Old 07-15-08, 11:28 PM   #1
Boz_10's Avatar
Pre cat O2 sensor question
Finally got my catalytic converter installed after someone cut it out. I had a friend install/weld some exhaust piping along with Magnaflow single cat 2.5" in place where the thieves cut the stock one out.
The post cat O2 sensor is in place, but the pre cat O2 sensor is missing. My friend did not know there is a pre cat O2 sensor so he did not make a hole for pre cat O2 to be installed in. Basically, now I only have post cat O2 sensor.
My question is, in my case ('97 FZJ80 w/~ 155K miles), of what importance is the pre cat O2 sensor? Is it all right to drive without one? How hard would it be to drill a hole to place a pre cat O2 sensor in?
I can reset the ECU, but am I doing more harm by not having the correct oxygen/fuel mixture by not having the pre cat O2 sensor? Is my timing, power, or mpg compromised?
Any advice is helpful!!
PS: I searched, but got limited results back.
1997 FZJ80, Locked, almost stock -seldom driven.
1999 Maxima SE 5speed, MM EVO5 18", H&R+ KYB AGX 2.5" drop - DD
Boz_10 is offline   Reply With Quote
Old 07-15-08, 11:42 PM   #2
Firedog's Avatar
I don't know about what damage it could do, but i would imagine that it will effect the mileage, power and possibly the longivity of your new cat.
It's easy enough to replace the bung, just order one from Slee, cut a hole for it and weld it in place (or any muffler shop should be able to do it for you.)
Keith
'77 FJ-40 OME, ARB, SM465, Family cage, 33" Swampers, and lots of rust.
'93 FZJ-80 - Flare-less, Factory Lockers, ARB, OME "J" Lift, IPOR Skid Plate, Toyo 315 MT's, Sliders, Side Protection, and Rear Bumper by M&M Fab (http://mandmfab.com/id55.html)...... This is just the begining...
'02 Chevy 2500 Duramax to tow the toys
http://www.4x4bcds.com/
'92 Toyota Celica GT Convertible - The newest Toy, 113,000 miles and unmolested!
Firedog is offline   Reply With Quote
Old 07-15-08, 11:49 PM   #3
The quick brown fox .....
Beowulf's Avatar
Your truck is OBD-II and both O2 sensors are important. Very important. You will be in a limp-home mode without the O2 sensor so your truck is not running optimal. The timing is retarded, the fuel mapping reverts to a base map. Your power will be down. Your MIL will stay on. You'll never pass emissions.
You should follow firedog's advice and install a bung and O2 sensor.
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Old 07-16-08, 12:30 AM   #4
Boz_10's Avatar
...thanks for the quick reply!!
Sorry for the ignorance, but what is a "bung"?
Old 07-16-08, 12:36 AM   #5
Beowulf's Avatar
From the Slee web site:
http://sleeoffroad.com/products/prod...driveshaft.htm
-B-
Old 07-16-08, 03:06 PM   #6
nicholas's Avatar
I agree, go with the slee bung and an OEM sensor from CDan. Mine had a generic O2 sensor in the front that was worthless. I got horrible gas mileage and I probably added a lot of carbon deposits in my engine as well as possibly shortened my cat's life.
97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying.
nicholas is online now   Reply With Quote
Unsecured Loans | Loans | Bikini Babes | Charity | Free Ringtones
