LinkBack (4) Thread Tools Display Modes
Old 07-17-08, 03:46 PM   #61
All we can do wait., but it's not likethere was every anything wrong with the old design, could it be improved, of course, but I'll take what I can get.
spencevans is offline   Reply With Quote
Old 07-21-08, 11:39 AM   #62
Anyone seen a release date yet? Don't want to call my parts guy every week until it comes in and bother him...but I'm hot to trot for it.
'97 LX-450-TRD Supercharger sitting on the garage floor
'88 FJ62 rustbucket power accessory donor 4 the '87, ...was put to death 8/16/08, R.I.P. Still got the motor and misc parts though!!!
'87 FJ60, 350, NV4500, EFI, SOLD July '08, Happily hitting trails in S/W Colorado now!
'96 civic EX 4DR 5SP
SBFJ60FIG is offline   Reply With Quote
Old 07-21-08, 04:10 PM   #63
Parts Shaman (per Romer)
cruiserdan's Avatar
TLCA# 11332
Nope.
When I know, you'll know.
Old 07-21-08, 10:09 PM   #64
How many bananas?
General question....how many bananas was the installation of the original TRD supercharger kit? Any special training or tools needed?
cmtierney is offline   Reply With Quote
Old 07-21-08, 10:56 PM   #65
cruiserdan's Avatar
TLCA# 11332
You will need a 30 mm socket, a 32 mm socket, a chain wrench and a torque wench that goes to 309 lb-ft.
Old 07-22-08, 12:58 AM   #66
Duh...crankshaft pulley has to come off of course. That should be anything but fun.
Old 07-22-08, 11:16 AM   #67
cruiserdan's Avatar
TLCA# 11332
You dont have to remove the pulley, just the bolt. However it would probably be a good idea to change the crank seal since you are that close to it.
Old 07-22-08, 04:43 PM   #68
natvet's Avatar
TLCA# 18169
right vehicle
What would the minimum requirements for an 80 to be considered a good candidate for a SC. Example .....miles ,OEM head gasket( or not) ..........other considerations or things that should be checked out on the truck prior to considering a SC
Nathan
73 FJ40
1997 FZJ80 DD
Did you ever notice that when you blow in a dog's face, he gets mad at you, but when you take him for a car ride, he sticks his head out the window?
natvet is offline   Reply With Quote
Old 07-23-08, 12:12 AM   #69
I don't think anyone, unless they have a crystal ball, could answer this. And if you put a S/C on and the head gasket blew you just put on a new one. No biggie. Except that you don't just put the gasket under the hood and it finds its way to the correct location. Installation is a bit of a chore.
Old 07-23-08, 12:16 AM   #70
Last crank pulley bolt I had to take off...on Sunday...broke one screwdriver I used to lock it in place. Just bent the second one before letting go.
Last FZJ80 pulley/bolt I had to get off....uh yeah, ended up having the machine shop get it off for me it was so thoroughly stuck on!
Hope I have better luck next time!
Old 07-23-08, 09:48 AM   #71
cruiserdan's Avatar
TLCA# 11332
3/4 inch drive breaker bar jammed against the inner RH frame rail. Bump the starter and it's done.
NOTE:
this is a potentially dangerous method and it's possible to break things and/or people in the process. DO NOT attempt it unless you are certain about what you are doing and do so ENTIRELY AT YOUR OWN RISK
Old 07-23-08, 05:18 PM   #72
NOTE:
I like the lawyer-like vernacular here...I live for danger cannot wait to try this!
Smart though, very smart indeed!
Old 07-23-08, 05:33 PM   #73
cruiserdan's Avatar
TLCA# 11332
Can't help it.
Me mum's an attorney, still in continous private practice after ~50 years.
Old 07-24-08, 04:23 PM   #74
Ting's Avatar
I haven’t driven my truck for a month now. I took it a spin yesterday and wow…
It felt like a sport car.
1996 Kazu
96 LX450, 97LX450
Ting is offline   Reply With Quote
Old 07-24-08, 04:31 PM   #75
[quote=cruiserdan;3505337]3/4 inch drive breaker bar jammed against the inner RH frame rail. Bump the starter and it's done.
When you tighten it has anyone ever just put a little light threadlocker on and just gotten the bolt good and tight? I just rebuilt a 1FZ last year, sold it to a forum member, he and I have put on over 30k since I did the rebuild and he's had no issues. If I recall I locked the crank on the engine stand from the rear, and just made it as tight as I could. I know that it was not the spec of what? 300 FT LBS?
Old 07-24-08, 04:35 PM   #76
cruiserdan's Avatar
TLCA# 11332
309 lb-ft actually.
It's that high because the oil pump drive gear is not keyed to the crank, the pully clamps it in place. If it's not tight the gear will slip and you will lose oil pressure and power steering assist.
Old 07-24-08, 04:40 PM   #77
ThinkTank Waterboy
landtank's Avatar
309 lb-ft actually.
