Sarah's 1996 LX450.
Symptum : Turn key and no starter noises no clicking. Problem is intermitant
First thought was bad cables and connectors ( a little loose) worked for a bit
Then thought bad cell in battery and replaced with new Red Top. Worked for a bit.
Starter contacts done last year.
It is about 100 deg around here.
Tried the screwdriver with the safety switch trick and no joy. But I have never done it myself so I don't know if I was doing it right.
When it is failed, all other electronics work. No fuses or EFI links are bad
Measured 12V on the starter.
Did not take the harness that ties the Neutral Saftey switch down to troubleshoot.
Thinking either the Solenoide on the Starter of the Nuetral Saftey switch.
I'll do some more research, but thought someone might have some quick pointers
