Old 09-08-08, 05:41 PM   #1 (permalink)
NLXTACY's Avatar
TLCA# 19015
HOW TO: POWER DISTRIBUTION Part 4- bring da power
Part 1 of the power distribution install- the aux. fuse panel
Part 2 of the power distribution install- 12 volt outlets
Part 3 of the power distribution install- the inverter install
In part one I showed the aux. fuse panels I added. In part two I showed the usual 12 volt outlet that was added. In part three I showcased my inverter install. In part four now I want to go over what I had to do to bring in power to the center console.
I first needed to start with the dual battery install. I went with the Hellroaring BIC 95150 and also decided to use the Sears rebadged Odyessey. You can see my dual battery install here: http://forum.ih8mud.com/80-series-te...ppearance.html
Basically I decided to run all accessories of the aux. battery instead of running everything off the main. I then covered the battery with an acid absorbing mat and a heat shield.
ふざけんなよ!
Old 09-08-08, 05:43 PM   #2 (permalink)
NLXTACY's Avatar
TLCA# 19015
Now what I needed to do first was pull in enough power, to run ALL my current and future accessories, into the cab. This meant I wanted to go big and risk less by the way of wire resistance and bring in big ole' 1/0 welding cable. The positive side of the cable went through a 250A MegaFuse that I mounted onto the bracket that was discussed previously. From there I routed it around the back of the engine bay and then through the clutch master hole. This was easy enough. Now I needed to decide where to mount my distribution blocks. After starting this thread I decided to just use the standard power posts.
I began by tearing out the entire center console to give myself plenty of room to work around. Removing the seats helps too. It was at this point that I figured the best way to route this garden hose of a battery cable would be to follow the channel that runs alongside the driver's side door sill. Fits right in. I ran it along the sill until I got to the seat bracket. Then I continued to run the cable, under the carpet, along the seat bracket until it popped up where the center console was.
ふざけんなよ!
Old 09-08-08, 05:44 PM   #3 (permalink)
NLXTACY's Avatar
TLCA# 19015
I went ahead and mounted the two power distribution posts that I got from Wrangler Power Products. The mount location chosen was the large flat floor bracket that is under the arm rest console. I used the bent up section of it to mount the posts. This actually made my access to everything much easier than if I mounted on the longer flat section.
I now had an issue. I needed to mount two 80A circuit breakers now and two more later so I needed a large enough piece of flat area to mount them. Turns out I "could" have just mounted them on the flat section of the floor bracket but that really limited the space I had to work with and then trying to maneuver big bulky cables.
ふざけんなよ!
Old 09-08-08, 05:45 PM   #4 (permalink)
NLXTACY's Avatar
TLCA# 19015
It was at this point that I figured out the solution. I now had three bolt holes I am not using because I removed the MID speaker box. Two on top of the bracket that now holds the inverter, and one on the front edge of the floor bracket. This looked like a perfect place to just stick a flat piece of metal with two bends in it. So I went to my local sheet metal shop and $20 later I had a new galvanized bracket. I drilled two holes to match the two in the new inverter bracket and I drilled out the one for the front hole in the floor bracket. well I now needed to clear another bolt sticking up along that bulge so I used a .75" hole drill and cut out a piece for the bolt to go through. NOW everything site flush and even looks like it was meant to be there.
Now I can start thinking about placement of the circuit breakers. It was at this time that I decided that with this much current going though the cab and with the sheer amount of accessories I was eventually going to be adding, that I need to seriously need to consider running a power kill switch. So I got the one from 12voltguy. Now I have it so that the POS cable goes to the power stud. The stud goes to the kill switch, and all pos. power wires goes to the opposite stud on the kill switch.
ふざけんなよ!
Old 09-08-08, 05:46 PM   #5 (permalink)
NLXTACY's Avatar
TLCA# 19015
Now that this was figured out I need to move onto the large cables. I drilled two .75" holes lining up with the power studs. Then attached the 1/0 lugs to see how everything lined up. Perfect. I then took off the new bracket and proceeded to drill out an addition side hole in order to use that as a cable pass thru for all of the outlet and inverter wires that need to pass thru the bracket. I then also needed a way to bring the wires and cables from below the bracket to above the bracket. So I made an oblong hole on the top. I then used .25" vacuum line split in half vertically to use as a protector for all the edges that "could" come in contact with the cables/wires. This was after I used a file to remove all burrs and soften all the edges of the new bracket.
