Old 08-01-08, 04:51 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Ebag333's Avatar
TLCA# 18864
Grey wire mod (extend alarm remote range)
I did a couple of searchs and didn't find anything on this, so apologies if I missed something.
This is about a tenth of a mod that takes less than 30 minutes (if you're moving slow).
The goal of this mod was to extend the range of the "factory" alarm. This applies to the RS3000 alarm.
Using my remote as a test unit (battery is fairly old, I'm about 4-5 feet away typically when it starts working) I was able to extend the range to well across the street, and even further as long as I had line of sight to the drivers side B pillar.
To reroute the antenna:
  1. Find some wire that works. I used some speaker wire I had handy. If you had an actual antenna (it would need to be long, narrow, and fairly flat) that would probably work even better.
  2. Pull the bolts on the seat (2 front, 2 rear).
  3. Tip the seat back and disconnect the wires from the seat. I simply tipped it up on top of the center console to move it out of the way, but you could also move it onto the back seat.
  4. On the single 4 pin plug (that has one grey wire in it), snip the grey wire a fair way back and connect your new wire via the method of your choice (solder or mechanical connector).
  5. Slide the new wire under the carpet to the door step. I went along the ridge where the other wires were ran to make it easy.
  6. Run the wire up the drivers side B pillar. I simply looped it over the top of the seat belt mount, and down a foot or so on the opposite side.
Initially (as you can see from my pictures) I ran a double wire and connected it back to the original antenna. This actually decreased the range to about that of stock.
I did several tests for range:
  1. 4 pin completely unplugged (no antenna). About half the range of stock.
  2. Stock antenna. About 4-5 feet range.
  3. Double wire running up the B pillar and back down, terminating at the alarm. About the same as my final solution.
  4. Double wire running up the B pillar and back down, attaching to the stock antenna. Same range as stock.
  5. (Final solution) Single wire running up the B pillar towards the front, and hanging down about a foot on the back side.
Your range will be greatly increased no matter where you stand, but I found that the best range was with direct line of site to the inside of the drivers side B pillar.
Which makes sense as the only thing blocking the signal is glass and the soft cover over the seat belt mounts. Any other angle has metal blocking the signal.
Couple of crappy cell phone piccies below.
In the first pic, you can see the entire box. The 4 pin connector with a single grey wire is at the top.
Second pic has a zoomed in pic of the connectors. Note that in this pic I had the double wire hooked back into the factory antenna, which decreased the range. With the way I would recommend doing it (and how I'd do it in the 's rig) is to simply leave the grey wire loose, so you completely reroute it.
An alternate suggestion I found when searching for this was to find the end of the grey wire (ending somewhere around the steering column) and extend it up the A pillar. I found that getting to that area was far more difficult that getting under the seat, and would greatly increase the time to do the mod.
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 08-01-08, 07:09 PM   #2 (permalink)
lx450landcruiser's Avatar
just went out to my truck and did it. walked across the street and truck locked. never tried it before so i dunno but ill be able to test it when i drive some where in the next few days. if this works as well as i think it does this is a great mod. took all of 5 min
1996 LX450 ARB, dual batteries, remote starter, 760 watt sub woofer, in dash CB, Custom switch pannel, cut and turn mod, magnaflow, custom rear bumper, rock lights, 2.5 lift, snorkle. clear side lights, CSC alum spacers, 33s, and more to come.
lx450landcruiser is offline   Reply With Quote
Old 08-01-08, 07:24 PM   #3 (permalink)
calfj60's Avatar
Great info...this drives me crazy...gotta be within feet of the truck to lock or unlock...gonna do this really soon..
Tim Coffey
87 FJ60 SBC 350 SOA and some other stuff SOLD 5-15-07
94 80 with some stuff New to me 04-28-08
TLCA # 6947
Parts and Carb Rebuilds
http://www.marksoffroad.net
calfj60 is offline   Reply With Quote
Old 08-01-08, 08:35 PM   #4 (permalink)
Clutchee's Avatar
TLCA# 13383
Garage
New FAQ thread.......
