Old 07-30-08, 07:04 PM   #1
JPHockerAZ's Avatar
The I have a 93-94 and want a supercharger thread
This thread will pertain to how previous installs of the TRD supercharger on a 93-94 truck were done. It will also discuss how it could be done.
I know that there are remarks on various threads about this subject on the board but lets put it all together in one thread!
Discuss
94 FZJ80
JPHockerAZ is offline   Reply With Quote
Old 07-30-08, 07:47 PM   #2
Parts Shaman (per Romer)
cruiserdan's Avatar
TLCA# 11332
Been there, done that, drive it every day.
Install it like you would a 95-97 and either relocate the PAIR valve or block off the manifolds and get it some extra fuel so it won't knock.
My solution for the knock: http://forum.ih8mud.com/80-series-te...induction.html
Old 07-30-08, 07:54 PM   #3
JPHockerAZ's Avatar
Dan-
Did you relocate or remove the pair valve. I get the feeling that the people doing visual inspection here for emissons dont know or look for the pair valve. I would think removal is the easier and less expensive route.
For your water/methanol injection, did you start with water and switch to methanol for any particular reason?
94 FZJ80
Old 07-30-08, 07:59 PM   #4
cruiserdan's Avatar
TLCA# 11332
I relocated my PAIR. The truck runs the same with or without. I have run it both ways. I have always used a 50/50 blend of methanol/distilled water. it cools better than plain water and it does burn so there is a bit of a fuel boost. In addition it does not freeze in the winter... That last part is kinda important.
Old 07-30-08, 08:11 PM   #5
JPHockerAZ's Avatar
Any other solutions for the knocking problem out there?
94 FZJ80
Old 07-30-08, 08:24 PM   #6
ThinkTank Waterboy
landtank's Avatar
I've got one in the back of my head and just recently have access to a fellow mudders 80 for verification. But don't hold your breath as I have other things in the works as well. The basic idea is to augment the VAF sample size to match larger injectors. This sounds kind of out there but it is exactly how Toyota dealt with Turbo charging engines back in this era. The end result, if successful, would be accurate fueling through out the operating range of a boosted engine for the 93/94 guys.
Rick Bigelow
'96 215k
Groveland MA 01834
landtank is online now   Reply With Quote
Old 07-30-08, 09:16 PM   #7
cruiserdan's Avatar
TLCA# 11332
In addition to Rick's angle some folks have used a rising-rate fuel pressure regultor and some others have installed a twin turbo Supra fuel pump. Some have done a combination of both. I think that some sort of additional injector, such as the cold-start injectors Toyota used on very early EFI motors, would also work.
The trick is to get it to come online at the proper time and flow the proper ammount of fuel.
Old 08-01-08, 08:37 PM   #8
Wagon Owner
calfj60's Avatar
John,
I can take pics of how we made my pair valve work when getting it smogged and now it runs plates to close the holes...Thanks again for the info on the tranny filter today...
Tim Coffey
87 FJ60 SBC 350 SOA and some other stuff SOLD 5-15-07
94 80 with some stuff New to me 04-28-08
05 Subaru WRX
TLCA # 6947
Parts and Carb Rebuilds
http://www.marksoffroad.net
calfj60 is offline   Reply With Quote
Old 08-02-08, 03:12 AM   #9
JPHockerAZ's Avatar
This is johns son Joel but I am sure he wouldnt mind the thank you
It would be awsome if you could elaborate more on your temporary pair setup.
94 FZJ80
Old 08-02-08, 03:11 PM   #10
Wagon Owner
calfj60's Avatar
I will try and snap a pic or two for you tommorow ...
Tim Coffey
05 Subaru WRX
TLCA # 6947
Vacation Spots | Debt Consolidation | Free Credit Report | Bad Credit Mortgages | coupon-coupon.com
