09-07-08, 11:54 PM
my lx450 seems to burn oil. Suggestions?
It seems to burn quite a bit. It's got about 160k.
Does it need rings?
Is that super hard to do? I've pulled the motor on my old 89 toyota truck a few times, replaced it's headgasket, rebuilt the rear end, and rebuilt most of the tranny, so I'm fairly competent mechanically . . . .
09-08-08, 12:46 AM
Er is it actually burning oil? Could it possibly be leaking oil instead?
ふざけんなよ!
09-08-08, 01:00 AM
How rapidly is it losing oil (burning or leaking)? Mine eats about a quart every 4k miles or so, and I know a few other members' rigs do as well.
'97 Lexus LX450 - CDL/7 Pin | Factory cup holder | Black LX wheels | 305/70 Toyo M/T | Optima Redtop | Auto-Up mod | George's LEDs | 1.5" Spacers |
09-08-08, 01:39 AM
I've been lucky. I go through half a quart every 6-7k.
But you NEED to verify if it comes from a leak before you start linking about tearing anything apart.
ふざけんなよ!
09-08-08, 02:53 AM
Synthetic or conventional? Try some Shell Rotella 15/40 and a Wix filter. I swear by this combo and run it in everything I own. If this oil "disappears" I would say you might have a ring problem. If it doesn't smoke any, who cares, just keep topping it off. Beats the hell out of the price of a rebuild.
`97 LX, locked, BFG's, OME, ARB, 4X4Labs rear, and some sliders.
`91 FJ80, grocery getter/wife's, (Sold)
`90 3VZE Turbo, SAS 4Run, (Sold)
`88 Turbo FJ62, (Sold)
`73 FJ40, (Sold)
09-08-08, 06:43 AM
It leaks some, but not enough to drip onto the ground.
I'm using mobil 1 synthetic 10w30
09-08-08, 09:59 AM
I am using this same oil as well. You might want to try the High Mileage variant of M1 10w-30 or try a XW-40 weight oil.
Good luck.
96' FZJ80 - Moonglow/Grey Interior, ARB Bull Bar, OME 850/860, Slee Blue Bushings, 285/75/16 Nitto's, Speedo Gear, CDL, Hella 500 Fogs, Toshiba HIR's, Silicone PHH - Baselined
- Purchased from original owner @ 77K-(12/04)
04' WRX, Modified - 292HP/319LB-FT
"Phil 4:3-8"
09-08-08, 05:13 PM
My 1994 did not like the Mobile1 you are using. I switched to the Rotella mentioned previously and all was well.
1981 BJ42
1994 FZJ80 ROTW
1997 FZJ80 40th Anniversary
Victimized by CDan
Court photographer for HRH The Shaman
Honi Soit Qui Mal Y Pense
09-08-08, 05:49 PM
I've tried all the above, but when it burns, time for ring job. I just don't see any liquid at this point will help. Mine was burning at 150K.
 where are you hurting?
09-09-08, 04:25 PM
#10 (permalink)
Oil Burning
Are you doing your own oil changes? Make sure your shop knows these vehicles take 7 quarts. My oil light came on and after I stopped panicing, I looked at my last receipt and realized I was only charged for five quarts of oil. My LX still burns about a quart between changes. Five quarts minus another quart give or take plus a slight incline put the light on. Food for thought.
1997 LX450
09-09-08, 05:45 PM
#11 (permalink)
Mine "used" more oil with M1 10W-30 too. I am in Texas and switched to 15W-50. Consumption is lower, maybe a quart per 3k mi.
My indy worked at the Lexus dealership, maintained a lot of LX450s and said many trucks used oil even when new. Not to worry too much.
I would definitely do some analysis with the different oils and viscosities before declaring it needs serious work.
Robert Callaway
'03 LX470 52k mi. - The Smooth Ride
'94 FZJ80 212k mi. - Locked, OME 861/862, less the OE roof rack, add a D31M
'85 FJ60 - Sold
09-09-08, 08:01 PM
#12 (permalink)
I switched to the M1 High Mileage and my oil consumption went down significantly. I now go through a quart every 3-4K
1997 LX450 Green! with lockers
09-09-08, 08:46 PM
#13 (permalink)
The P.O. of our LX had a complete engine rebuild done at the Lexus dealership at 138K for "excessive oil consumption" to the tune of nearly $4K. It doesn't seem to use any now at 170K.
-Eric
64 FJ40, slightly modified.
96 LX450, locked.
09-09-08, 09:10 PM
#14 (permalink)
THIS THREAD IS WORTHLESS WITHOUT KNOWING HOW MUCH OIL IT'S CONSUMING PER 1K MILES!!!
Jebus you guys...
02-20-09, 11:42 AM
#15 (permalink)
Was synthetic. Mobile 1 10w 30
Just bought the high mileage mobile 1 10w30.
I must not have had my email notifications set up correctly. I just saw this had been replied to.
It uses about 1 qt every 750 - 1000 miles.