Ask Romer about this after his SC install. This needs to be where it ought to be.
Rick Bigelow
'96 215k
Groveland MA 01834
landtank is online now   Reply With Quote
Old 07-24-08, 10:01 PM   #78
Kneel for the Shaman
Romer's Avatar
TLCA# 13968
Yup, my crankbolt was not properly torqued and when wheeling it loosened up on me and my power steering was almost gone. The oil pressure went low. Fortunately, I was avble to stop and get the right wrench on the way home to tighten it to bring my steering back full and return the oil pressure to normal. Got it properly torqued the next day.
I have two 80's that are in excellent condition. On my daughters 80, I just improved the exhaust system to a 3" pipe and new muffler, Landtank MAF and a few other items and it runs great. Still, nothing like jumpring behind the wheel of my supercharged truck.
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline   Reply With Quote
Old 07-24-08, 10:56 PM   #79
fjfar80's Avatar
Hopefully soon I will have that experience...jumping into a super charged 80...already bought LandTank's MAF and ordering the new sensor from CDan. I'll have so many goodies waiting for me back in the States that it will be like Christmas...
1997 FZJ80 - Flareless, Lined, MetalTech Sliders, LandTank MAF, PM'd to the Gills, 285 BFG ATs, Alpine, and XM but, just starting (it's sitting in CONUS...a bit lonely..awaiting customization and ready to get Super Charged)
1997 BMW 528i - AC Schnitzer'd out (right-hand drive)
1988 E28 M5 - Currently being restored in the US
"It is not the critic that counts" TR - 1910
http://faragesgarage.blogspot.com
http://www.flickr.com/photos/mrgarage
fjfar80 is offline   Reply With Quote
Old 07-24-08, 11:11 PM   #80
Ting's Avatar
what sensor are you talking ?
1996 Kazu
96 LX450, 97LX450
Old 07-28-08, 04:41 PM   #81
Anything yet on a release date???
I picked up my LX450 and I'm quite excited to begin force-feeding it!!!!
C-Dan, where did you pick up your 3/4 breaker bar? I got one at Sears for my early cruiser's crank pulley bolt but it's way too short to make it to the frame rail and don't feel like flagging down the Snap-On man!?
Old 07-28-08, 04:47 PM   #82
fzjconvert's Avatar
C-Dan, where did you pick up your 3/4 breaker bar? I got one at Sears for my early cruiser's crank pulley bolt but it's way too short to make it to the frame rail!?
Go to the hardware store, get a piece of pipe and slid it over the end. A little race tape and you saved yourself a $100 bucks or more.
Dave
fzjconvert is offline   Reply With Quote
Old 07-28-08, 05:55 PM   #83
cruiserdan's Avatar
TLCA# 11332
That's called a "cheater" by the way.
It does add a degree of "not quite right" to something that is already "not quite right"....
If one chooses to add a cheater to an already potentially dangerous tactic, please do excercise extreme caution.
Old 07-29-08, 09:53 AM   #84
cruiserdan's Avatar
TLCA# 11332
OK.................
There are 48 kits available at the moment and 12 more in transit.
The published list price is $3,750.00. I will have them available for order for $3,299.00 plus the ride on Brown.
Old 07-29-08, 10:11 AM   #85
Hah...my parts guy in Chicago just checked and still nothing is showing up! Ugh!
And yeah I already thought about a cheater bar and too concluded that that was a very very VERY bad idea.
Dan...do you know how long it will take for the number to start showing up? My buddy says it's still "D" discontinued and no depot shows any in stock at the moment.
Tomorrow maybe??? I'd love to be putting this thing on over the weekend once I'm done at the E.R. for my broken wrist and arm from getting the crank pulley bolt off with your MacGyver method!!!
Old 07-29-08, 10:15 AM   #86
cruiserdan's Avatar
TLCA# 11332
I just told you there are 48 available and 12 in transit.
Old 07-29-08, 10:25 AM   #87
I know...sorry...but he checked to try to place an order and however he checks stock at the depot via the Toyo computers quantity available to him is currently zero. So what's a guy to do?
I want it so badly, probably more than Ralphie wanted his "official Red Rider bee bee gun with the combine stock and pump action handle" in A Christmas Story!!!!!
And I don't care if I'll shoot my eye out, need premium gas, climb tall mountains without needing to kill O.D., I wanna tow my boat at supersonic speeds uphill!!!!
Old 07-29-08, 10:36 AM   #88
Romer's Avatar
TLCA# 13968
Then why don't you order it from Dan, he told you he can get them. You do know he is the Parts manager at a Toyota Dealership don't you and he wouldn't post that unless he could get it. Call him at American Toyota
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Old 07-29-08, 10:44 AM   #89
Trunk Monkey's Avatar
TLCA# 11251
Ok, now we need the exact same thread in the 100 section. I miss my SC . . . . .
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
100 Series Wheels FOR SALE-CLICK HERE
Trunk Monkey is offline   Reply With Quote
