Old 07-30-08, 12:55 AM   #1
AppleTech's Avatar
Bypass AT Park Safety (for starting)
So my truck has been giving me trouble starting when it is hot. Reading threads around here, I think it has something to do with the unit that prevents the truck from starting when in gear? Something about a solenoid not releasing when it's hot? If someone could shed light on this and a way to bypass, that would be great.
The truck starts after a while, but usually about 20-30 minutes of sitting, which can be nerve wracking for first time guests 15 miles into the forest
Thanks in advance...
Phil
AppleTech is offline   Reply With Quote
Old 07-30-08, 06:59 AM   #2
Doc
Corn Eater
Doc's Avatar
TLCA# 17266
The park safety release is under a little cover just north of your shifter, you have to pry the cover off and then push a little button using something like a pen, screwdriver, etc...
Eric P.
1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Tall Corn Cruisers- El Presidente.
Doc is offline   Reply With Quote
Old 07-30-08, 11:20 AM   #3
NLXTACY's Avatar
TLCA# 19015
Interesting. My 4Runner had that button that you can press and not have to press the brake pedal to shift out of park. Curious as to why the 80s dont have it available...unless you pry off the cover, etc.
70 FJ40-sold, worst day of my life
79 TOY 4WD pup-stolen, 2nd worst day of my life
91 4Runner 4WD-burned to ground, 3rd worst day of my life
83 FJ60- suckiest day of my life
97 LX450, 221k, non-locked. Expedition vehicle in progress. Factory rack removed
Originally Posted by Brentbba View Post
Nah! I'll just overanalyze it for about 3-4 weeks, put up 5 posts about it, then not make up my mind.
ふざけんなよ!
Old 07-30-08, 11:29 AM   #4
Kneel for the Shaman
Romer's Avatar
TLCA# 13968
I believe this is called the Nuetral Safety switch and I have seen folks remove that little square and with a screwdriver down the hole, start their truck
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is online now   Reply With Quote
Old 07-30-08, 12:16 PM   #5
NLXTACY's Avatar
TLCA# 19015
WHAT?!?!
I want to ask for more info but I kinda also don't. More info for me, less info for someone who wants my truck.
ふざけんなよ!
Old 07-30-08, 01:21 PM   #6
Doc
Corn Eater
Doc's Avatar
TLCA# 17266
Originally Posted by NLXTACY View Post
WHAT?!?!
No- pressing the button doesn't automatically start the truck, you still have to have a key and turn it in the ignition....
Eric P.
Old 07-30-08, 01:42 PM   #7
NLXTACY's Avatar
TLCA# 19015
Thank you.
ふざけんなよ!
Old 07-30-08, 02:01 PM   #8
jonheld's Avatar
TLCA# 5980
OK, we're all confusing 2 different things here...
Neutral Start Switch: Pie shaped guy mounted on the side of the transmission housing. Allows the starter circuit to work only when in P or N.
Shifter interlock: Locks the transmission shifter in P until the ignition switch is ON and brake pedal depressed.
The failure to start when hot...is that no crank or no fire?
Jon Held
1991 FJ80 "Lumbering White Rhino"
Times Square, New York, USA
TLCA# 5980
http://gclcny.com/jh/
Buy your FJ80 FSM here:
http://gclcny.com/jh/fsm.html
jonheld is offline   Reply With Quote
Old 07-30-08, 04:47 PM   #9
ToyotaDon's Avatar
Right, the push button is just to take the vehicle out of P without the key on or brake pedal depressed.
You can try putting the trans in neutral when it acts up. That uses a different circuit in the Trans Range Selector switch. It would also indicate that is where the problem lies.
Donal
Originally Posted by fish2live View Post
WTF - where have you been?? That's the most detailed post from someone with less than 300 posts I've ever seen...
Thanks TDon - stick around and help for a bit, won't you?
Originally Posted by Hilux View Post
Low post count ≠ Low intelligence
ToyotaDon is offline   Reply With Quote
Old 07-31-08, 12:15 AM   #10
AppleTech's Avatar
Both of you are on the right path here. I know about the Interlock. I'm referring to the NSS. Basically, the truck thinks the shifter is in gear when its hot. I've hit the SI and moved the shifter back and forth, tried starting in Neutral. No crank. Get prime though, so I know it's not dead - reads ~12V on the scanguage.
Someone with this issue mentioned it can be a sticky solenoid? I just want to bypass the system so that the truck always thinks its in park, meaning I wouldn't have this issue. Of course, I could rebuild the solenoid, but I really don't want to get into that at this point.
Any thoughts now that we have clarified? Sorry for not putting that in the original post, but I forgot what it was called
-Phil
Old 07-31-08, 10:13 AM   #11
ToyotaDon's Avatar
The only solenoid in that circuit is the starter solenoid, which is part of the starter. There is not even a relay on these vehicles. If you are having an issue with the solenoid, you should be hearing a click, but no crank. The most common thing is the starter contacts which are inside the solenoid, a search should bring up how to replace these.
It's not recommended to bypass the Neutral Safety switch, you don't want to chance starting the vehicle in gear. You can do this as part of diagnosing the problem, though. At that switch, there should be a couple wires which are larger than the others, one black with a white tracer (from the IGN switch), the other black with a red tracer (to the starter solenoid). Disconnect the connector and jumper these together with a jumper of sufficient wire size and the proper connector terminals. If your engine starts, then you know the NSS is the problem. Get one of those and be sure to follow the FSM for how to adjust it properly when replacing.
Donal
Old 08-01-08, 11:18 PM   #12
gbell210's Avatar
I 2nd the starter if you haven't ruled that out. Next time it doesn't start, take the jack handle or long metal rod and tap the starter solenoid (connected to the starter). If it turns over after that (or a few trys) you've found your problem. Thats how I trouble shot mine.
-Garrick
'94 ARB'd (non-winch), Kaymar'd, OME 850/863, Toyo M/T's 285/75/16, Metaltech sliders, and OEM lockers
'89 Supra Turbo, Blitz Nur-spec, K&N FIPK, Michelin Pilot sports
'00 Corolla VE The stripped down gas-miser
gbell210 is offline   Reply With Quote
Fast Loans | The eBay Song | Go ACC | Mortgage | Buying Your 1st Home