Not dripping at all. Period. I fixed all the leaks. (except rear seal, which does not drip on ground/concrete)
1996 LX450: Temp Gauge Mod, 2.5 Iron Man, Rear AirLift - My Work Truck
02-20-09, 12:41 PM
#16 (permalink)
Odd
Mine takes 8 and the low level light comes on at 7
02-20-09, 01:46 PM
#17 (permalink)
If you're using a quart every 1k I would not do a thing to it.
Is this an easy motor to rebuild? Sure...aren't they all? But you'd be kidding yourself if you thought you could get to a point where it uses little to no oil.
'97 LX-450-TRD Supercharger sitting on the garage floor...moved it to the basement! Gotta get to work on that I/C and hood scoop!
'87 FJ60, 350, NV4500, EFI, SOLD July '08, Happily hitting trails in S/W Colorado now!
'96 civic EX 4DR 5SP 30+ mpg all day long!
02-20-09, 01:53 PM
#18 (permalink)
On the Golf Course!
Jebus you guys...
Thank You!! Same thoughts reading thru this.
Are you seeing white/bluish smoke? How much oil are you going thru?
I need to put in 1 qt between 5K oil changes. Using dino Penzoil high mileage stuff - factory recommended weight. Truck has almost 193K now.
Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; BFG MT KM2 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!
TLCA Member #13420; KI6SGO
02-20-09, 01:58 PM
#19 (permalink)
See post #15 (in which he revived the thread).
02-20-09, 02:07 PM
#20 (permalink)
On the Golf Course!
thx - I was skimming! That does seem a little excessive, even though Yota does consider 1 qt/1000 miles normal and ok.
Brent
02-20-09, 02:26 PM
#21 (permalink)
Rookie
had simular consumption changed to NAPA 10/40 now it seems to be 1quart every 2/3k.
02-20-09, 05:45 PM
#22 (permalink)
I was "disappearing" about 1 quart every 800 miles using 5w-30. I changed to 0w-40 and now I only use about a quart every 1300 miles.
1995 80 230,000 miles. stock
I named her Miss Kitty because
she's big and red and I bought her
in Dodge City.
02-20-09, 09:33 PM
#23 (permalink)
OK.
I'm not as thourough as I should be. I know that it burn enough oil that i don't feel an oil change is really necessary. In the 6 - 8 months that Ive owned it I've put 2 - 3 5-gallon oil containers through it.
I should be more anal, but I haven't reached that plateau yet.
I'm more of a fixer than a maintainer, so I want to fix it so I don't need to worry about it for a while. I'm sure that is irresponsible, but that's me.
Pretty sure I'll drive 1000 miles in the next week or so. Perhaps tomorrow I'll top it off (again) and check to see how much it burns during the next week.
I relegiously write down mileage so maybe I can add an OIL column.
02-20-09, 09:34 PM
#24 (permalink)
btw it burns hella tons of white smoke at start-up, I mean a sh!+ ton. Its embarrasing
02-20-09, 11:02 PM
#25 (permalink)
White smoke at startup is either normal cold morning condensation or coolant. Oil burning on startup is blueish grey.
DougM
02-21-09, 07:44 AM
#26 (permalink)
Mine used to burn through 3-4 quarts every 1500 miles. Toyota wanted to rebuild at $4000, local shop replaced front and rear seals and I haven't had any problems yet. Started at 165,000 miles, now at 199,900.
02-22-09, 11:06 AM
#27 (permalink)
When you say a shit ton of white smoke...do you mean like Rally-X style, that you cannot even see the truck if the wind is right? Or just a little puff...or like you are James Bond and you just hit the smoke screen button on your latest spy vehicle?
Maybe a picture could better capture this?
02-22-09, 11:15 AM
#28 (permalink)
The quick brown fox .....
If you drive an average of 1,500 mi each month, that would be 12k miles. 2.5x5gallons = 12+ gallons = approximately 50 qts. which would be 1qt every 250 miles.
If you are giving us correct information then you have a major oil consumption problem that needs to be repaired soon.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
02-22-09, 02:00 PM
#29 (permalink)
Major screw up on my part . . . I meant 5qt containers, not 5 gallon. So lets say 15 - 20 qts.
From 6/21/08 - 2/21/09 I drove the car exactly 18,846 miles. At 15 quarts, thats 1 qt every 1256 miles. At 20 qts, thats 1 qt every 942 miles.
I guess that's not so bad. However, I'd prefer it if it burned zero oil.
02-22-09, 11:35 PM
#30 (permalink)
Check your PCV valve and hoses
From my recent experience...Check your PCV valve and hoses.
I had a bad PCV valve and my LC was burning 5 qts per 500 miles! Thought I needed a new engine. Changed it out and now it hasnt lost any measurable amount of oil over the past 500 miles but I am still monitoring it.
How is the compression? I ran both a leakdown test and compression test. This ruled out any internal problems w/ rings or valves.
1997 FZJ80 163k, unlocked, in the process of being baselined...
