Trail etiquette
Today was the first time on a trail in the 80 since we purchased it about 3 months ago.
We drove Ophir pass from Ophir to Silverton. Question: When traveling opposite directions, who should stop and yield for whom on the trail? While it seems sensible that the vehicle protected by the uphill side of the trail should yield, I don't know that is the case. Some help? |
try this link it has alot of common courtisy rules listed...
Tread Lightly - Responsible Four Wheeling __________________ 94 229k |
myopic luddite
If you have room to pull over, you pull over.
__________________ "Well it's a '68, '69, '70, '71, '72, '73, '74, '75, 76, '77 FJ55" http://forum.ih8mud.com/424768-post9.html |
#4 | |
I'm not sure, but I'm usually the first to pull over and let them pass. Unless they pull over first, then I give 'em a smile and a wave.
__________________ Lane Anderson 1991 TRD FJ80, Red, 249.9k, 3FE Powa ----- Lifted, flareless, LineX, 31" BFGs, Slee stuff, Dual batts, HIRs, OBA, GPS, headlight buzzer, couple lights, clear/tinted lenses, 100 Series emblems, NLXTACY's garage opener, air horns, custom 3FE sticker __________________________________________
"If Chuck Norris drove a Land Cruiser, the resulting unstoppable force would destroy the earth." Quote:
Thanks for the help.
I tend to pull over. Just wanted to know if there is a convention. |
The only real rule I know of is those that are pointing uphill have the right of way but other than that it is usually pretty easy to see who can pull over safely and who cannot. HTH.
__________________ 97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, LandTank MAF, HKS Turbo Timer, 3" Ceramic Coated Exhaust, OME HD 2.5" Suspension, DBA Slotted Rotors, ARB Stuff, 33" Revos, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, TC Skid Plate, SS Brake Lines, DC Drive Shafts. HG PM'd, My Rocky Mountain Mojo Mobile! Last edited by turbocruiser; 07-05-08 at 07:16 PM. Reason: was wrong |
On the Golf Course!
Per the link:
"Yield the right of way to those passing you or traveling uphill." It's safer to back uphill rather than downhill. Less chance of loosing control if you're going uphill rather than backing downhill. __________________ Brent '94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; Revo 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik! TLCA Member #13420; KI6SGO |
Great post! Subscribed.
__________________ <>< 1996 FZJ80 With all the goodies to make it go anywhere. ------------------------------------------------------------------------------ For Genuine Toyota Parts Call Cruiser Dan at 1-800-432-6668 ext. 8 |
myopic luddite
But you break birfs when backing uphill....
#10 |
If you break a birf backing up a hill, something was already broken in it.
Besides, birfs don't care which way they turn. -Spike __________________ His 1994 TLC 'White Elephant' +6"/35" Locked and loaded. Hers '95 TLC Bare bones. "I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown |
#11 |
Uphill has the right of way!
#12 |
No question about it. This being said though, I'll give up my right of way if there is a place for me to get my junk out of the way!
__________________ "Macadamia nuts in mixed nuts?!? Now that's a high class nut mix..." -Anonymous quote heard during a CM08 lunch break in the worm hole on Kane Creek |
#13 |
myopic luddite
Exactly. Don't worry about "Right of Way" on the trail. That's not etiquette. Just pull over when and where you can and give a nod or a wave when the other rig passes by. That's etiquette.
If there is a "Right of Way", I yield it to the less-able rig. They may have fewer options for pulling over.... __________________ "Well it's a '68, '69, '70, '71, '72, '73, '74, '75, 76, '77 FJ55" http://forum.ih8mud.com/424768-post9.html |
#14 |
I beg to differ. All drivetraiin on every vehicle is designed with the strength going forward... This is why most manufactures will put a lighter duty axle under the front than the back. I'm not saying that if you back up a hill, you'll break a birf, but they are less strong going backwards than forwards... The reason for this, in our case, is not the fact that a birf is designed to go one direction (in that aspect, you are correct), but because the weight of the vehicle cause more stress on the front end. That extra stress combined with a locker and turning the wheels = SNAP! Therefore, a birfield is weaker in reverse. Not because of the birf ifself, but of the other factors multiplying the strain on the axle.
#15 |
Still Lookin'
You'd have to put a LOT of strain on the drivetrain in reverse to break something.
For example: I backed up a 35-40 degree slope, in mud, all lockers on, all four wheels spinning at full throttle for about 150-200 feet. No problems. I really had no other choice at the time though, as the mud was making me slide into a tree and I had to get some distance from it to make the corner I was trying to turn into. I still ended up tagging my rear quarter on that tree and still have the dent from it. I should have backed up farther, but was getting close to the vehicle behind me. Had I not backed up at all I would have drug the entire drivers side along the tree as a pivot point. This was not an acceptable option to me at the time. __________________ Eric P. 1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW |
#16 |
I was running up Medano Pass at the Great Sand Dunes in Colorado this past weekend headed to the back country camping area. The trail is fairly narrow but has many wider spots for passing vehicles. I hadn't yet made it to camp so both my truck and M101 trailer were pretty loaded. I was starting up a 100 yard loose deep sandy part of the trail when 2 Jeep Wranglers came flying over the top of the hill. They had probably 6" lifts and 37" tires and were going way to fast, laughing their asses of bouncing 2 feet in the air. When they saw me they were still 150 feet away and right beside a nice wide spot to pull over. They didn't even slow down, they simply drove right off the trail catching air and drove through the undisturbed desert landscape. I was so pissed because they destroyed a bunch of nice landscape that was pretty untouched, clearly violated the many posted signs to not go off the trail for any reason, and they scared the shit out of my wife and kids. I tried to get their license numbers to no avail. And I really wanted to go after them with my Glock! Sorry for the vent, but I had to sit there and cool off for about 10 minutes. Plus I had a really tough time getting rolling again up the hill with all the extra weigh in deep sand.
__________________ 2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee SliderSteps, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers M101 Trailer - Sold 1993 Bontrager Race Lite MTB |
#17 | |
__________________ - Iam home now from the SUCK !!!!!!! VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!! - RUBITHON 2008 TESTED GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7.. |
#18 | |
In mud you don't have strain on the drivetrain. Try the same thing in a rock garden and turn! |
#19 | |
The front axle is plenty stout enough to handle backing up in reverse. The only thing designed to go forward is the gear set, and it can handle backing up a hill just fine. Some people act as if the front axle will explode if they do anything besides drive straight forward on pavement. It can take some abuse. -Spike __________________ His 1994 TLC 'White Elephant' +6"/35" Locked and loaded. Hers '95 TLC Bare bones. "I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown |
#20 |
I would be more Worried about Breaking a Front Hi Pinion in Reverse, than a Birf.. If a Birfs where stronger going one direction they would Be Driver or Passenger side Specific..
needless to say i would not worry about it, determine who has the easier ability to get out of the way, and who has more rigs in there group, and get out of the way accordingly.. __________________ 1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINEColorado Land Cruisers - Club Redline Land Cruisers - Safety First CrAwLoRadO.com - Just Check it out
#21 |
Parts Shaman (per Romer)
Not the best thing to back-up with a locked front diff. High-pinion or not. It's about a push between the early trucks and a high-pinion 80. In an early truck you shatter a bell and in a high-pinion you shear teeth.
Take your pick. __________________ Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock and a lumpy old Dodge car.
#22 | |
#23 | |
