Odd ABS question: what type of signal?
Okay, this is not your usual ABS question
This would be for a full float rear axle(95+??)Can anyone tell me what type of signal the rear ABS signal send out? Pulses per rev or pulses per mile would be a GREAT help. Back story for the question: I've retro fitted a full float rear axle into my FJ55. I knocked 7" off the short side to retain stock WMS of the FJ55. My FJ55 is getting a 6.0L Vortec shortly and I've been trying to figure out the VSS situation since I am using an NV4500 with Toyota tcase. I've got two or three other ideas I'm looking at. But while putting the axle in, I noticed those nice ABS sensors and thought those would be a perfect way to get a signal to the PCM at a low cost(aka freeish )
__________________ -1971 FJ55: 6.0L-NV4500-doubler, SOA, D60s, ARB'd... and cupholders ![]() -1972 extra cab FJ45... 10 year project with a BB cady... DOA 08 ![]() |
counted a hub I have here, the rear abs ring has 48 teeth, so 48 cycles per revolution, the training manual says the sensors produce a low level AC voltage, one cycle (low peak, high peak) per tooth
__________________ 1988 FJ62 on 33s 1996 LX450 on 33s |
I don't wheel
It's nearly a square wave.
So is the VSS. Problem is the frequency per revolution will be very different. Also, if you try to use both WSSs therell be frequency overlap (like a flanger for a guitar) that'll confuse the PCM. You could probably run one of thos VSS correction boxes for bigger tires and fool the PCM into thinking a single WSS is the VSS. A lot easier than installing a VSS in the stock transfer. Or, you could just get an 80 series transfer. It'd already have a VSS.
__________________ Jonathan M. Rundlett <skadalajara@gmail.com> Copper State Cruisers #001 Member of the Happy Hour Gang and the last true conservative in the U.S. '94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper |
Raven, thanks for the tooth count. In my "rush" to get the axle in and together, I forgot to count them.
![]() I wish I could do the FJ80 tcase but no adapter for NP203 that I know of ![]() I would definitely only use one of the signals. On the difference of frequency, the PCM can be programmed for a surprisingly wide array of inputs ![]() My current other options right now are:
![]() ![]() Uh, Houston, we have a problem......... some of you guys are way too smart for us puny earthlings ![]() oh yeah, where're the pictures of this beast of a '55? __________________ '93 FJ80; stock, locked, 7PIN, CDL button, 255/85 BFG MT's TLCA# 19103 '71 FJ55- donated mid V8 swap to a 4x4 shop to move ![]() '78 FJ40- rust bucket, parted to the '55 '84 FJ60- sold to buy Heep Liberty CRD. dumb@$$http://forum.ih8mud.com/ca-jefferson-state-cruisers/ |
I have this habit of out smarting myself
![]() ![]() ![]() Here is a picture of the pig as I got it: I've got a build up thread here with LOTS of non-complete pictures in it. About 100 and change posts... mostly me rambling with pictures. ![]() ![]() http://forum.ih8mud.com/fj55-iron-pi...-build-up.html FJ80 axle high lights:
__________________ -1971 FJ55: 6.0L-NV4500-doubler, SOA, D60s, ARB'd... and cupholders ![]() -1972 extra cab FJ45... 10 year project with a BB cady... DOA 08 ![]() Last edited by Lil'John; 07-28-08 at 04:38 PM. Reason: idiot forgot the thread |
Mobile Phone | Credit Card Debt Consolidation | MPAA | Wu Long Tea | Credit Card Consolidation |
