IIRC, LX_Treme removed the rods and installed new pistons and bearings with the engine in the vehicle. You should be able to find his thread here in the 80-Section. Do a search for threads started by author=LX_Treme
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Old 09-14-08, 02:13 PM   #5
I don't wheel
hj60's Avatar
TLCA# 11004
Of course, I recommend figgering out why you have a bent rod before doing any repair work. Did the HG fail? Did a cylinder take on water?
The special tools you would need to do the swap are readily available at a parts store. Ring compressor. Plasti-Gauge.
Old 09-14-08, 02:47 PM   #6
AfricanToy's Avatar
"Did the HG fail? Did a cylinder take on water?"
I am not sure...the engine is running fine (except for the knock)
However the radiator just sprang a leak...what should I be looking for regarding HG failure?
Old 09-19-08, 06:42 PM   #7
AfricanToy's Avatar
Fixed the radiator....been told to check compression to see if the rings have gone bad or if there is water in the cylinder? There is no white smoke or any tell tell signs...
Old 09-19-08, 07:05 PM   #8
Tools R Us's Avatar
Why do you believe it's a bent rod? That's not a common problem on the 1FZ.
.... is it possible to replace just the rod or am I in for something major?...
I would classify replacing a rod as major and would recommend determining what is wrong with the motor before taking it apart?
Copper State Cruisers #007
Latest Hollywood Gossip | Loans | Great Place for a T-shirt Quilt | Loans | Credit Expert