Oh yea, thanks!
You can't fix Stupid
---CottonLand Cruisers-----
---White Trash of the Elwood Chapter----
---STLCA----
We've been this close to death before, we were just too drunk to know it
Guess the price of being sobers being scared out of your mind
-Drive by Truckers-
Clutchee is offline   Reply With Quote
Old 08-02-08, 10:09 AM   #5 (permalink)
Corbet's Avatar
TLCA# 15340
Great mod.
This has been driving me nuts since I got the truck. Can't wait to give it a try.
Rising Sun 4 Wheel Drive Club Member
1976 FJ40, A project with little progress.
1985 FJ60, wife wants me to sell it, you want it?
1997 FZJ80 40th Anniversary, daily driver
Corbet is offline   Reply With Quote
Old 08-02-08, 10:17 AM   #6 (permalink)
The quick brown fox .....
Beowulf's Avatar
Can you post a pic of the antenna at the B-pillar. It wasn't clear to me how you left that end of the wire.
Also, did you try using both the original antenna under the dash *plus* your B-pillar antenna mod?
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 08-02-08, 12:01 PM   #7 (permalink)
Ebag333's Avatar
TLCA# 18864
-B-
there's really not much to show. I just tucked it under the cover, looped it over the bolt that holds the top of the seatbelt, and let it dangle (I had about a foot extra hanging down).
There's not really a good way of securing it, but as it's just the antenna and was super easy to do I can redo it if I have to.
Any setup that I tried that used the original antenna left me with close to stock range.
'97 LX450
'96 LX450
Old 08-02-08, 01:07 PM   #8 (permalink)
Well im very pleased with the results, Wish i had done this yeas ago.
I used a antenna i had from a cheap remote starter kit, I get killer range now. Went to buy beer at the store and could unlock and lock my doors from in the store about 65 feet away
Old 08-02-08, 02:33 PM   #9 (permalink)
Ebag333's Avatar
TLCA# 18864
It looks like you went up the A pillar and attached it to the wiindow?
I might find a cheap antenna that's flat enough to fit behind the cover of the B pillar. But maybe not....do you REALLY need a 65 foot range?
I've already unlocked my rig when unlocking the 's rig, about 20 feet away, by accident. As the Mrs rig doesn't have the chirper, it's not always easy to tell when hers locks/unlocks from a distance.
'97 LX450
'96 LX450
Old 08-02-08, 04:27 PM   #10 (permalink)
98 SNAKE EATER's Avatar
I do
YouTube - HORNBLASTING GONE WIRELESS!!
98 SNAKE EATER is offline   Reply With Quote
Old 08-03-08, 12:34 AM   #11 (permalink)
george_tlc's Avatar
TLCA# 8068
I just ran the new wire up the back of the drivers seat (with enough slack underneath to allow for full forward/rearward seat motion). Since I have SOR seat covers I just ran the wire up behind the seat under the SOR cover and ran it up to the headrest and secured it in that area.
Range is at least 30' and since the antenna is not running along the pillars etc the range seems reasonable consistent regardless of direction from the vehicle.
Something I've wanted to do forever - this thread finally gave me the kick in the @ss to go and spend a few minutes doing the mod.
cheers,
george.
where ever you go, there you are....
'97 S/C White CE, locked^3, sliders,arb,kaymar, m12000,dual batteries, LEDs, etc..... ki6ibx
http://www.george4wd.taskled.com
george_tlc is offline   Reply With Quote
Old 08-03-08, 08:35 AM   #12 (permalink)
Doc
Utarded
Doc's Avatar
TLCA# 17266
Garage
Why do you guys need to unlock your truck from so far away? It's not like this is a remote start....
Eric, Utah operations commander- Tall Corn Cruisers.
1993 Landcruiser, 197K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Doc is offline   Reply With Quote
Old 08-03-08, 09:49 AM   #13 (permalink)
george_tlc's Avatar
TLCA# 8068
It's not as if it is that far... Before I did the quick mod yesterday, I was lucky sometimes if I could lock/unlock it from 5' away - especially from 'blindspots' to the original antenna location. Often I had to push the button several times and walk around the vehicle.
