Power inverter question
Does anybody have a Xantrex 1000 watt power inverter in their truck? I bought one of these from Costco ($39.99ish) to power my laptop and other junk I don't really need in my truck. I have already run the 4G welding cable from the battery to underneath the driver's seat and am ready to complete the install, but before I buy my fuse holder and fuse (these things are surprisingly spendy) I wanted to see how large of a fuse others have used. Is the fuse size dictated by the load on the inverter or by the length and guage of wire from the battery to the inverter?Any thoughts __________________ Blackdog 2nd owner '97 nonlocker, stock sus., 285/16 Nitto TG's, extra DC outlets, 1000wt inverter,Sony stereo,CDL (hazard switch),7pin mod,Toyota serviced (til I got it), no real mods (yet) ![]() "I KNOW WHAT YOU'RE TRYING TO DO! YOU'RE TRYING TO MAKE ME LOOK STUPID!!!!!!! Last edited by Blackdog; 07-16-08 at 09:34 PM. |
The one I installed said to use a 75AMP fuse as close to the battery as possible.
BUT... I would read through the instructions. These Modified Sine Inverters don't do well with laptops and specifically rechargeable batteries. __________________ 70 FJ40-sold, worst day of my life 79 TOY 4WD pup-stolen, 2nd worst day of my life 91 4Runner 4WD-burned to ground, 3rd worst day of my life 83 FJ60- suckiest day of my life 97 LX450, 221k, non-locked. Expedition vehicle in progress. Factory rack removed ![]() ふざけんなよ! |
the fuse is typically sized for the wire, to prevent fires.
But there is no real harm in using a smaller fuse. Just be sure it is at last large enough for the demand from the stuff plugged in, yet smaller than the wire's capacity. 50amps probably more than enough. __________________ 91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Hankook MT's 31x10.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns. WTB: Tan DS mirror & housing '88 HJ60, "Louie" For Sale in Costa Rica.
1000 Watts at 12V is ~83 amps. Now you probably aren't going to ever pull the full 1000 and you should be operating at a bit higher than 12V (say 14) which will also reduce the actual amperage draw. I would go with the 75 amp fuse as NTXTACY suggested. You might consider a breaker instead of a fuse.
4 gauge wire is good for 100 amps (at high ambient temp and 10' length) so you should be good to go with what you ran. __________________ 1985 4Runner - ROTM WarDamnEagle's 85 4Runner 1997 FZJ80 - locked and stock 2007 HDJ100 - DD .....and these are just the Toyotas |
Ignore my previous recommendation of 50amps. It is too conservative. Definitely better to use a breaker than a fuse if the cost isn't too much higher.
Thanks for the posts. I have settled on a "maxi-fuse" blade type setup. It came with a 40 and 80 amp fuse in the pack. I believe the 80a should serve my purpose well. If I can get my digicam to work I will post up som pics of the install. Still have a few more pieces on the shopping list but I hope to have it working by the weekend.
__________________ Blackdog 2nd owner '97 nonlocker, stock sus., 285/16 Nitto TG's, extra DC outlets, 1000wt inverter,Sony stereo,CDL (hazard switch),7pin mod,Toyota serviced (til I got it), no real mods (yet) ![]() "I KNOW WHAT YOU'RE TRYING TO DO! YOU'RE TRYING TO MAKE ME LOOK STUPID!!!!!!! |
#7 | |
The quick brown fox .....
-B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. Last edited by Beowulf; 07-16-08 at 10:43 PM. |
Singapore Shopping Guide | Credit Card Debt Consolidation | Credit Card Consolidation | Loans | Credit Cards |
