Turbo Spark Plug Selections: Some Hopefully Helpful Hints
Fine folks, I stumbled onto something that will hopefully help others. I know that Air Power Systems ( aka Safari Turbo Systems for 4x4 vehicles) recommends NGK spark plug part number BCPR7ES-11's for several of their offerings for Toyota Turbo Systems (Land Cruiser & Supra).
This BCPR7ES-11 is a 14 mm plug (the B), with 5/8 hex (the CP), resistor plug (the R), in a 7 heat range (the 7 which only represents one heat range colder than the stock setup for forced induction), standard 2.5mm diameter center electrode (ES), gapped to 1.1mm (the -11). To put this plug in, the gap should get reset at least as low as .8mm ( aka .0315inches) which represents the stock plug setting and ideally it should be set approximately .004inches or .1mms smaller for every additional 50HP produced over the stock engine setup according to NGK and also according to most tuners out there. Now, NGK recommends that their plugs get gapped "larger or smaller by no more than .008inches or .2mm's" soooo what that means is that taking the BCPR7ES-11 to the recommended .0315inches or .8mm's is technically slightly too much (.004inches and .1 mm too far - prolly no problem) AND what that also means is that taking them to the .6mm or so suggested by the power produced from the turbos that are out there is really too far for these plugs (still prolly no serious problem). Will it cause catastrophic failure, no absolutely not, but is it ideal, no because it basically misaligns the electrodes. So, it turns out that NGK now makes the BCPR7ES without the -11 as a suffix for the plug's part number and it turns out that the "BCPR7ES" is pre-gapped at exactly .0315inches or .8mm! So whether one wants to install them at that gap and rely on the power of our stock ignition systems to still spark the gap, OR, one wants to regap them to the .7 or .6 or whatever they think based on the power their system makes, it is now much more within the range of the plug. As far as I know the stock ignition system is plenty powerful to spark the gap of .8mm (i've never had a misfire code if that really represents anything) and as I recently accidentally acknowledged when I dropped a set of -11's in and forget to re-gap them to the .8mm's I usually use, the stock ignition system can still spark the gap of 1.1mm's although I think that is costing some power if that is possible without causing an actual misfire? In any event, it seems that the "BCPR7ES" is more ideally gapped as a starting point or as an ending point for force inducted 1FZFE's. Again, just in the hope it helps others here. ![]() ![]()
__________________ 97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, LandTank MAF, 3" Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 8.5psi and climbing, My Rocky Mountain Mojo Mobile! Last edited by turbocruiser; 08-16-08 at 10:22 PM. |
Parts Shaman (per Romer)
Why not just use the OEM Denso Turbo MR2 plug, 90919-01180-83.
Platinum, one heat range colder than stock and already gapped at .8mm.....
__________________ Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock and a lumpy old Dodge car.
#3 | |
__________________ 97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, LandTank MAF, 3" Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 8.5psi and climbing, My Rocky Mountain Mojo Mobile! |
That plug is already at the proper 1FZ gap.
Regarding the selection of platinum you may be interested to know that in all of Toyota's factory forced induction engine families, the turbo MR2, supercharged MR2, supercharged Preva, turbo Supra and the turbo Alltrac Celica, Toyota uses a platinum plug that is one heat range colder than the naturally aspirated version of that engine. __________________ Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock and a lumpy old Dodge car.
#5 | |
![]() easy now...... __________________ '93 FJ80; stock, locked, 7PIN, CDL button, 255/85 BFG MT's TLCA# 19103 '71 FJ55- donated mid V8 swap to a 4x4 shop to move ![]() '78 FJ40- rust bucket, parted to the '55 '84 FJ60- sold to buy Heep Liberty CRD. dumb@$$http://forum.ih8mud.com/ca-jefferson-state-cruisers/ |
no insinuation,
![]() you two have a LOT of experience/posts; obviously have your opinions, I just saw the time stamps and thought things could get fugly. maybe it's a turbo Vs. super-charger grudge match . At any rate, both of you guys are way over my head, I bet your helpful hints will steer someone in the right direction. I'll go lurk somewhere else....
#9 | |
). I was simply sharing something I recently stumbled on that should save some trouble for folks using a turbocharger (neither Dan nor I even mentioned the S word ). Dan understandably has a thing for OEM parts all around and so do I but there are some select things he and I advise going aftermarket on. For me, but not for Dan, spark plugs are obviously one of those things and believe it or not there are times when Dan will actually advise aftermarket alternatives (steering stabilizers for example) for folks. No big whup whatsoever at least as far as I'm concerned and again I'm sorry if by written word or by the rapid timestamps it seemed sort of . One thing that really sways my mind is that much of, and prolly most of, the racer world and the tuner world actually avoid platinums for several specific reasons. For whatever reasons APS/Safari is REALLY against advising people to use them and while its written into their literature a little (piqued my curiousity), if you give em a call and chance to communicate their feelings they will REALLY advise against them. So for me the choice to follow their advice was absolutely easy and NOW the ability to follow their advice while not re-gapping the plugs past what NGK says they should be gapped to is a really cool thing that I thought I'd share with the fine folks here who may want to know. That's all, that's really all. ![]() Lastly, both my combined post count here on MUD and my overall experience/expertise count "here in life" should be looked at with a 1/99 ratio; for every one thing that I've taught to others, they, and especially Dan, have taught me 99 times more! So, many thanks for that!
#10 |
Not a chance.
Besides I'm still trying to get him to come over to my place to give my truck a proper wash and wax. I don't do a good-enough job.....
#11 | |
![]() ![]() Dan, my friend, I keep hinting and hinting, its not you keeping me away, its yer cheap ass beer! ![]() ![]() ![]()
#12 |
DAMMIT!
Fat Tire? __________________ Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock and a lumpy old Dodge car.
#13 |
#14 |
If you head out now you should be here by ~3 pm. It'll be cold by then...
#15 | |
#16 |
I knew it was a forced induction issue
![]() ![]() ![]() you guys are all right, I hope to approach a 1:999 ratio for a beginning here, I can't give much advice yet, but I am close to learning my 999th thing, so I bet i help someone soon. have a good week fellas,
#17 |
ThinkTank Waterboy
why don't you two take the love to someplace more appropriate...like a rest stop!
__________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
#18 |
![]() If it means anything I have not stayed at his place....
#19 | |
#20 |
OL' MUDD DOG
I think I've just been reading under the sheets!
I'm getting a lil scared here guys, seems to me you guys are closet something or other here ....and I'm starting to get scared!..
![]() Joeb.
#21 | |||||
ah the simple
factor of mudQuote:
![]() Quote:
)Quote:
now thats a good one.... nice info TURBO .............................but i still use the MR2 plugs
__________________ 95 FZJ-80 Lifted, Locked, armored,37'd, blown and bigelow enhanced ; single digit MPG wondermobile 72 FJ-55 IPOR bumpers/sliders, SOA, 3'' BL, 8274, and a big ole F'n engine, 35' (for sale) 92 P/U stock, lil lady owned, gas miser/DD/worker aka tiny tim |
