Old 08-02-08, 04:54 PM   #1
98 SNAKE EATER's Avatar
Silly question about tire rotation....
OK, when I bought my rig, the dealer installed a brand new set of Toyo Proxy street rubber
Because they were uni-directional, I was forced to do front to back/back to front rotation
Now I have a set of BFG MT's and I'm about to do my first rotation (including the spare)
I was gunna follow the diagram in the manual, but the left front tire (the one the diagram says to stick in the spare holder) seems to have the least amount of tread wear
The alignment specs are spot on, so this has me wondering if the rotation is the same for the RHD rigs overseas
Anyone happen to know if the rotation diagram is the same?
I figure it should be a mirrored image since they would be dealing with an opposite road crown
98 SNAKE EATER is offline   Reply With Quote
Old 08-02-08, 05:24 PM   #2
tblume's Avatar
there are no silly questions.
silly answers, yes.
I just mounted up 5 BFG MT's, still thinking how often and how I'll rotate in the spare, prolly just put #5 in in the spot with the most wear, and put the most worn one in the back for next go round; I'll do rotating every oil change- I use semi synthetic, change my filter at 3 and oil and filter at 6, so every three or so I'll change tires.
'93 FJ80; stock, locked, 7PIN, CDL button, 255/85 BFG MT's TLCA# 19103
'71 FJ55- donated mid V8 swap to a 4x4 shop to move
'78 FJ40- rust bucket, parted to the '55
'84 FJ60- sold to buy Heep Liberty CRD. dumb@$$
http://forum.ih8mud.com/ca-jefferson-state-cruisers/
tblume is offline   Reply With Quote
Old 08-02-08, 05:32 PM   #3
Well, here's what I have in the owners manual:
But according to THIS THREAD, the proper rotation seems to vary from manual to manual
Old 08-02-08, 05:47 PM   #4
tblume's Avatar
measure twice; rotate once
Old 08-02-08, 06:53 PM   #5
snowwolf's Avatar
I have just come home ofter quite a few beers and can't get my head around rotaion, what if you dont have a spare! how would you do the rotaion?
snowwolf is offline   Reply With Quote
Old 08-02-08, 07:49 PM   #6
That depends if the tires are uni-directional or not
If they are, then you have no choice but to rotate front to back/back to front (that is, unless you want to remove the tires from the wheels)
If they're non-directional, then you can do a criss-cross rotation, but even that can be complicated as the rotation is different for every car for a reason
Some alignment specs compensate for road crown so that there's minimal steering drift due to the normal crowning of the road surface...
This compensation, along with weight bias, causes the tires to wear unevenly per side, so the manufacturers set specific guidelines for rotation to get the most out of the tires for that specific vehicle
Thing is, the 80 series is made in both LHD and RHD, so if all I just said is true, then the rotation should be the complete opposite of that used on an RHD rig
On the other hand, I could just be blowing smoke outta my arse
Old 08-02-08, 08:36 PM   #7
sandcruiser's Avatar
If you use the same pattern every time, it doesn't matter that much which pattern you use.
That's assuming that you do rotate the tires at least 5 times during the useable lifespan of the tires. More can't hurt.
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Hankook MT's 31x10.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns. WTB: Tan DS mirror & housing
'88 HJ60, "Louie" For Sale in Costa Rica.
sandcruiser is offline   Reply With Quote
Old 08-06-08, 11:02 AM   #8
I agree that more rotations can't hurt, but I've always been told that there's a pattern for reason...
Lets say that due to road crown, the left front tire wears more than the rest...
Using the diagram posted above, you would always move the left front to the spare...
If you move any other tire to the spare, the left front tire will see more wear than usual
Granted, the difference will most likely be minimal, but like I said, the manufactures have a specific rotation for a reason
Anyhoo, anyone happen to know if the same diagram is listed in the OM for RHD rigs?
Old 08-06-08, 02:41 PM   #9
Again, if you go through all the positions, it doesn't matter much.
To take your example: lets assume that the Front Left (FL) tire wears more. So you move it to Spare. Next time you move that worn tire to back left.
Would it really matter if you moved it from the FL to the BL without pausing in Spare?
In other words, you could move to spare at any point in the rotation, I think, without a significant difference. The one part that I think does matter is that you do want the two front tires to go to the rear.
Old 08-06-08, 02:50 PM   #10
Actually, yes because by the next rotation, the rest of the tires would've worn down a bit to match the worn spare that was initially on the left front
Old 08-06-08, 04:44 PM   #11
ok.
I'm still thinking that if each tire spends equal time at each position, in the end, they all wear about the same.
But I do see your point, and I guess it could be significant if you wait a long time between rotations. In 1,000 miles, I'll bet you can't tell a difference in wear. In 20,000 miles, you'll probably see a big difference.
Old 08-06-08, 10:54 PM   #12
I don't wheel
hj60's Avatar
TLCA# 11004
Wow. You guys are way overthinking this.
I've never rotated my spare onto an axle.
Only once have I even bought 5 new tires.
I rotate the backs to the front and the fronts to the opposite back.
Hell, on my first 2 vehicles, I never even rotated my tires at all.
When the spare is dryrotted, the best of the old tires goes on the carrier when I replace the 4 on the ground.
Rotate often and uneven wear isn't an issue.
Jonathan M. Rundlett <skadalajara@gmail.com>
Copper State Cruisers #001
Member of the Happy Hour Gang and the last true conservative in the U.S.
'94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper
Originally Posted by NLXTACY View Post
Others here can explain that a whole lot better than me but IIRC it had to do with the Vicious Coupler.
hj60 is offline   Reply With Quote
Old 08-07-08, 04:11 AM   #13
Sorry, but I didn't pay $245 per tire to let ANY of them dry rott lol
Old 08-07-08, 02:15 PM   #14
rdang's Avatar
I do the rotation from this site here: Tire Tech Information - Tire Rotation Instructions, figure G.
Because mud tires generally wear faster, I try to do it every 2-3000 km's, keeps the tires nice and even.
95 FZJ80 | 4" OME Lift, 315 Cooper's, ARB Bumper, Locked Baby, Locked!
97 4Runner LTD | Sonoran Steel 1.1 Lift, 2" Rockcrawler BL, TG Sliders, 33x12.5x16 SSR's on 16x10 Eagle 058, Factory Rear Diff Lock (SOLD)
98 UZJ100 [wife's DD] | 18" Tundra Wheels, Factory Rear Diff Lock, otherwise stock
rdang is offline   Reply With Quote
Old 09-16-08, 03:13 PM   #15
ttt
Anyone have a pic of the Rotation used on the RHD rigs?
Old 09-16-08, 04:08 PM   #16
mainemike's Avatar
TLCA# 17772
I don't see why a RHD would make a difference over a LHD. The tires don't care. Your original post asking about the crown of the road being opposite - well, over the life of rotation the tires end up on all 4 corners eventually.
I'm still amazed that I have over 30,000 miles on Nitto Grapplers with never rotating (following threads by landtank) and there is no uneven wear... I can't explain it, I used to be obsessed with rotation on previous trucks.
1996 FZJ80 not-locked, Emu 861/862, ARB, Slee sliders and skids, 285 Nitto TGs, Scan Gauge, hopefully exploring somewhere in North America.
www.purplelizard.com
mainemike is offline   Reply With Quote
Old 09-16-08, 05:30 PM   #17
alia176's Avatar
TLCA# 15941
I don't feel so bad about my OCD now....
TLCA # 15941
KE5LED
Currently working PA
alia176 is offline   Reply With Quote
Mobile Phone | Debt Consolidation | Property for sale in Spain | Mortgage Calculator | Ringtones
