RTH - rig won't start
'93 1fz fe - cranks but won't start.
no CE light when the key is in on position so EFI circuit right? fusible links are good. changed out efi relay and fuse is good. so what next, any ideas... __________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo |
Jon Held has posted up diagnostics for the 3FE EFI circuit. "If continuity here, then next check there..." etc. Not sure how much of it would apply to a 1FZ though...
Hang in there, Curtis |
thanks, i've been through that up till this bit...
"check for +12 on pin 8 (B+) on the check connector mounted on the right side of the firewall." ....not sure how to translate that to my 1fz diagnostic port. __________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo |
What did you do prior to it not starting? Any repairs? Electrical work?
__________________ 1994 FZJ80 |
I don't have access to a schemo for a later truck. Do you have a EWD of your truck?
The diag port has to have a +12 pin. I would ASSUME that it is the same source, but can't be sure without the schemos. __________________ Jon Held 1991 FJ80 "Lumbering White Rhino" Times Square, New York, USA TLCA# 5980 http://gclcny.com/jh/ Buy your FJ80 FSM here: http://gclcny.com/jh/fsm.html |
#6 | |
truck taken apart to build new shock towers. i disconnected the ecu, battery etc before i did the welding on the shock towers. i've also done a bunch of PM before putting everything back together or at least what i thought was "all" back together.... __________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo |
#7 | |
more info - i jumped the 2 and 4 pin of the efi relay and that has gotten me a CEL and fuel at the return line but no start (no spark)... __________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo |
ok this is getting really strange. i was checking fusible links again and i noticed the
headlights don't work. (i don't know if they ever worked because i only drove the car for four hours before i started in on it) so any way i get in and hit the brights to see if that helps and guess what, with the brights switch on the efi circuit powers up and cel comes on.... W. T. F. ![]() now it still won't start (no spark) but what is going on. does that make any sense to anyone, the bright switch powering up the efi circuit..... __________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo |
With you having done all that work on the truck, I would assume you missed something. The EFI circuit appears not to function because you're still a "no spark". Do the later model trucks have the +12 terminal in the fuse box? That would be a logical place to start.
You manually jumped the EFI relay and that gave you nothing so the ECU/distributor/coil/igniter are now suspect. However, the truck WAS running before you did what you did. I would go back over everything. __________________ Jon Held 1991 FJ80 "Lumbering White Rhino" Times Square, New York, USA TLCA# 5980 http://gclcny.com/jh/ Buy your FJ80 FSM here: http://gclcny.com/jh/fsm.html |
#10 |
went back over every connection, as i was redoing ground wires the
door buzzer popped on and all was right with the land cruiser gods... ...it's alive!!!! ![]() ![]() thanks for the help
#11 |
I have no door buzzers, but no other problems........yet? hope there is not a connection
__________________ '93 FJ80; stock, locked, 7PIN, CDL button, 255/85 BFG MT's TLCA# 19103 '71 FJ55- donated mid V8 swap to a 4x4 shop to move ![]() '78 FJ40- rust bucket, parted to the '55 '84 FJ60- sold to buy Heep Liberty CRD. dumb@$$http://forum.ih8mud.com/ca-jefferson-state-cruisers/ |
Problem Mortgage | Credit Cards | Mortgages | Buy Anything On eBay | The eBay Song |
