Old 08-03-08, 02:05 PM   #1
Blue Phoenix's Avatar
TLCA# 18336
Rear Locker
Before anyone flames, I checked in the FAQ and used the Search to try and help me with this, but I saw nothing like what led to my rear locker locking and not disengaging. Heres the story:
Shortly after leaving for a camping trip up 24 through Manitou Springs (those of you who have driven it know its about a 6% grade), I pushed the POWER button with Overdrive turned off, and I see my Rear Locker indicator light come on. No flashing like usual, it just came on and stayed on.
I stopped to check it out and could find nothing wrong in my ignorance, and kept driving on since it wasnt behaving as if it was locked. I know I know, not a good idea.
Now before anyone starts thinking I snapped or broke something, I am sorry to disappoint, but nothing broken.
We kept driving and I noticed that when I accelerated hard (around 3K RPM) uphill, it would start flickering, not blinking, flickering and would sort of go dim.
Later on, on the trail, I really wanted to see what was going on so I did some tight turns, and yes it was for sure locked and showing no intention of trying to unlock.
My front locker works fine and when engaging both, the rear goes dim while the front is locking and then lights up.
This continued on our way home, with the flickering uphill and turning off briefly, and then coming on again and staying on.
Does ANYBODY know whats going on and how I should trouble shoot this. I have the day off tomorrow and I see myself trying to get to the root of this.
Again, soory this is so long and thank you in advance for all the help. Pictures would be helpful in any info you guys may give too.
I kept dr
1997 LX 450, OEM Lockers
2003 VeeDub Jetta 1.8T (The Wifeys)
A_Soldiers_Diary
Blue Phoenix is offline   Reply With Quote
Old 08-03-08, 02:30 PM   #2
-Spike-'s Avatar
Some very odd behavior here. Does your truck normally engage the rear locker when you push the 'power' (I assume thats the button on the center console, not on the dash) button?
-Spike
His 1994 TLC 'White Elephant' +6"/35" Locked and loaded.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
-Spike- is offline   Reply With Quote
Old 08-03-08, 02:44 PM   #3
TLCA# 18336
Never, all its suppoed to do is remap the engine for shifts at higher RPMs and quicker shifts. Maybe this is a feature no one knew about?
A_Soldiers_Diary
Old 08-03-08, 02:46 PM   #4
-Spike-'s Avatar
I doubt that. Sounds like you have a short somewhere. Driving with the rear locker engaged wouldn't bother me, but having it lock in that manner would force me to check it out immediately.
-Spike
Old 08-03-08, 02:50 PM   #5
TLCA# 18336
Either that or I hit the actuator or something around it when I removed the rest of my exhaust pipe?
A_Soldiers_Diary
Old 08-03-08, 02:52 PM   #6
-Spike-'s Avatar
Why would it engage when you hit the 'power' button? The two systems should be completely independant.
-Spike
Old 08-03-08, 04:20 PM   #7
-Spike-'s Avatar
Did you remove/break any ground wires?
-Spike
Old 08-03-08, 04:28 PM   #8
TLCA# 18336
I glanced, but havent gone in depth. The exhaust routes next to the actuator I think and MAYBE I hit it. But like you said, two completely different systems. I'll be spending some quality time under her tomorrow, so hopefully I'll find some indicator of what's wrong. Honestly, though, I dont know what I am looking for.
A_Soldiers_Diary
Old 08-03-08, 05:01 PM   #9
The quick brown fox .....
Beowulf's Avatar
Simple, you are looking for a wiring problem with the rear actuator. You didn't say one way or the other but I am guessing the rear locker light did not go off when you turned off the "Power" button, correct? Otherwise, you would have turned it off and left it off for the drive home.
Driving in a straight line with the rear locked isn't terrible but you will not be a happy camper around town and getting into tight parking places. There is a procedure to use a 9v battery and unlock the actuator if you cannot find the wiring problem fairly quickly. I don't have it handy but search for 9v and actuator or locker (80-section only) and you should turn it up. (You will have to use 9V* in the search)
Since you were working in the area of the rear actuator and not in the dash then I would start there though the logical place would be under the center console area where the POWER button is located.