So, in my case it isn't so I can open/shut it from 30' but so I can open/shut it when at the vehicle.
ALSO, often our kids will be at the vehicle waiting to get in and I'm still in the garage putting on shoes etc. Only like 15' away, but the stupid thing won't unlock until I'm right next to the vehicle.
So, in summary like most things - if you find the operation of something irritating then it isn't operating the way 'you' need it to, i.e. horses for courses...
cheers,
george.
Old 08-03-08, 10:28 AM   #14 (permalink)
Ebag333's Avatar
TLCA# 18864
That's an interesting way to go. I'd be concerned about it getting pinched, but I suppose if you routed it similar to the seat harness you shouldn't have any issues.
I think you can get a bit higher by going up the B pillar, but as you mentioned you'll have better LOS to the top of the seat.
'97 LX450
'96 LX450
Old 08-04-08, 03:17 PM   #15 (permalink)
beside La Caja China
PabloVTA's Avatar
TLCA# 15996
you da man!
this has been killing me for 10 years!
the new highlander can do it from another zip code, i practically have to be putting the key in the door to get mine to work.
Pablo '94 FZJ80 225K 6M1,
Optima Red Top, Bilstien'd, Amsoil,
Powerstop DnS F&R Rotors, 285/75 Revos,
George's LED's, MetalTech Sliders,
Slee Short Bus Front Bumper, OME 850/863 and stuff.
PabloVTA is offline   Reply With Quote
Old 08-04-08, 03:23 PM   #16 (permalink)
Ebag333's Avatar
TLCA# 18864
Beowulf,
Did you ever try this? Or do you need more pics?
'97 LX450
'96 LX450
Old 08-04-08, 03:29 PM   #17 (permalink)
Hog Head's Avatar
I did this quite some time ago. I found the stock wire running behind the dash and ran it up the drivers A-Pillar. The range is now 40-50 feet and no cutting or splicing was required. Also no need to remove the seat, just the trim around the steering wheel.
Hog Head
2008 Tundra 5.7L Crew Max 4x4, Radiant Red, 3" lift, LT285/70R17 Cooper Discoverer STT's on 17x8.5 Weld Method wheels.
2008 Camry Hybrid for the wife and kids.
Hog Head is offline   Reply With Quote
Old 08-04-08, 03:46 PM   #18 (permalink)
Beowulf's Avatar
This description was clear. I'm not too keen on dangling wires so I will pass on this variant.
I am frequently under the DS seat messing around with my ham radio so I was thinking this might be a simple project next time I am in there. I will probably do as George did and run the antenna extension up to the headrest as I also have covers over the seat and an external speaker for the ham radio is mounted on the headrest.
-B-
Old 08-04-08, 04:02 PM   #19 (permalink)
Ebag333's Avatar
TLCA# 18864
-B-
I understand the dangling wire concern.
It would be extremely easy to attach the top of the wire to the top mount for the seatbelt. I chose not to as I didn't want to pull the whole assembly apart, but could easily slide the wire in place without trouble.
Going with George's method is probably the best for a variety of reasons, though I don't know how well you could mount an antenna there if you chose to.
If you pulled off the cover for the seatbelt assembly, there is lots of room to figure out a mount, either for the wire by itself or an antenna.
'97 LX450
'96 LX450
Old 08-05-08, 04:39 PM   #20 (permalink)
KurtKuhn's Avatar
TLCA# 19102
Replacing my remote battery got me from 5' to 20'.
Good enough for my general purposes.
-KK
'96 LX450 - Factory lockers; 285 DuraTracs / Slee speedo gear; ScanGauge II; CDL & pin 7; CG-Lock; Alpine IDA-X001 Receiver; Polk Audio db 651; Alpine MRP-F250 40W x 4 Amp
KurtKuhn is offline   Reply With Quote
Old 08-05-08, 04:44 PM   #21 (permalink)
Ebag333's Avatar
TLCA# 18864
-KK
With my nearly dead battery I easily have 20'-30' range.
