Old 08-02-08, 12:07 PM   #1
Elijah's Avatar
TLCA# 16029
Fan clutch fluid
So how much fluid is needed to refill the blue hub fan clutch if completely drained? Been reading threads for a half hour and can't find it.
99 UZJ100, OME 2" lift, 315's, ARB front bar, 4x4 Labs rear bar
95 FZJ80, lockers, off-road monster, 37" Pitbull Rockers
84 FJ60, stock
76 FJ40, v8 conversion, discs all around, lock-right in back, 35's
Elijah is offline   Reply With Quote
Old 08-02-08, 01:10 PM   #2
I don't wheel
hj60's Avatar
TLCA# 11004
Not much. IIRC mine was about 6 oz?
Maybe Tools R Us can say for sure, as he did mine
Jonathan M. Rundlett <skadalajara@gmail.com>
Copper State Cruisers #001
Member of the Happy Hour Gang and the last true conservative in the U.S.
'94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper
Originally Posted by NLXTACY View Post
Others here can explain that a whole lot better than me but IIRC it had to do with the Vicious Coupler.
hj60 is offline   Reply With Quote
Old 08-02-08, 01:19 PM   #3
turbocruiser's Avatar
I seem to remember that with an overnight drain still leaving some fluid/film in the clutch it takes exactly two tubes to correctly fill the clutch. I'm referring to the tubes that the dealers sell here, btw. I bought two tubes of the 6K from Dan based on the Landtank thread. My clutch is relatively new so IF i think that the fill is a little low, I'll just take some of the old drain 3K (US spec IIRC) and add as appropriate. All of this is from my memory and my memory sucks so perhaps either Landtank or Tools can chime in here to help.
97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, LandTank MAF, 3" Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 8.5psi and climbing, My Rocky Mountain Mojo Mobile!
turbocruiser is offline   Reply With Quote
Old 08-02-08, 01:36 PM   #4
gotmud's Avatar
TLCA# 18039
I have found there is no consistency with volume amounts on an oe clutch. I would drain the clutch over night as others have said, but when you fill it, fill it to the top of the reservoir opening.
1994 FZJ80
gotmud is offline   Reply With Quote
Old 08-02-08, 01:39 PM   #5
Tools R Us's Avatar
The newer style Aisin blue hubs, (identified by sheet metal spring holder) my fill is 50ml. The earlier type (cast spring holder) can hold more ~60ml. The original Eaton clutches about only hold ~30ml.
The first pic is the newer style Aisin with sheet metal spring holder, the second pic the older Aisin blue or black hub style.
Copper State Cruisers #007
Tools R Us is online now   Reply With Quote
Old 08-02-08, 01:44 PM   #6
Wow, that surprises me, I'm not saying it isn't so, I'm just saying it surprises me. Is this with clutches that aren't leaking any or otherwise have a reason to be so drastically different? Between the really wide range of observed temperatures where the clutches activate and this inconsistency in fluid fills, we really seem to have missed the mark in standardizing this incredibly important part. Either way, if you drain overnight and add two tubes regardless of how "off" each one was with others to start with, yer gonna get the same final fill.
Edit: Looks like the tubes I got from Dan of the 6K (part no. 08816-06001 ) are 15ml's each so three tubes is more appropriate unless you simply take some of the old 3K and add it. HTH>
Old 08-02-08, 02:34 PM   #7
gotmud's Avatar
TLCA# 18039
IIRC, the last blue hub I did took a little over 50ml.
1994 FZJ80
Old 08-02-08, 04:30 PM   #8
Elijah's Avatar
TLCA# 16029
I picked up 50 ml of the 10,000 weight rc diff fluid at the hobby shop. I'll put all of it in after I drain for a few hours. I have a newer style blue hub. I had no cold air at all idle, but at 30 mph or more I have cold air. At idle, the clutch was not engaging. I'm hoping this will do the trick to having some AC in this 100 degree weather. Anti-freeze flushed as well and no overheating either.
84 FJ60, stock
Old 08-02-08, 04:35 PM   #9
Elijah's Avatar
TLCA# 16029
Which side of the clutch is the 'reservoir' on? Looks like both sides hold fluid?
84 FJ60, stock
Old 08-02-08, 09:44 PM   #10
Elijah's Avatar
TLCA# 16029
Just dumped the 50ml of fluid in and got it put back together and installed. Nice roar on startup and can tell the roar during idle at stops, traffic, etc. Only thing is this didn't get my AC cool, I look again and now the compressor clutch doesn't engage. FSM says check belt tightness, than check the magnetic clutch relay. I'll try and figure out how to 'test' the relay, if I can find it.
84 FJ60, stock
Old 08-03-08, 12:09 AM   #11
The quick brown fox .....
Beowulf's Avatar
Don't overlook the belts. There is a reason that the FSM says to check them first. Depending on age it might be a good idea to replace the A/C belt. My A/C wasn't working right after I bought the truck in 2001. No audible indication that the belt was bad or slipping. Put on a new belt and tightened and the A/C has worked fine for 7 years.
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Beowulf is online now   Reply With Quote
Old 08-03-08, 12:15 AM   #12
Kneel for the Shaman
Romer's Avatar
TLCA# 13968
My pully had fallen off the adjustment bolt near the bottom of the engine. Check to make sure its tight and the pully is still there
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is online now   Reply With Quote
Old 08-03-08, 01:51 AM   #13
Elijah's Avatar
TLCA# 16029
Belt is new and tight(OEM) and everything is intact. I need to figure out why the clutch isn't engaging. I remember before I would hear a slight click when it engaged and RPM's would jump to around 800-850. Now I get no engagement at all.
84 FJ60, stock
Credit Card Debt Consolidation | The eBay Song | Deals On Products | Myspace Layouts | Books
