Wagon Owner
Hot Tranny in 94
Ok guys I got the tranny temp gauge installed in my rig last night and went for a drive today...maybe 75 degrees or so today...little stop and go on the freway.. some surface streets and the gauge reads over 225....get scared and park the truck... so if I am correct that seems too hot...also an assumption on my part is the cooler on the drivers side of the truck is tha tranny cooler??? and it was cold to the touch?? what the hell?? any help would be great...thanks
__________________ Tim Coffey 87 FJ60 SBC 350 SOA and some other stuff SOLD 5-15-07 94 80 with some stuff New to me 04-28-08 05 Subaru WRX TLCA # 6947 Parts and Carb Rebuilds http://www.marksoffroad.net |
Wagon Owner
so anybody go any input??? can you confirm that the cooler on the drivers side is in fact that tranny cooler?? should it atleast be warm to the touch??? am I worrying about nothing??? would it matter if the lines got hooked up wrong or is that even a posibility?? Thanks guys...just wannna drive the truck but the hot tranny and cold cooler worries me..
#3 | ||
yes above 190 is running hot...
... try a search, lots of info out there. one thing i've come across is that if the torque converter's lockup is starting to fail that can drive temps up. good luck __________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo |
The idiot light on the dash cluster will come on at 305 degrees, then it turns off once it cools to 248 degrees.
Once the light comes on, you need to pull over and keep the engine running to cool the tranny. I have come to understand that between 170 and 200 is acceptable. I think you're reacting to new information from the gauge. If no warnings have tipped you off before the gauge then you should be okay. However, a cool to the touch tranny cooler is another situation. Check that system and see if you have any abnormalities. The tranny cooler should be warm if not hot to the touch at operating temps. |
Wagon Owner
any ideas on how to check the tranny cooler or see why it wouldn't be getting hot or warm??? It made me wondewr also...cause the radiator was warm to the touch and the cooler didn't even feel like anything had gone through it....I am stumped..
#6 | |
Where do you get the temp sender for the gauge . ? on the out or in line ? Mine reach the 190 in a really hot day here in Panamá, with AC on and aprox 34ºC ouside temp .. heavy traffic city driving. Other anormal day with a constant speed driving stay between 140 - 160ºF |
It sounds like there may be a blockage on the tranny cooler lines. When the truck/tranny warms up feel the lines that run along the left side of the engine block near the upper oil pan flange, they'll be two hard lines one above the other. Those are the tranny cooler lines and should be warm, if not trace them back to where they exit the tranny on the right side. As Tapage mentioned use an IR temp gauge and take the temp of the lines, pan and cooler.
Do you have a Toyota service manual? __________________ 1994 80 - Some stuff Tornado Alley Cruisers - TAC Those who can, do; those who can't, criticize. |
Wagon Owner
no manual as of yet...on my list...had one for my 60 and used it to death...will check the lines and see what I find...thnaks guys..
Western Union Locations | Internet Advertising | Dan Brown | Loans | Personal Loans |