I could now route all of the power wires I needed with all the access holes I just created. Now I needed to bring in the neg. 1/0 cable and I had a nightmare trying to figure out where in the heck I am going to pull in another 1/0 cables as written in this thread: http://forum.ih8mud.com/80-series-te...ge-cables.html
ふざけんなよ!
Old 09-08-08, 05:47 PM   #6 (permalink)
NLXTACY's Avatar
TLCA# 19015
From here I decided to try and get the second 1/0 cable through the same clutch master hole. Problem was I already had a bunch of random wires in there and the first 1/0 cable. So I did what any man here would have done.....
Cue the chika-chika-bow-wow music:
I was at a loss. I have this long thick cable in my hand. solid to the core. I stared at my girl's waiting hole. Baby...there is no way this thing is gonna fit in there. "Sure it will" I could imagine her saying. "Sure it will". I tried forcing my way in. Its just not right. I need to glide it in...softly...gently. The voice in my head breaths another thought..."get your wife's lube". I can't. Thats her favorite lube. And its for her and I. "If you want to get that fat thing in me, you gotta lube up". So I sneak upstairs and palm the lube. "What are you doing!?"
Doh! Its my wife. She wont understand. I've been told to make her first above all others. How can I explain that I need her favorite lube for another.
"Nothing baby, just finishing up the truck for you to be more comfortable!!!"
Success! I make my way down to the garage, I dim the lights.
I go ahead and dab a bit of lube on the tip. "oh that is not enough, look at the size of that thing. You don't want me to tear do you?"
No baby, I hear you. I coat my 1/0 and feel for the opening. My baby moans...I found the spot. I get the tip in. "Push it in, bottom out!"
Oh it didn't take much. All 8ft. of my hard black cable practically fell inside of her.
"See, told you it would fit".
Slut.
ふざけんなよ!
Old 09-08-08, 05:48 PM   #7 (permalink)
NLXTACY's Avatar
TLCA# 19015
At this point I have the loop of neg 1/0 cable laying on the floor of the DS footwell. I didn't think i could run it along the same path as the pos. cable so instead I routed it on TOP of the brake pedal bracket. No moving parts up there. Then routed in under the dash and popped it up under the center console. From there it was nothing to route it to the new hole I had in the new bracket. I used the crimper at this time and crimped the 1/0 lugs to the 1/0 cables and I was golden. Perfect length.
Now on to the kill switch. Where to put it? Well I wanted it hidden put accessible so I decided on drilling a 7/8" hole into the arm rest box and install the kill switch from behind using two screws. Now in order to turn off all power, all you have to do is lift up the arm rest.
ふざけんなよ!
Old 09-08-08, 05:49 PM   #8 (permalink)
NLXTACY's Avatar
TLCA# 19015
Now once everything is buttoned up and put back together I needed a way to attach the pos. cables to the kill switch. I already had them all in place but I cant attach them with the arm rest console removed. So I took off the mesh in the front of the console where the MID speaker box used to be. I carefully trimmed out the speaker grill using a razor blade. I now had easy access into the console which my hand could easy fit inside of and attach the remaining lugs. I could easy install the mesh back. But I am already working on a way to make it MORE easily removable and useful.
I now have a working power distribution system. Something that I can now EASILY tie into if needed. Such as adding the new stereo equipment, the PURE SINE inverter, the rear aux fuse panel, the rear power outlets, the fridge the roof lights, etc etc etc etc.
ふざけんなよ!
Old 09-08-08, 08:16 PM   #9 (permalink)
Ebag333's Avatar
TLCA# 18864
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 09-08-08, 11:54 PM   #10 (permalink)
FJason80's Avatar
TLCA# 17089
Slut.
-NLXTACY
Possible sig material right here.
93 FZJ80 - Locked, ARB front, MileMarker 12k Winch, Kaymar Rear, OME 2.5, 33" MTRs, LightForces, Safari Snorkel, Slee Wiring Harness, etc.
