Old 07-01-08, 03:01 PM   #1
esh
esh's Avatar
TLCA# 4408
FZJ rear FF shaft dimensions
I am trying to find a set of replacement axles for my 45's Dana/Toy hybrid rear FF axle.
Can someone with spare FZJ80 axles or who happen to have theirs out for maintenance measure:
- shaft diameter
- length from inside end to the flat mount surface (both axles)
- spline count
- spline length
mucho appreciated!
Ken, Cascade Cruisers
'64 FJ40, '66 FJ45, '79 FJ40, '81 BJ42, '82 BJ42, '85 xcab, '89 FJ62
Steens Photography, LLC
esh is offline   Reply With Quote
Old 07-03-08, 12:07 AM   #2
The quick brown fox .....
Beowulf's Avatar
Ken,
I see your thread has gone a couple of days with no response. Sorry about that. Unfortunately, I can't help with your questions other than to say that I am pretty sure this same question was asked and answered a few months ago. Try searching the 80-section and see what you come up with. If you cannot find it then post back in this thread and I will try to search for you. I'm pretty good at finding information in the 80-Section if it is buried in here somewhere.
Good Luck and let us know.
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Beowulf is online now   Reply With Quote
Old 07-03-08, 10:50 AM   #3
CreeperSleeper's Avatar
TLCA# 15577
I'll measure the short side axle tonight... I'd measure the long side, but half of it is still in my truck.
Chad
Cascade Cruisers- President
KE7VSA
Views from the Creeper
MetalTech
Originally Posted by DanKunz View Post
You stacked rocks to climb your porch......HA!!!
CreeperSleeper is offline   Reply With Quote
Old 07-03-08, 10:58 AM   #4
esh
esh's Avatar
TLCA# 4408
Thanks for the help. I guess the important one is shaft diameter since I can cut one down if needed.
Only thing I've found so far in searches-
non elocker spline length - just under 2"
elocker spline length - 4-1/4"
Beowulf, do you remember the context from a previous post?
Old 07-03-08, 11:02 AM   #5
TLCA# 15577
Spline lengths sound correct, but that is only on the short side of the axle. The long side is approx 2" of spline on either locked or unlocked. I would imagine that the dia is the same as a 40 axle, but there is no taper to them. I say this because you can swap 3rds and they will work... You have my number, if I space it, call me and remind me!
Chad
KE7VSA
MetalTech
Old 07-03-08, 11:49 AM   #6
Parts Shaman (per Romer)
cruiserdan's Avatar
TLCA# 11332
RH, non-lock.
Length, inside of flange to end of splines: ~28 15/16
Spline length: ~1 15/16
Diameter at sealing surface: ~35mm
Spline count: 30
Old 07-03-08, 12:07 PM   #7
jasonmt's Avatar
I have some PP 4340 axles in the shop I will measure for you today.
jasonmt is offline   Reply With Quote
Old 07-03-08, 01:43 PM   #8
Beowulf's Avatar
I'm still searching Ken. Found this post from Dan a few years ago...
http://forum.ih8mud.com/80-series-te...fferences.html
In the case of the FF 80 series rear axle there are 3 part numbers. Left and right side numbers are different and the RH has a lock and non-lock version.
In addition, there have been multiple supercessions on all three axles and the diameter of the shaft where the seal rides was increased from 35 to 36 mm. It is important to know what you have in there as the newer shaft requires a different oil seal.
The smaller shaft was the one used in production so if the shafts are original to the vehicle one would use the smaller seal. If the shafts are replacements, one needs to know what was used to obtain the proper seal.
D-
-B-
Old 07-03-08, 05:15 PM   #9
Photoman's Avatar
New style rear axles in inches.
Short axle
Bearing seal diameter 1.417
Splines O.S. 1.283
Splines I.S. 1.2220
Spline length 4.15
Axle length 28.9242
Number of splines 30
Number of grooves 29
Long Axle
Splines O.S. 1.289
Splines I.S. 1.2225
Spline length 1.285
Axle length 36.402
Some variance because of axle rust preservative.
Bill
If it ain't broke, fix it until it is.
97 40th
Photoman is offline   Reply With Quote
Old 07-03-08, 05:17 PM   #10
cruiserdan's Avatar
TLCA# 11332
The short-side axle in Bill's post would be for a factory locked diff. Note the longer splines.
Old 07-09-08, 05:47 PM   #11
esh
esh's Avatar
TLCA# 4408
Just a followup thanks for all the info!
The short side numbers are very close to mine- enough to remeasure.
Will be nice to get the FJ45 back on the road.
Old 07-11-08, 11:36 AM   #12
TLCA# 15577
I should have my spare short side in a couple weeks. Otherwise Mark has one lying around the shop...
Chad
KE7VSA
MetalTech
Loans | Problem Mortgage | Credit Cards | News | Debt Consolidation
