1991 3FE cutting out issues
I recently took my Cruiser to the mountains for a day out. It worked great on the way out but after several hours of driving it started to bog out when I would accelerate. The RPMs would drop to below 1000 and it would chug up to around 35 mph then repeat the bog out. What could be the cause of this problem. I got it home and let it sit for several hours and took it for a short spin and it was back to normal. Any help would be great.
I'm no mechanic, but my rig acted like that once and it was a dirty fuel filter.
Only thing that puzzles me about yours though is that it went back to normal... |
Sounds exactly like my 91. It only does it on the drive home, after a few hours of wheeling.
I've replaced the fuel filter, and that didn't fix it. It's definitely something electronic. Here's the weird part... I can be driving along at 55, and it will start acting up (bogging, cutting out, very little power), and I can throw it in neutral, turn it off for a few seconds, then fire it back up and I'm good to go for about 5 more miles. Then it starts acting up again. The first time it did it, it took me about 2hrs to drive 30 miles... then I figured out that turning it off and then back on fixed it for a while. Anyone have any clues? Ignition coil maybe? -Tim |
what an odd problem my 91 only did that once ... but i was running of gas
__________________ 91 fj80 298k 3fe powa ; ome heavies, 36in IROKS, 17in Tundra wheels, rhino lined, abused, bruised, and still running like a champWWW.SAVETELLICO.ORG |
Hmmm, now that I think about it, i guess it could be the fuel pump going out? But, would shutting the vehicle off for a couple seconds cause it to start working fine for a while?
-Tim |
Try replacing the screen on the fuel pump. Sometimes it will get clogged up and collapse on itself. If you let it sit for a while then things settles and it will let up.
__________________ 78 fj40, 4" lift, Scout PS, Aussie in the rear, ARB in the front. SM465/3spd TC in the works. 91 FJ80-stock for now-future expedition truck |
Same thing
I can turn mine off and it will stop doing it for maybe 1 mile then right back to it????
Driving through any water? My 3FE did that when I didn't have 02 sensors in, and the connectors got wet.
no water
#10 |
if it only did it once and hasnt done it again it could just be something as simple as bad gas
__________________ 92 fj80: full 6 in slee lift, electric fans, 36" w/t custom sliders, custom front bumper |
#11 |
My old honda was doing this and I ended up needing to replace the distributor and all. I would do the neutral shut off deal too. Who knows.
__________________ 1992 FJ80, stock except brush guard , and BF Goodrich AT 33's. Hopefully soon to come; ARB, OME 2.5 inch lift, etc.
#12 | |
I would find a buddy or fellow TLCA member in your area and start swapping on some of his things to see if it goes away. I had a problem with my camaro once and swapped parts from my friends vette untill his MAF solved the problem on mine and saved me mucho $$$$ on a mechanic finding the problem. __________________ 92 fj80: full 6 in slee lift, electric fans, 36" w/t custom sliders, custom front bumper |
#13 |
I don't wheel
A failing fuel pump can cause the symptoms you describe.
If it's failing due to overheating, the few seconds of rest can allow it to cool enough to work for a little while longer. They're fuel cooled normally. If you frequently run your tank to near "walk the :censored: home", it's not getting cooled anymore. Do this long enough, and it will go bad. Buy/rent/borrow a fuel pressure gauge and test the pressure next time it happens. Also, IIRC, the fuel pressure regulator can cause similar symptoms. Check that as well. I think it's vacuum controlled on the 3FE? A cracked or rotting vacuum hose might be causing it to dump pressure back to the tank. __________________ Jonathan M. Rundlett <skadalajara@gmail.com> Copper State Cruisers #001 Member of the Happy Hour Gang and the last true conservative in the U.S. '94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper |
#14 |
check your intake hoses. it is very common to find that the intake hose right at the intake manifold is torn between one of the ridges.
#15 |
#16 |
My time is thin on the fuel pump. Time to keep turning left.
__________________ 2- 91 FJ80's, one smashed In the family 74 FJ40 w/PTO winch, tow bar 83 FJ60 84 FJ60 90 FJ62 w/damage inducer 94 FZJ80 w/damage multiplier 95 FZJ80 " " 03 UZJ100 |
#17 | |
The FP intake filter is a soft mesh. It will collapse on itself after an hour or so of driving. When you shut the motor off it will expand back into shape, but once the fuel in the tank is warm it will collapse on itself in a short time. These filters should be replaced every 100K miles (just like the fan clutch). No one knows they exist and they'll swap in a new fuel pump with a new pre-filter and it'll solve the problem. Spend a few extra sheckles and replace all the gaskets and cushions as they're most likely old and crusty. __________________ Jon Held 1991 FJ80 "Lumbering White Rhino" Times Square, New York, USA TLCA# 5980 http://gclcny.com/jh/ Buy your FJ80 FSM here: http://gclcny.com/jh/fsm.html |
#18 |
I have a similar symptom with my 62 right now...and ordered a pre-filter for the tank, and a coil, along with a few other part$.
