#31 | |
-Spike __________________ His 1994 TLC 'White Elephant' +6"/35" Locked and loaded. Hers '95 TLC Bare bones. "I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown |
#32 |
Still wondering why almost everyone's ignoring the steering stabilizer.
What am I missing? Shouldn't it at least be checked to make sure it's not shot? Curtis |
#33 | |
KI6MIE
Because a stabilizer is not needed to prevent death wobble. If everything else is good, it doesn't wobble. My FJ40 has no stabilizer and does not wobble. Often they just cover up another problem. __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
#34 |
Mine only has a couple thousand miles on it max. At least in my scenario I'm certain it isn't the stabilizer.
__________________ 99 UZJ100, OME 2" lift, 315's, ARB front bar, 4x4 Labs rear bar 95 FZJ80, lockers, off-road monster, 37" Pitbull Rockers ![]() 84 FJ60, stock 76 FJ40, v8 conversion, discs all around, lock-right in back, 35's |
#35 | |
The quick brown fox .....
The other thing you have not mentioned is the lower knuckle studs. Those should be checked, properly torqued, and replaced if necessary. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#36 |
I'm having that problem with my 60 at this time, any disruption Ie. potholes, bumps on the road will get it started, and I have to come to a complete stop.
__________________ José ![]() 92 FJ80 83 FJ60 76 Fj40 74 TY250 83 IT 175 85 TY350 DT250 91 Isuzu P/UP 79 Plymouth Trailduster 72 Jeep Commando |
#37 |
Does your version of Death Wobble do this: steering wheel shake back and forth and doesn't diminish even when you're slowing down? And the frequency of this thing seems to go up and down based on speed? When you look at the wheels, you wonder how in the HELL can they dance like that?
I see that no one mentioned birf housing preload. You might as well do a front end job with all new bushings, bearings, races and torque everything down to spec. As someone stated earlier, it's a combo of many things but aging suspension parts is a large contributor. Tires type/size/wear only accentuates the underlying problem. Marlin has a complete kit for sale as well. Good luck. __________________ TLCA # 15941 KE5LED Currently working PA |
#38 |
ThinkTank Waterboy
lets baseline your suspension bits and pieces and see where there might be an obvious omission that you might have over looked.
Since you have the Slee 6" springs then the obvious included pieces are: Slee's front control arms Adjustable front and rear panhard bars While there are a plethora of other bits to the full kit these would be the main items concerning your death wobble. So Cody, you DO have these on your truck, RIGHT? __________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
#39 |
#40 |
Nope, and nope.
The control arms are just beefier, and push the front axle forward (since lifting it naturally arcs it closer to the vehicle center). The adjustable panhards simply center the axle from side to side (since the stock panhard is a fixed length, and the front axle is pushed out to the left (DS) when lifted). I've seen folks with the full Slee 4" and 6" kits complain of death wobble as well...so while those parts center the axle better at the raised height, this is definately a something is loose, not pulling in a direction, or binding reaction. I just can't locate a loose or damaged part that would allow the violent wobble. I did do a full front axle service, and everything is greased properly, torqued to spec, and all bearings and seals are factory Toyota replacement parts. There is no noticeable play doing the tire push pull check when off the ground. __________________ 97 LX450 - Champagne Silver / 161k / 5.29s / ARB lockers F/R 39" Michelin XML tires, 8" coils / L shocks, 1.5" wheel spacers, Slee caster plates, ARB rack & Safari Snorkel, 60 ARB bullbar, custom sliders, dual swingout rear bumper, Overland RTT on a Monster M100 trailer Copper State Cruisers #045 |
#41 | |
ThinkTank Waterboy
#42 |
Whitey
Geometry is off...
you really need to fix the caster correction, panhards and any angles that need to be addressed due to the lift. By not having these, it's probably exaggerating the issue even more. Why wouldn't you want a better driving cruiser? I honestly can't think of any reason NOT to fix the caster and panhards...unless you want to end up in a ditch and go topless 80.
__________________ ~~~~~~~~~~~~~~~~ 93 FJZ80 Slee 4"/OMEJ, 35's, 4.88's, ARB's, Metal Tech sliders, ARB with M12000, On Board Air, caster plates, DC drive shaft, Pin7, CDL, adjustable rear uppers, A, homemade rear, Slee Skid Plate, extended brakelines, backup camera, Conferr Rack, Hella's, FOR SALE 96 FZJ80 285's OME 's ride
#43 | ||||
#44 |
ThinkTank Waterboy
unfortunately I'm thinking that by now those ridiculous tires have a wear pattern that even if he were to straighten out the geometry the wobble would still be there to some extent.
#45 |
I'm probably way off, but when was the last time you had an alignment done on the old girl? With the way you drive that thing, it couldn't hurt to have someone take a look at it.
__________________ 93 FZJ80, locked, slider-ed, with 35" TRXus MTs. "Go that way, really fast. If something gets in your way, turn." |
Job Listing | Download movies | Mortgage | Loans | Car Credit |