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Old 08-03-08, 05:18 PM   #10
TLCA# 18336
The two systems are stand alone though, correct? I quickly turned off the POWER button after it indicated the locker was engaged, but even after turning it on and off and trying everything I knew how to do, nothing worked. I will look into the 9V, but is that just a quick fix? I just really hate shops and hope this doesnt lead me to them.
A_Soldiers_Diary
Old 08-03-08, 05:37 PM   #11
-Spike-'s Avatar
Doesn't suprise me at all that the locker didn't disengage when you turned off the 'power' button. The locker circuit involves an ECU and multiple contacts and electrical paths in the actuator itself. When power is applied to the actuator to engage the locker, it turns a motor which loads a spring which moves the arm that locks the diff. When the motor turns to a certain point, a contact is made that tells the ECU that the spring is loaded- and then the ECU shuts off the power to the motor. Another contact is made when the arm actually moves, which tells the ECU to turn the indicator light 'solid'. To disengage, the ECU sends power on a different wire to reverse the motor, unload the spring, and allow the arm to move back to its unlocked position. Without power to that wire, the locker will never disengage.
So, somehow you had power on the wire that actuated the locker, or you had some weird ground situation that caused the locker to engage. I would expect that if there wasn't still power to that wire, turning the locker switch on and off would unlock the locker, but anything's possible since we don't know where the power came from to lock it in the first place. It might be that the power is still applied- which would be bad, and is why I'd figure it out before driving the vehicle, or even leaving the key on.
Just to scare you a little more, your locker is probably not fully engaged, as evidenced by the flickering dash light. The actuator arm is probably not quite in the right place to indicate 'locked'. I'd not like to find out what happens when it engages or disengages under power on pavement in a turn. Probably could get ugly.
-Spike
Old 08-03-08, 05:47 PM   #12
-Spike-'s Avatar
Another possible scenario is that the locker actuation was not caused by a short, but rather by a hard shift, or by nothing at all. That would indicate a problem with the spring/arm in the actuator itself. Maybe it's just floating around, and it was a coincidence that the dash indicator came on when you hit the 'power' button.
-Spike
Old 08-03-08, 06:32 PM   #13
TLCA# 18336
HAHAHA....Yeah as soon as it happened my 80s life flashed before my eyes. I figure this is going to take more than tomorrow to figure out. My biggest fear is that it is in limbo between being fully engaged and not, so, we'll see what happens. I am planning on disassembling the entire actuator unit tomorrow. UGH.
A_Soldiers_Diary
Old 08-03-08, 06:43 PM   #14
TLCA# 18336
Does anyone have a link or an actual picture of the actuator unit? Also, where should I follow along the wires to see if I have a good ground and no other issues? My FSM should have come in the mail by now, and not a day too late, so I'll see what I can find in that.
A_Soldiers_Diary
Old 08-03-08, 07:19 PM   #15
tblume's Avatar
PM sent..
'93 FJ80; stock, locked, 7PIN, CDL button, 255/85 BFG MT's TLCA# 19103
'71 FJ55- donated mid V8 swap to a 4x4 shop to move
'78 FJ40- rust bucket, parted to the '55
'84 FJ60- sold to buy Heep Liberty CRD. dumb@$$
http://forum.ih8mud.com/ca-jefferson-state-cruisers/
tblume is offline   Reply With Quote
Old 08-03-08, 07:45 PM   #16
Beowulf's Avatar
Start simple! Check the wiring!
There are posts here in the 80-Section containing the schematics of the diff lock system. This is in the EWD which will not be part of the FSM unless you also purchased that manual. (You should) There is also a section in the NCF that discusses the theory of operation of the diff-lock system.
-B-
Old 08-03-08, 07:50 PM   #17
TLCA# 18336
I'll start with the wiring....What areas do I need to look at?
Sorry...My mechanical know how is stuck in the engine bay.