I have two questions, though...first, does the problem clear up if you drive in 3rd instead of drive? Mine does...also if I am going over 55 mph, it is greatly reduced in drive. And second, is your fender-mounted blower operating? Mine isn't... ![]() What I'm getting at is that you may be overheating your intake and fuel rail, like I am. I'll know tomorrow if I'm right, as I am hot wiring (fused) the blower for the ride to work. I'm still going to change the pre-filter, though. It just seems like it should be done regardless. Good luck... __________________ 1988 FJ62 - undergoing rejuvination 2003 Tacoma - relegated to daily driver |
#19 |
I had same problem, and did the fuel injection system cleaning at pep boys and no more issues....
__________________ HELO?....is this thing on? 1991 fj80 's but I drive it, suspension air bags, roof rack, trailer 8pin connection, 7 pin mod, hood spacers & stolen radio. 1985 fj60 (DD)HID-xenon retrofit projectors, tailgate storage, rear seat shoulder belts, 62 rear sway bar, & roof rack. 1987 4runner, seat bracket spacers(4crawler.com), driver side battery, HID-xenon retrofit projectors, & modified/upgraded intake, rancho shocks.WWW.RONSERRANO.COM |
#20 |
going back to the original post, i would check the air intake for cracks, since offroading it could move enough to tear and cause problems
__________________ 91 FJ80 318k, spare tire mod, custom roof rack----SOLD 98 4runner 141k---SOLD 98 Avalon 149k 04 Sequoia 74k |
#21 | |
FJ62 Karma
Have to admit I never had to change a fuel pump prefilter on either of our FJ62s. Don't believe it was even mentioned when the gas tank service bulletin replaced the OEM tank in the early 90s. Wouldn't hurt to have Toyota check your VIN to see if the tank replacement was carried out. __________________ ![]() Joe aka 4XODDIC ( allow me to pronounce that for you: 4 By, Odd Eye, See! ) aka the One Eyed Guy Owning Toyotas Since 1975 TLCA 8537 99-00 Tundra LTD 4X4; 01-90 Samurai; 07-88 TinTop Samurai; 08-97 LX450 |
#22 |
4xoddic,
I studied on the service manual a bit, and instead of removing the sender for a hot oil bath test, simply shorted the sender wire to ground, and the fan ran. I ran to work this morning with the fan running, and in drive, with no problems. However, it was 20 degrees cooler this morning than it has been lately. So I consider this encouraging, but inconclusive. It should be up to a normal hot and humid by the time I get out of work tonight, and I'll test it the same way. I've not had a 62 before, so I'm not sure what to expect of the fan. The FSM does not give a dignostic tree that I could find, just a schematic and component test procedures. There IS an "ignition hot" lead going to the relay, but I'm not sure that means the fan should run whenever the ignition is on. More later... Oh, if it matters, my fuel tank was replaced around 1992 or 94. __________________ 1988 FJ62 - undergoing rejuvination 2003 Tacoma - relegated to daily driver Last edited by NJTaco; 07-16-08 at 07:35 AM. |
#23 | |
Curtis |
#24 | |
Mtn Home TLC and Tim, I hope you guys have better luck troubleshooting your trucks than I am! __________________ 1988 FJ62 - undergoing rejuvination 2003 Tacoma - relegated to daily driver |
#25 | |
#26 | |
This was also from one of Jon Heald’s threads. I think he refers to the modulator as the “flying saucer” looking thing
#27 | |
__________________ 1991 fj80 4" lift , 35" bfg's, 5.29's.locked. 1997 LX450 ,wifes ride ,all stock. |
#28 |
I'm surprised that no one has mentioned the EFI relay yet. Notorious on FJ80's and can cause similar symptoms.
__________________ -Kristian '00 Tundra- Daily driver/tow rig '92 FJ80- Overlanding rig '83 Porsche 944- track car '74 VW Thing- Kubelwagen project |
#29 | |
Be sure to replace the EFI relay with OEM Toyota, other aftermarket relays will not last long at all. I also upgraded the wires leading to the relay to a lower(beefier) guage wire. From what I read in the past, the original wire was too narrow to carry the current in extreme heat situations. Haven't had any problems since, 3+ yrs, but this was a constant summer-time problem for me for several years. __________________ 1991 FJ80 |
#30 | |
Not to say that it's impossible, just not likely given the description. __________________ Jon Held 1991 FJ80 "Lumbering White Rhino" Times Square, New York, USA TLCA# 5980 http://gclcny.com/jh/ Buy your FJ80 FSM here: |
