Random stereo question... (factory "sub" with new head)
So i got my 80... drove it up 1200+ miles from florida to NY this weekend. replaced the stock head with scion t1807, and replaced the front speakers with Pioneer 1642s (stock front were shot).
Here's my question.... the "sub" in the trunk didn't/doesn't work. (speaker completely dead) with the new head (factory amp disconnected) is there signal to that speaker? should I invest in replacing it, or let it die in peace? Thanks! |
#2 | ||
On top of the world...
Replace it with a couple o' these: __________________ Lane Anderson 1991 TRD FJ80, Red, 252k, 3FE Powa ----- Lifted, bumpered, Slee'd, flareless, LineX, 31" BFGs, Dual batts, CB, HIRs, OBA, GPS, OEM CHMSL, roof lights, kickin' sound system, 2-seater - 10 MPG!! __________________________________________ Quote:
#3 | |
However, some have had good success with the Kenwood KSC-SW1.
IH8MUD™ Forums - View Single Post - Stock Location Mounted Powered Sub (bolt-on) and New Stereo __________________ Lane Anderson 1991 TRD FJ80, Red, 252k, 3FE Powa ----- Lifted, bumpered, Slee'd, flareless, LineX, 31" BFGs, Dual batts, CB, HIRs, OBA, GPS, OEM CHMSL, roof lights, kickin' sound system, 2-seater - 10 MPG!! __________________________________________ Quote:
#4 | |
Saw that one. Does that mean that there's still signal going to that hole? So I could put an actual speaker back there to counter all of the high signals from the trunk squeakers and rear doors? |
#5 | ||
No. When you switch out the headunit, the "sub" will stop working. There's a lot of info on this. Search it up, see what you find.
I actually tore out the rear-most tweeters, front-most tweeters, and the "sub", leaving only the 4 door speakers. I replaced those with Kenwoods and put two MTX subs in the back. MUCH better than stock.
[quote=Lka1988;3485927]No. When you switch out the headunit, the "sub" will stop working. There's a lot of info on this. Search it up, see what you find.
Hmmm.... When i replaced the radio in my 80 with the Scion unit the sub still worked. I had replaced it with a JL unit and the amp will barely drive it, but it works! lol I bought an used aftermarket amp to drive it, but i never got around to installing it (bought a used Celica and got too involved with it)
__________________ Keith '77 FJ-40 OME, ARB, SM465, Family cage, 33" Swampers, and lots of rust. '93 FZJ-80 - Flare-less, Factory Lockers, ARB, OME "J" Lift, IPOR Skid Plate, Toyo 315 MT's, Sliders, Side Protection, and Rear Bumper by M&M Fab (http://mandmfab.com/id55.html)...... This is just the begining... '02 Chevy 2500 Duramax to tow the toys http://www.4x4bcds.com/ '92 Toyota Celica GT Convertible - The newest Toy, 113,000 miles and unmolested! |
Maybe some geographical spec differences, but my sub was powered by a seperate min-amp (mounted by the sub), with a pretty weird connector going into the factory head unit (which apprears to be line level). If you want to use the factory sub (or sub location) just run a new wire and remove the old amp.
__________________ 1996 4.5 petrol 80 shipping to Zambia next year 1995 4.5 petrol 80 about the clear the Zambian border, headed for Lusaka 1993 4.5 petrol/LPG 80 street car (jap import) upgraded to a 60221 ECU |
Subscribe today!
Hold on!
With a Scion 1807, your OEM sub WILL WORK. That is, if the driver itself and the rear sub amp are in working order. And of course if you plugged in both of the gray plugs into the new Scion HU. We put an 1807 into our 1995 Land Cruiser and the sub works fine. By the way, we will have both the original sub amp and a BRAND NEW factory subwoofer for sale shortly, as we are continuing the audio project with a new setup back there. Let me know if you want to have a working sub setup and I'll save the components for you. Dave __________________ David Zartman Publisher 4WD Toyota Owner Magazine http://www.4wdtoyotaowner.com 1995 FZJ80, 1970 FJ40, 1999 Tacoma, 1979 FJ40, 1986 4Runner, 1973 FJ40, 2000 4Runner, 1984 hardcore buggy, 2007 FJ Cruiser Baja racer |
#9 | |
if the stock sub/amp does something for the sound, i'm in. on my old Saab, there was a gain and frequency adjustment on the stock 'sub' amp that could be played with if you took the amp apart... and how the heck do you get the rear speaker out of there anyway? thanks! Larry |
#10 | |||||
![]() Quote:
#11 | |
is coming around!Dave Last edited by fzjconvert; 07-16-08 at 11:42 AM. |
#12 |
#13 | |
thanks! |
#14 | |
Dave |
#15 |
We Have Assumed Control
Chalk another one up for factory sub working with my scion HU.
__________________ Scott- 97 40th S/C'd Landtank MAF WBO2 Locked CDL OME 850/860's shocks NITTO's air bags heated seats 98 Tacoma S/C'd w/fuel mods piggyback'd |
#16 | |
There are clips lined around the edge of the whole panel. Get your fingers behind the top edge and pull LIGHTLY, it will pop out.
It might be tough to pull off for the first time, and may sound like something broke when it pops. __________________ Lane Anderson 1991 TRD FJ80, Red, 252k, 3FE Powa ----- Lifted, bumpered, Slee'd, flareless, LineX, 31" BFGs, Dual batts, CB, HIRs, OBA, GPS, OEM CHMSL, roof lights, kickin' sound system, 2-seater - 10 MPG!! __________________________________________ Quote:
#17 |
Subscribe today!
Also one tip to help getting the rear interior panel off to access the sub is: remove the two closest screws that hold down the chrome floor strip. That will help give the plastic panel a little extra wiggle room.
Then it's three bolts to take off the sub/amp assembly. Remember to unplug the sub amp from the harness first! As for sound, yes, the sub does its job. Not like a powered 12", but it does add bass. __________________ David Zartman Publisher 4WD Toyota Owner Magazine http://www.4wdtoyotaowner.com 1995 FZJ80, 1970 FJ40, 1999 Tacoma, 1979 FJ40, 1986 4Runner, 1973 FJ40, 2000 4Runner, 1984 hardcore buggy, 2007 FJ Cruiser Baja racer |
Home Insurance | Loans | Free Advertising | Mobile Phones | Bad Credit Mortgages |
