OME Medium Stink bug questions
From what I have read and seen, it appears that you end up with some stink bug action (about 1'' higher in the rear) when using OME 851/860 springs with stock weight (no after market bumpers, batteries, winches, sliders, drawers). I also removed my 3rd row and I usually leave my spare 285 off the under carrier unless I am on a road trip. I would like to be level after I install this kit next week since I rarely carry any weight or tow anything.
Could I accomplish equal f/r suspension height by using the 1'' Mr. Gasket or preferably the Slee 1'' spacers? Or would it be a little bulldogged (higher in the front) by going this route? Thanks! __________________ 97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying. |
Hmmm... Why don't you try it and let me know
I'm about to install the exact same setup on my rig and wondered the same thing. Before deciding on any particular kit, I searched around quite a bit. Man-a-Fre offers a couple options that they call "level-stance kits", that basically uses different springs to correct for that. They have these kits in different lift heights too. I decided to just go with the OME medium kit from Slee. I did ask about the stinkbug effect while on the phone with Slee. The answer I got was a kind of vague, "it depends on how you look at it" kind of answer. I got to thinking though, it is just a matter of how you look at it. If it sits a little high in the rear, for your tastes, I guess a spacer up front would be in order. __________________ sb '93 FZJ80: factory lockers, CDL switch/7-pin mod, OME 851/860, Toyo Open Country 285's, George's LED's, and tunes by Alpine. |
The raked stance is how most trucks come from the factory including the 80 series. Plus, with the raked stance, when you are carrying a heavy load you don't look like your springs are worn in the rear.
__________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" Toyo M/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: ??? |
And it can sefely be driven loaded. Are you buying a lift for the look or for the function? Honestly I am doing for both, and dont liek a huge stink bug, but some into too bad. Do it and then post up pics.
__________________ '93 FZJ 32K miles - 850/863's, 285 MTR's & Lightforce 240's waiting. '89 FJ62 - 4" Alcan, 33" BFG MT's, 4.88's, Lockright (rear), 4runner calipers, & 3' firestick. Cruise in the garage. FOR SALE! '97 4Runner SR5 - 4x4, leather, '06 4runner rims, 265/70/17 Toyo AT, TJM T-15, 3 baby seats. (Wife's DD) '83 FJ60 - DooDoo Brown in and out FOR SALE! '63 Biscayne Wagon - Kandy Green and Tweed. Family Wagon 3rd row in the garage. Erskine College Upstate Cruisers |
I put the OME 851/860 in mine, as well as 10mm OME spacers up front and still ended up with a small 'stink bug effect'. I think that it looks OK but would rather level. As stated before the only thing is that when loaded I now sit level, so I'll leave it alone. I would post up pics but mine is in my garage with the injectors out of it for a few days (injectors being rebuilt).
__________________ Brad '92 HDJ81 VX Limited - lifted, etc, etc, etc, and the best part - the turbo diesel! |
I am about to start a new thread on my OME install this weekend. Maybe what I found out will help.
Curt __________________ '96 LC, 170K & counting DD, OME 850/863, 285's, custom front bumper in progress, empty wallet.... Any twelve people who cannot get themselves out of jury duty are not my peers! |
Mine is also a bit higher in back until its loaded and then its a bit low in back. Lifting the front would not help if you occasionally carry a load.
__________________ Doug -Bone stock IFS 94 22re mini (except for bumpers, sliders, skidplates, rear locker, 1" body lift w/trimmed fenders and 33" tires. -93 fzj80, locked, OME 851/860, deflared/linered, metaltech sliders, 285 Cooper stt's, http://tinyurl.com/6ovjzj -fj62 replaced by the fzj80 |
I've got mediums and yes, there is quite a stinkbug effect, but it doesn't bother me. When it's loaded it sits level. I wouldn't want it to be low in the back. If you don't want the stinkbug effect, look into putting heavies in the front and mediums in the back. Lots have done this. You can do a search. From what I understand the spring rate is the same between heavies and mediums. The only difference is the length.
Scott __________________ 1994 FZJ80, 205k, locked, OME 2.5, 285/75/16 NTGs, cdl switch, pin-7, 100 series pads, slee sliders 1976 FJ40 mileage unknown, broken #1 piston rod. Sitting in my apt parking lot until mgmt asks me to move it. |
#9 | |
Present
With all that in mind, consider how the additional 1" of lift up front will effect your caster. In my case, even with an ARB on the front, the yellow OME bushings did not provide enough correction. I'm using the slee blue bushings installed with landtanks templates. As said above, the easiest route is heavies up front and mediums in the rear. You won't have a need for spacers but you will still face the caster issues. |
#10 |
Thanks for all of the responses. Like I mentioned, I rarely ever carry a load in the rear, maybe 3 times a year and for short distances. I thought about the heavy's in the front, but I do not have any weight in the front, and Slee and others have advised against that and I have done hours worth of searches that seem to say the same thing.
I guess the general consensus is that OME 851/860 setup will yield about an inch of Stinkbug in the rear. I suppose I will look into getting about a one inch or less spacer to make it level. I will definitely post pics when I am done. __________________ 97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying. |
#11 | |
Present
http://forum.ih8mud.com/80-series-te...m-springs.html |
#12 | |
I have read that thread a few times. Frankies offroad: two diffrent springs of the same rate one being longer,the longer spring will still have a stiffer rate because there will be more coils for compresion,coil spring gain rate as the coils are compresed. so more coils to compress more actual spring rate. This seems to make perfect sense. Adding a spacer is not effectively modifying the spring in any way. It's just adding height to the vehicle. IMO it would yield close to the same effect as welding spring perches lower on the frame or higher on the axle except for the mr. gasket/slee spacers may compress a little upon compression. I'll make a post after I put my springs on. __________________ 97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying. |
Mortgages | Credit Cards | Mortgage Calculator | Credit Cards | American Flags |