I'll be curious to see what a fresh battery gets me, but now I'm in no rush to get one.
'97 LX450
'96 LX450
Old 08-12-08, 11:37 AM   #22 (permalink)
Ebag333's Avatar
TLCA# 18864
Update on this mod.
Drove the rig last weekend (for 4 days) as we were going up to her sister's wedding, and I was playing taxi. She does not have the extended antenna (yet).
With my remote (which probably does need a new battery) I had to practially stand at the drivers side door to un/lock. I had trouble un/locking while standing at the tailgate (very irritating).
After coming home and getting to drive mine, I'm very happy with being able to trigger the alarm from 10+ feet away (easily, I can still hit longer ranges with LoS).
So this mod will actually save a bit of money and headache as:
1) I won't have to replace batteries as often because a "weak" battery can still trigger the alarm from a reasonable range.
2) I won't have to hit the button 10 times trying to it to un/lock. First or second try nearly every time.
Additionally we blew the fusible link in the back of the cigarette plug, and while "fixing" (*cough*bypassing*cough*) it I noticed that the grey wire was terminated on the wiring harness directly behind the alarm LED light. Mine was not terminated there, but my guess is that it was a shorter wire and is probably still terminated on the bundle, just somewhere under/around the steering wheel.
So if you simply want to extend it up instead of bypassing, it might be worth while to pull that and see if yours is terminated there. It would still be more time consuming to run it back up the A pillar as you'd have to double back or extend past the glove compartment, as opposed to running it up the B pillar or up the seat.
HTH
'97 LX450
'96 LX450
Old 11-18-08, 11:17 AM   #23 (permalink)
Awesome. Now I can lock/unlock10+ feet. Took 30mins as described though B pillar...
1997 FZJ80 ~129K Stock; MOONGLOW(1A6); PHH; Headliner Re-Upholstered;
hkimsoft is offline   Reply With Quote
Old 11-23-08, 09:52 AM   #24 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
The grey wire runs up to the LED on my 80,
I have always been annoyed with the poor range of the alarm/keyless, some time ago I tried adding an extension to the existing wire, little improvement, I even took apart the transmitter thinking maybe I could add to the antenna there no such luck, It sounds like the key is bypassing the factory antenna,
Gonna give that a try, thanks
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is online now   Reply With Quote
Old 11-24-08, 12:50 PM   #25 (permalink)
calfj60's Avatar
went to do this today and found I don't havethe grey wire or the four pin plug?? maybe my truck is too old...oh well did discover the seat bolts were really loose..
Tim Coffey
TLCA # 6947
Old 11-24-08, 01:01 PM   #26 (permalink)
Ebag333's Avatar
TLCA# 18864
Do you have the alarm box under your seat?
You may have one of the other types of alarms or an aftermarket alarm.
And loose seat bolts = bad.
'97 LX450
'96 LX450
Old 11-24-08, 01:02 PM   #27 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
there are a couple of different "factory" alarm/keyless systems, most were actually port installed , the RS300 is the most common and has the grey wire.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 11-24-08, 01:08 PM   #28 (permalink)
Ebag333's Avatar
TLCA# 18864
RT, did you ever get around to trying this?
'97 LX450
'96 LX450
Old 11-24-08, 01:19 PM   #29 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
no not yet,
1988 FJ62 on 33s
1996 LX450 on 33s
Old 11-24-08, 01:33 PM   #30 (permalink)
calfj60's Avatar
I have the alarm box under my seat but with just one big connector...
Tim Coffey
TLCA # 6947
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/233963-grey-wire-mod-extend-alarm-remote-range.html
Posted By For Type Date
Grey wire mod (extend alarm remote range) - IH8MUD Forums This thread Refback 02-05-09 10:54 PM
FZJ80 gray wire mod (remote antenna) - Rising Sun Member Forums This thread Refback 09-06-08 06:36 PM
