LinkBack (4) | Thread Tools | Display Modes |
#121 |
Now that a fresh batch of s/chargers are hitting the street and folk are planning on their installs, I wrote up my install experience (several years ago) -> Kazuma Supercharger Install
Might help folk plan their install and prepare for what awaits them. I have since replaced the ringed fan (wonder if that is still supplied in the new kit) with a non-ringed fan through Dan and also a new blue fan clutch. Also, before installing your new s/chargers please make sure that your cooling system is in tip top shape and that you have no other engine/drivetrain issues. Our 80's are a lot older and higher mileage than when the s/c was first available... cheers, george. __________________ where ever you go, there you are.... '97 S/C White CE, locked^3, sliders,arb,kaymar, m12000,dual batteries, LEDs, etc..... ki6ibx http://www.george4wd.taskled.com |
#122 |
Great info George !, I am researching as I just bought my SC and will install it myself (I have no money left
), plus it is 50% of the fun. The other 50% is going fast and furious ![]() It sounds you ran into some troubles, I hope some of those are fixed in the new kit (i.e it will be nice to get pre-made extension harness for the TPS/IAC cables). I will make a tool like yours for the Crank pulley bolt. I was wondering if you used a 1/2" breaker bar to get it loose?. I've read that everybody uses a 3/4", but I don't have one. Also, does anybody knows if places like Napa, Autozone, etc? loan a big enough torque wrench for the crank bolt ? __________________ 97 White S/C S80 LC, 166K, Electric OEM lockers, ScanGauge, OME 2.5 Heavy F&R, 285 BFGoodrich AT, ARB Bar w/Slee AC drier plate, Warn 9.5XP, Slee Transfer Skid Plate, Slee Light Harness Upgrade+Aux lights, KC Daylighters, Interior LEDs, ARB Snorkel, all synth, Interior Winch control, CDL, OEM Hand Throttle, Inverter w/Matrix Switch, SOR seat covers. |
#123 | |
The quick brown fox .....
I agree that someone should start a thread requesting comments on the reliability of the S/C. That would be interesting and relevant since this second run is now available. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#124 |
I wonder if this S/C belt is the same as the old Kazuma S/C one? my toyota dealer cant get a belt for it, and I need one since it came off at the drag strip.
#125 |
What would typical acceleration times be vs stock on 0-60 and 1/4 mile. I'm just curious as to the improvement vs stock and have not seen any threads in search with this info.
les |
#126 |
7500 lb rig here with original TRD S/C ran the 1/4 in a high 15.
#127 |
What was stock
#128 |
not sure on stock numbers. didnt own the truck then.
sorry to hijack the thread |
#129 |
Kneel for the Shaman
I have never done the test you ask. It is a lot faster than stock.
I do have the two datapoints. With the SC you are as fast as a 100 series with a V8. With a SC towing a 3000 lb trailer up a mtn pass, you can still go faster than a stock 80 not towing. At least that was my experiance on the way to and from Moab the last two years |
#130 |
hi all!
my name is david thomas i work at a dealership parts dept.they have just reannounced availability thru a pant bulletin(08-59)as follows.. TRD Supercharger 4.5L I landcruiser Roots-type rotor pack Made from all new tooling(?) 50-state emissions legal fits 1995-1997 landcruiser m.s.r.p. $3750.00 installation time of approx.7-8 hours 12month 12,000 mile warranty UP TO 50% HP IMPROVEMENT dyno chart on pant bulleton shows 160 hp @4100-4200r.p.m... |
#131 | |
I know that when adding a SC that you're obviously not concerned about fuel conservation but with fuel prices like they are now I can't help but ask. Bases on the numbers that have been posted on these new SC's, do they seem similar to the power the old SC's produced? If so, can anyone give some before SC and after numbers for gas mileage? I'm getting very antsy but I'm afraid that the will divorce me if I pull the trigger on this one.
__________________ 97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying. |
#132 |
Nicholas -
I don't know specific numbers...but, based on the feedback everyone has offered about the S/C I went on faith alone. I have not heard anyone say..."yep bought the S/C...wish I hadn't." I'll see if I can get a dyno done on my LC now and then when I get back and get the S/C on I'll run it again. I believe there is a all wheel drive dyno in Memphis...if I remember correctly. Cheers. - Mark __________________ 1997 FZJ80 - Flareless, Lined, MetalTech Sliders, LandTank MAF, PM'd to the Gills, 285 BFG ATs, Alpine, and XM but, just starting (it's sitting in CONUS...a bit lonely..awaiting customization and ready to get Super Charged) 1997 BMW 528i - AC Schnitzer'd out (right-hand drive) 1988 E28 M5 - Currently being restored in the US "It is not the critic that counts" TR - 1910 http://faragesgarage.blogspot.com http://www.flickr.com/photos/mrgarage |
#133 | |
#134 |
My first LX 450 had SC installed at around 60K miles, and I bought it at 130K. No problem at all!!!
