Starter Question
North Jersey
I just replaced my starter contacts, I had no issues with it but did it as PM as the starter has 123,000 on it. Everything works but while testing it I noticed that if I turn off the engine as soon as it starts I can hear the starter still spinning until it stops. Just to clarify the motor is only spinning after being energized and is not turning or running on battery current. I don't know if it is supposed to do that, but isn't that a sign of something else worn out in the starter not sure because I never took notice.
Thanx
George
nope that sounds fine
your just hearing it since your turning it off right away and since you played with the starter your paranoid and hearing things :D
Todd,
I believe your right! I knew I didn't fawk it up but I never took notice of the noise before.
Thanx
George