88 Subaru GL Hatchback - Swapped RX turbo engine, Volvo intercooler, fastest P.O.S on the road, rallycross machine.
FJason80 is offline   Reply With Quote
Old 09-09-08, 12:21 AM   #11 (permalink)
NLXTACY's Avatar
TLCA# 19015
HAHAHA, one can only hope
ふざけんなよ!
Old 09-09-08, 02:17 PM   #12 (permalink)
NLXTACY's Avatar
TLCA# 19015
My final install schematic
ふざけんなよ!
Old 09-09-08, 04:32 PM   #13 (permalink)
sandcruiser's Avatar
cost and source on those 80amp breakers?
great install and writeup! Thanks for sharing.
Makes me think I better re-plan my install... it was going to be so..... simple.
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Hankook MT's 31x10.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns.
ask me about Costa Rican Realty
sandcruiser is offline   Reply With Quote
Old 09-09-08, 05:04 PM   #14 (permalink)
NLXTACY's Avatar
TLCA# 19015
Cheapest (with shipping) and most reliable has been Dave's Marine:
Blue Sea Systems 7014 Circuit Breaker 80a
The breaker is Blue Sea Systems 80A #7014
$37.91
ふざけんなよ!
Old 09-23-08, 12:59 AM   #15 (permalink)
NLXTACY's Avatar
TLCA# 19015
Update, the speaker grill for the old mid speaker is now where I will be mounting the speaker for the Yaesu 8800 HAM radio. I HATED the idea of mounting that ugly thing somewhere in the open.
ふざけんなよ!
Old 09-23-08, 09:41 AM   #16 (permalink)
SeanAndHis80's Avatar
TLCA# 19456
I am reading this with great interest as I am doing somewhat the same job right now - or at least gathering the parts at present. The issue I see is something you have not done yet - the large inverter. I am using a Xantrex 1750 Watt inverter - which is specifying no more than 4ft of cable to the battery. It seems to me that routing your 1/0 cable from the front of the truck then around the driver seat is going to easily exceed that.
...and one more note on running an inverter that big - it will require at least 110 amp hours out of your system. This is more than the typical deep cycle cell will provide so you will either have to use a battery bank (2 or more batteries) or run the juice through the isolator as well as the battery to deliver the needed power. Currently I am looking at using two sistered batteries as my second battery as i do not want the truck to need to be running to extract 1650 Watts (my target) from the system.
Don't get me wrong - you have given an awesome writeup and done a great job so far!
97 40th lockersx3, Yellow top & Diehard PM-2. Pin7 mod, Georges LEDs & others, Revos, heated mirrors, massive inverter project underway. P0401 fixed. Currently at 180K+. more to come...
87 Supra Turbo - stock, 5-speed, targa roof, midnight blue. Currently at 125K+.
SeanAndHis80 is offline   Reply With Quote
Old 09-23-08, 10:15 AM   #17 (permalink)
NLXTACY's Avatar
TLCA# 19015
Hey SEAN, I wont be going 1750W with my inverter. My system is just not spec'd to go that high. Also, even at 1000W I would very rarely be using half of it for even an hour or so at a time. There is no way I would use it to full potential. If you are sporting a 1750W then you have some serious plans.
I have not had available time to do the inverter install but I will be doing a write up for that as well.
ふざけんなよ!
Old 09-25-08, 04:04 PM   #18 (permalink)
pardon my ignorance, but for what do you want 1750w of power?
I mean.... you can run this fridge on 1750 watts. That's a full-size GE 48" 30 cu. ft. fridge.
Old 09-25-08, 04:46 PM   #19 (permalink)
NLXTACY's Avatar
TLCA# 19015
I was kinda wondering the same thing.
ふざけんなよ!
Old 09-25-08, 06:13 PM   #20 (permalink)
TLCA# 19456
I am building a cabin off of the grid. The power is going to be used first for construction and later for power to the cabin.
Out of the tools needed, my circular saw is rated at 1650 Watts. This is the max power target. According to the charts I can get around a third of an hour with 105Ah worth of battery feeding it. It doesn't sound like much - but 20 minutes of cutting time will probably last most days w/o needing to start and recharge. We have a lot of cordless tools but the saws drain the batteries too fast to be practical.
