07-12-08, 04:54 PM
fatherofdaughterofromer
Landtank does it again - Sway Bar links
Broke my front and rear swaybars on the Rubicon. One link in the back and the bracket from the front driver side dismounted from the axle.
How timely that I get back and see this thread
From his thread
So I put these puppies on today. Went on real easy and they are real beefy compared to the OEM links and brackets
Put the front brackets on so they could be welded on Monday.
Since the only time I broke one was on the Rubicon, I may have to go back there someday to fully test these.
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
07-12-08, 04:55 PM
The rear OEM link is a pencil thick peice of metal
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
07-14-08, 09:15 PM
Got the front welded on and installed and had another pricelss lesson you will never forget.
I had the swaybar completely off and the brackets that hold it to the drop blocks had come off. So I am looking to make sure the big droop goes under the drive shaft. After the full install the swaybar was grinding against the steering linkage. Turns out I had the swaybar on upside down. Dooooh!
I'll add that to watch out for that plastic nipple on top of the radiator.
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
07-14-08, 09:56 PM
Test them for you
Hey Romer,
Send me a pair, I would be happy to test them for you on the Rubicon.
The Claw
07-14-08, 11:30 PM
I ruin surprises.
Hey Romer,
Who is Lantank?
As always, nice product from Rick!
07-15-08, 07:12 AM
Originally Posted by mot
Hey Romer,
Who is Lantank?
What are you talking about MOT
(Nice being the moderator and able to fix thread titles)
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
07-15-08, 10:29 AM
beside La Caja China
Are they extended for a lift when using them on highway?
Curious, Landtank, did you ever tweak out the calipers from the 4rnr to work in an 80?
07-15-08, 11:44 AM
www.unwiredadventures.com
These look great!
I just ordered my set.
07-15-08, 11:50 AM
They went on fine with my lift, 2" drop blocks etc.
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
07-15-08, 12:19 PM
#10 (permalink)
ThinkTank Waterboy
Not yet, since I twisted up my sway bar links earlier this year and hearing issues with the front brackets this got moved to the head of the line. But the brake upgrade isn't dead, just resting.
Rick Bigelow
'96 215k
Groveland MA 01834
07-15-08, 02:51 PM
#11 (permalink)
not an addict
now if only he made a fix for the sideways ones. one of my "sockets" is toast.
"to learn is to teach someone else"
only four cruisers left
07-15-08, 03:04 PM
#12 (permalink)
What about adding a disconnect to it?:
ふざけんなよ!
07-15-08, 03:04 PM
#13 (permalink)
Parts Geek, M1 Mechanic
Those "socket" thingys are spendy as hell to boot. I wish the frame had the captive-threaded holes in the bottom to change over to the bottom-mount style. I'm not convinced that nutserts would be strong enough to handle. it.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
07-15-08, 03:06 PM
#14 (permalink)
Originally Posted by NLXTACY
The problem is the bar is still vulnerable to rock impacts. It's best, for a trail like Rubicon, to get them out from under the truck altogther.
07-15-08, 03:28 PM
#15 (permalink)
ThinkTank Waterboy
buy Slee's drop brackets and get welding, it's not like you need to remove them for anything.
If this is something people wanted I could come up with a cardboard template for positioning the bracket onto the frame.
Rick Bigelow
'96 215k
Groveland MA 01834
07-15-08, 03:38 PM
#16 (permalink)
The "socket" is a factory piece that is retained when using the Slee brackets. It is the 93-95 version of the piece you have made.
07-15-08, 04:04 PM
#17 (permalink)
ThinkTank Waterboy
What I'm saying is to buy the bracket for the 96/97 setup, weld it to the underside of the frame and change over. Aren't the sway bars themselves the same?
Rick Bigelow
'96 215k
Groveland MA 01834
07-15-08, 04:07 PM
#18 (permalink)
The bar is the same.
I would be reluctant to weld to the frame. I am not a big fan of that. In addition, when (as opposed to if ) you trash that bracket you would have to cut it off and start over.
07-15-08, 04:46 PM
#19 (permalink)
ThinkTank Waterboy
How many of these brackets do you think have been trashed over the years? I like the bolt solution but just offering an out if someone wanted the stronger link.
Rick Bigelow
'96 215k
Groveland MA 01834
07-15-08, 04:56 PM
#20 (permalink)
The reason I like it
ふざけんなよ!
07-15-08, 05:00 PM
#21 (permalink)
I have sold some. But, of course, they are the short stockers. You would have to ask Christo how often he repeat-sells his extended ones.
07-16-08, 01:36 PM
#22 (permalink)
not an addict
i made my own extended ones. the p.o. welded the stock ones to flat stock and it broke at the welds. mine should hold up pretty dang good. just got to get the socket thingy and tap the frame again so i can put the other side on.
07-16-08, 02:06 PM
#23 (permalink)
07-16-08, 07:40 PM
#24 (permalink)
the p.o. welded the stock ones to flat stock and it broke at the welds. .
that PO should take a shop class
07-16-08, 09:11 PM
#25 (permalink)
You know what they say
Those who can do
Those who can't teach
(For those wondering, the PO is an Automotive Shop teacher at a HS)
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
07-17-08, 08:39 AM
#26 (permalink)
Those who can do
Those who can't teach....teach shop?
07-17-08, 01:24 PM
#27 (permalink)
gumby, where are you? under the bus? hahahaha
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
09-08-08, 05:54 PM
#28 (permalink)
USPS dropped these off today:
They'll be installed before my next trip.
Thanks!
