Old 07-14-08, 04:30 AM   #1
barCruiser's Avatar
Slee 4" lift and Driveline Vibes
Ok, so I just installed a slee 4" lift this past weekend, which was a breeze thanks to the great instructions and awesome components of the lift. I installed the supplied new double cardan driveshaft for the front, but am still getting some pretty decent driveline vibes at all speeds (especially under 10mph) . I know my rear u-joints are pretty much toast because my truck has 130k on the clock and I don't believe they have ever been changed. My question is this, are the mojority of people with 4" lifts out there running the stock rear driveshaft or a double cardan rear driveshaft. Because I don't want to replace the rear u-joints only to still have some driveline vibes. Thanks in advance for the help.
1996 LX450, factory lockers, slee 4", 4.88, 315's
1979 Jeep CJ7, 3" lift, 33" BFG m/t, sbc 350, front/rear lockers
barCruiser is offline   Reply With Quote
Old 07-14-08, 04:39 AM   #2
ThinkTank Waterboy
landtank's Avatar
The rear stays stock as far as I know. Don't over look a bad slip yoke on that shaft either. I've found a few. If it was my truck I would go ahead and change out the entire rear shaft since the cost of the new joints are going to be a good part of a new one.
Rick Bigelow
'96 215k
Groveland MA 01834
landtank is online now   Reply With Quote
Old 07-14-08, 04:46 AM   #3
barCruiser's Avatar
how much do new joints cost from C-dan?
Old 07-14-08, 10:10 AM   #4
Young and Dumb apparently
alkaline747trio's Avatar
Did you try the stock shaft?
'92 - 3FE POWER'D!
-- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 35" TrXus STS Street/38.5x11 Boggers Trail, 180k.
'85 Honda Accord - 55MPG!!!
-- No air filter, Custom Burple (blue and purple) Paint.
Upstate Cruisers
alkaline747trio is offline   Reply With Quote
Old 07-14-08, 11:18 AM   #5
DUM8HIT
T Y L E R's Avatar
barcruiser,
My lift is listed in my sig. As mentioned, try using the stock DS. A slightly different approach to a lift height similar to your own. In this case, I installed Slee's longer control arms, and was able to use the stock driveshaft. The only vibes whatsoever are from the IROKS once in a while before the balancing powder distributes.
Every truck is a tad different, but at least there are alternative solutions to fit in most cases.
TY
Hybrid suspension - Slee 4" Front/OME863 Rear, Slee Front control arms, Slee DIY adjustable panhards, Slee sliders, 36X13.5R16 IROK radials on AR Black Trenches, 1.5" Trail-Gear spacers, Toughbook CF74 with GPS etc, sans roofrack, jumpseats, lockers. Clear lenses abound
T Y L E R is offline   Reply With Quote
Old 07-14-08, 03:25 PM   #6
clarkrw3's Avatar
TLCA# 15560
I use a stock rear drive shaft on a slee 6"...
'96 LX 450 67K locked, ARB Bull Bar, Slee 6", Slee step sliders, Slee rear tire carrier, slee skid, CDL, 315/75-16 MTR's, etc. ROTW
'07 FJ Cruiser locked, 285/70-17 MTR's
Copper State Cruisers #38
TLCA #15560
Rob Clark
clarkrw3 is offline   Reply With Quote
Personal Loans | Cheap Car Insurance | Remortgaging | Buy PSP | Credit Cards UK