Once it is a cabin - no I won't be running the fridge on it. The fridge, stove and most of the lights are propane, heat is by woodstove. I will have a stereo and a few lights to run off of it in a pinch - I suspect all @12V. I will plug it in when I get up there like a camper plugs into service at a camp.
I originally wanted to go solar, but found it prohibitively expensive. I have a generator but it is loud and annoying. This method seemed to have a bunch of upsides with a bit of expense but not as much as solar panels. With this I will always have power with me wherever I am camping or tailgating etc...
Old 09-25-08, 06:19 PM   #21 (permalink)
NLXTACY's Avatar
TLCA# 19015
I am actually in the middle of spec'ing out a solar solution for my 80. Once I get my INTI rack (from whatever source) I will be mounting slider rails under the rack and the solar panel will basically act as a pull out "drawer". The panel will be locked in place until I am stopped at a campsite and I unlock it and pull it out to cover the front windshield from the sun and thus allowing the solar panel to start working.
After sourcing a panel that is adequate and a solar controller and all the necessary wiring and such, I will still be well under the cost of a 2000W Xantex ProSine inverter. I had wanted to have it ready before this summer but I will instead have it ready for my Spring camping season
ふざけんなよ!
Old 10-01-08, 02:35 PM   #22 (permalink)
Interesting ideas. For me, the fear of flattening my batteries and leaving me stranded at the cabin would push me towards a different solution.
For construction, I think you'll find that a generator is a better solution. Just figure the cost of killing deep cycle batteries, compared the cost of buying and fueling a little generator. Because in my experience, a single deep cycle battery isn't going to survive the abuse that you described and a good deep cycle battery is going to cost you more than $100.
Less than $400 for a propane powered generator:
Generac GP Portable Generator — 2050 Watts, Model# 5723-0 | 1,000 - 4,999 Watts | Northern Tool + Equipment
Get a small charger and leave a deep-cycle battery at the site, that way you can run lights/music at night when the place is done, but still have enough ooomph to run tools and/or recharge all of your batteries. Better long-term solution than using your vehicle to power your home, in my opinion. You can always add batteries and/or renewable charging solutions to the mix, but having a generator around is a pretty convenient thing in an off-grid application.
Some generators also work as a compressor. Could be a nice feature if you need to wrench on the truck, at the cabin.
Old 10-01-08, 02:41 PM   #23 (permalink)
NLXTACY's Avatar
TLCA# 19015
x2 ...
ふざけんなよ!
Old 10-01-08, 03:07 PM   #24 (permalink)
TLCA# 19456
sandcruiser - I would guess that your comment is directed at me. First of all - only one battery is going to be on the circuit with the inverter not both. The secondary benefit here is that if I do drain my primary battery I will have a second one I can start the truck with which has always concerned me while at camp. This especially after all the horror stories floating around the web about my Optima Yellow Top. I can also easily take my electricity on the road to other camps, tailgates etc...
At camp I already have a generator that I do not like using. It is obnoxiously loud and reminds me of the early days of the internet - where I would think of everything I had to do online before dialing in. Likewise stacking up ten cuts before firing up the generator is no fun.
This is NOT a home but simply a camp where, if I am lucky, I spend about two weeks and a half dozen weekends at per year. If it were more permanent I would consider a solar setup. Solar would require a lot of trees to fall and maintenance particularly in Vermont's snowy months.
The Sears Diehard Platinum Marine battery will run me about $250, the inverter was $200, the tray and hardware was somewhere around um, I think $100. The wiring seems to be in the $100-$200 range. All said it should run in the $800 range. It is not the cheapest solution - but one I am very comfortable with all of the ups and downs of. As for longevity of the battery, the inverter cuts out at 10.7 Volts, the battery is rated for something like 5000 charges at that depletion level.
BTW: The $400 generator you posted is gasoline - they do have an LP one for about $500.
For wrenching the truck at the cabin my neighbor has a barn and a great set of tools that can fix anything (I think he is a TV repairman.)