__________________ 1996 Kazu 96 LX450, 97LX450 |
#135 | ||
Regarding MPG -
I got about 16+ on all freeway and Local is about 13 to 15 on my last stock LX450 with SuperCharger. I will say, it’s very comparable to NA engine. Quote:
More about MPG http://forum.ih8mud.com/80-series-te...-fuel-run.html __________________ 1996 Kazu 96 LX450, 97LX450 Last edited by Ting; 07-31-08 at 11:47 PM. |
#136 |
tlcwagons.org
Romer,
I'm curious about how the truck performs on long freeway grades or mountain roads. That is the time I really wish for more power. For example taking the 330fwy up to Big Bear, Ca (7,000' of twisting elevation gain w/ the occaisional passing lane) - there is a sign at the bottom saying "turn off AC to avoid overheating" and I've seen many pull off w/ overheating problems. does the SC cause more heating up of the engine with constant boost like this? It is about an hour of this type of climb. What do you feel are the real-world drawbacks of the SC? thanks |
#137 |
*cough*Dieselswap*cough*
__________________ '97 Lexus LX450 - CDL/7 Pin | Factory cup holder | Black LX wheels | 305/70 Toyo M/T | Optima Redtop | Auto-Up mod | George's LEDs | 1.5" Spacers | |
#138 | |
#139 |
ThinkTank Waterboy
I wanted one like everyone else. I figured it was a Toyota product and expected it to be of a certain level of quality. I looked into it and IMO it falls short of what I would want on my truck.
There is no intercooler with the kit There is nothing in the way of fuel management, not that it's an issue any more. And the reports of engines running hot are quite common. So yes you can bolt this kit on as is and it will work but as owners have reported you will likely start wanting to add additional components to help with it's short comings. If I'm going to do all that then I'll just do my own thing from the ground up. I really enjoy the process of engineering something and the satisfaction I get from doing it myself, but going in and fixing someone else's design flaws or short comings bugs the hell out of me. If I'm going to buy a bolt on kit then that's what I expect, bolt it on and it's done. Like anything else, not everything is for everyone and this just isn't for me. __________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
#140 | |
But for scooting around town, it was a BLAST. There are a lot of ricers in my neighborhood, I used to love to scare them and shoot a 3 ton truck out in front of them. __________________ Cory Fillmore TLCA Western Individual Representative 99 UZJ 100 Series Wheels FOR SALE-CLICK HERE |
#141 | |
tlcwagons.org
![]() turbocruiser, I agree the turbo is better but SC = $3500 AVO turbo = $7400 the SC sounds expensive until you price the turbo... |
#142 | ||
I have read George's install page and have seen his list of tools/materials. The install seems to be within my range of abilities, and it will probably will take me 2-3 times as long (at least 2 full Saturdays). So my question is beside the tools/materials George recommends are there any "hidden" costs to adding a S/C? $3300+shipping from Dan +tools/locktite/shinkwrap etc. +2 Saturdays time and I'm in business? My rig has 141K and had a Lexus Dealer installed Head Gasket at about 100K by the PO. I drive like a grandpa so I'm hoping adding an S/C won't blow my engine Quote:
. I am seriously contemplating buying one of these new S/C kits. Can anyone give me some serious reasons as to why I shouldn't buy a S/C besides potentially having a very angry ? Dan said my secret is safe with him so unless these things make a "blow off" sound like those rice rocket turbo's do, I should be in the clear.
#143 |
They do make a lovely high-pitched whine/vacuum noise on a quiet road in the cool, morning air at WOT.
#144 |
Edit: It took me a while to write that last post.
Landtank: Thanks for your input. Those are definitely things to consider. Maybe I should just put around in the old NA 1FZ-FE until I could either do a turbo or maybe swap the engine out for something else. This is one heck of a tough decision. __________________ 97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying. |
#145 |
Nicholas - If you are in Nor Cal, I will let you test drive mine.
#146 | |
Who am I kidding, I'm going to hell. __________________ 97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying. |
#147 | |