A_Soldiers_Diary
Old 08-03-08, 07:51 PM   #18
Beowulf's Avatar
The two systems are stand alone though, correct? I will look into the 9V, but is that just a quick fix?
The transmission "Pwr" switch/system and the diff-lock switch/system are not related though it is possible they may share something in the EWD. I wouldn't think so but it is possible. tblume will take care of you there.
The 9v "fix" is to get your rear actuator unlocked. It is a quick fix so you can drive around town and work on getting the problem diagnosed and fixed.
-B-
Old 08-03-08, 08:17 PM   #19
tblume's Avatar
Cool
a thought here; could the actuator be gummed up keeping the splines engaged and the light is lit (sometimes, almost) showing the motor trying once in a while at 12V? if so 9V will prolly not help. I popped the cap of my rear actuator and it was really easy; can manually moving the linkage in there while a helper rolls the wheels around pop it loose? I'm thinking a bit more oomph than the spring can give might be the ticket.
thanks Beowulf for the .pdf last month, it's making it's rounds and helping us new guys more than once, you're the man.
Old 08-03-08, 09:23 PM   #20
TLCA# 18336
Thanks to all of you guys...Beowulf has got the ticket. Right now all I am concerned about is getting it out of the rest of the linkage to prevent any damage as this is my DD. One thing I thought of too, could this at all be related to Diff lube, or the lack thereof? It wont hurt to change it. Thanks again
A_Soldiers_Diary
Old 08-03-08, 09:33 PM   #21
Kneel for the Shaman
Romer's Avatar
TLCA# 13968
Take a look at this thread. Post #5 tells you how to disengage wiith a screw driver while you figure it out.
http://forum.ih8mud.com/80-series-te...ed-locker.html
Probably some mechanics hanging around at the ralley
BTW, you can do Red Cone with an Open 80
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline   Reply With Quote
Old 08-03-08, 09:34 PM   #22
TLCA# 18336
So, tools needed:
ME, the biggest tool
9v and 12v (just in case) Batteries
Ohm meter?
and I guess regular hand tools from what Ive read.
Sorry for being so needy, I just dont like stopping midway realizing I have to go to the Auto shop to pick something up.
A_Soldiers_Diary
Old 08-03-08, 09:37 PM   #23
TLCA# 18336
Thanks for the boost of confidence on Red Cone Romer, I was waiting for a comment from you on this. I'll be using every bit of info thats thrown at me.
I should have mentioned before, this happened on a trip to Kenosha Pass area- did Georgia Pass and Glacier Ridge side trails along with Middle Fork Swan River and Webster Pass if my memory serves me right. Fun trip and thank goodness nothing broke!
A_Soldiers_Diary
Old 08-03-08, 09:43 PM   #24
Romer's Avatar
TLCA# 13968
Sarahs Truck had a different problem where the locker would engage ok, but then would not dis-engage until it was driven on for a while. We took it apart back in camp and the spring and actuator where installed incorrectly.
Have you tried engage and disengae with the locker switch and have someone stand there to see if they hear anything?
Id get it unlocked and take your time isolating the problem
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Old 08-03-08, 10:07 PM   #25
TLCA# 18336
I stood outside the truck myself, had my wife engage both and then disengage: I clearly heard the front locker disengage. I heard a click from the rear as if it was trying to disengage, but it wasnt the "normal" clink that it makes. So Im thinking a sticky actuator.
A_Soldiers_Diary
Old 08-03-08, 10:07 PM   #26
TLCA# 18336
PS- love the Avatar Romer.
A_Soldiers_Diary
Old 08-03-08, 10:18 PM   #27
Romer's Avatar
TLCA# 13968
I would take the actuator off, dis-engage the locker and then photograph the actuator taking pictures as you disassemble and clean. Sarah's all had lost the O ring so it was pretty dirty where the spring was and it was the spring that was installed backwards.
Spring went the other way, cleaned surface with an emory cloth and used black FPIG in place of an O -ring putting it back together. Robbie diagnosed and gave instructions
Thanks - Big Sluice on the Rubicon
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Old 08-03-08, 10:35 PM   #28
