Old 08-17-08, 04:02 PM   #1
decavo's Avatar
pully dohickey thingy what is it ??
on a 3FE engine beside the a\c comp there is a roller? the a/c belt ride just on top of it there is no grove for the belt it just sits ther what is it's function? should this be spinning with the engine running? Mine is not and I have this rubbing noise up front. I am thinking this is the culprit. It make more noise with the truck around 1700 to 2000 rpm and when I leave my foot off the accel the noise stops.
I have checked the wheel bearing and repacked them. Nothing in there leads me think there is a problem there. Calipers and rotors look O.K. Even had a mech look at these parts so I feel they are O.K.
thanks D
91 running 33 bfg's hillbilly roof rack,air lockers,Tube bumper,hurcilined,
http://www.flickr.com/people/desert_adventures/
I don't give a damn for a man that can only spell a word one way.
decavo's custom jewelry ,vegan soaps, fragrance oils,lip balm, lotions all natural products
decavo is offline   Reply With Quote
Old 08-17-08, 04:27 PM   #2
The Pea's Avatar
decavo,
are you referering to the A/C idler pulley? If so, check if everything is alligned proper and flush. Quick optical check from on top should suffice. If the bearing is dry it would make a screeching sound at or above certain RPM. Sprinkle some water on the belts and see if that makes it go away or lessens the noise. Worth a try
1991 VX Ltd HDJ 81 with Kid Seat, working e-Lockers, Icemaker + Seatheater and Sugarcane Train Horn
And soon: Nissan Cedric Brougham VIP "For The Bling In Your Life"
The Pea is offline   Reply With Quote
Old 08-17-08, 05:15 PM   #3
CJF
Is it seized, or can you spin it easily by hand?
CJF is online now   Reply With Quote
Old 08-17-08, 05:22 PM   #4
CJF
Just went and checked on my own rig out of curiousity and the d*mn thing's pretty much seized up!
VERY hard to rotate by hand, even with the belt pulled away from it.
Curtis
Old 08-17-08, 05:25 PM   #5
jonheld's Avatar
TLCA# 5980
That's the AC idler pulley. When the compressor kicks on you'll see the belt ride on that pulley. With the engine running and AC off, it JUST misses the roller.
Jon Held
1991 FJ80 "Lumbering White Rhino"
Times Square, New York, USA
TLCA# 5980
http://gclcny.com/jh/
Buy your FJ80 FSM here:
http://gclcny.com/jh/fsm.html
jonheld is offline   Reply With Quote
Old 08-17-08, 05:54 PM   #6
decavo's Avatar
yhe idler will spin but barely. it only squels at certain rpm . I need to listen when the a/c is on for the noise. with the windows down..
Old 08-17-08, 06:34 PM   #7
CJF
the idler will spin but barely.
Pretty sure that's NOT ok. Group buy??
Curtis
Old 08-17-08, 09:49 PM   #8
decavo's Avatar
need to see what dan is charging
Old 08-17-08, 10:01 PM   #9
The Proton's Avatar
Mine's been missing since I bought the truck, with no ill effects. That being said, I assume Toyota put it there for some reason, so I would be interested.
'94 TLC w/OME hvy, snorkel, hanna sliders, kaymar rack, etc, etc.
The Proton is offline   Reply With Quote
Quick Collect | Mobile Phone | Reggaeton Videos | Loans | Debt Help
