Old 06-30-08, 11:18 AM   #1
mylesprimo's Avatar
Parking brake upgrade
Does anyone know where I could find a parking brake set like the ones you can get at All-Pro offroad for mini-trucks?
All Pro Off Road
I like this set up, but cannot find it for an 80.
93 FZJ80 Factory Locked, junk ECU, and the problems keep coming...it is worth it though
mylesprimo is offline   Reply With Quote
Old 06-30-08, 12:24 PM   #2
Doc
Still Lookin'
Doc's Avatar
TLCA# 17266
The X-fer case parking brake? Check your local laws first, in many areas of the country this makes a vehicle not legal to run on the road.
Eric P.
1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Doc is offline   Reply With Quote
Old 06-30-08, 12:34 PM   #3
Tools R Us's Avatar
I wouldn't call that an upgrade, doubt that it has as much holding power as the stockers.
Copper State Cruisers #007
Old 06-30-08, 12:36 PM   #4
ringpinion.biz's Avatar
Not that it matters (it wont fit the 80 anyway) but driveshaft ebrake offers much greater holding ability, as it is multiplied by the gear reduction in the differential.
JTS Diff Parts & Accessories
ih8mud sponsor
866-349-6801
info@justdifferentials.com
www.justdifferentials.com
99 uzj100 35's, uniball a-arms, fox shocks, 4.88, lockers, bullbar, drawers & more.
ringpinion.biz is offline   Reply With Quote
Old 06-30-08, 12:44 PM   #5
Tools R Us's Avatar
That maybe true in theory, but I have never seen one that worked well in real life.
Old 06-30-08, 01:41 PM   #6
Atticus's Avatar
When properly adjusted, the hand brake works fine, in my experience.
"It was a blend from italy, not cheap, and absolutely superb!" - Judge Smails.
Atticus is offline   Reply With Quote
Old 06-30-08, 11:46 PM   #7
mylesprimo's Avatar
my problem is the current parking brake is junk, and if I am going to put more money into it, then I would like to have it be more of an upgrade. Has anyone tried this in one way or another?
Old 07-01-08, 12:05 AM   #8
paleo-conservative
hj60's Avatar
TLCA# 11004
I think the big thing with wheel-end e-brakes as opposed to driveline ones is redundancy.
If you mess up a driveline e-brake, that's it. If you mess up a wheel-end one, you can make the other work without it.
Just my 20 pesetas.
Jonathan M. Rundlett <hj60dot5@yahoo.com>
Copper State Cruisers #001
Member of the Happy Hour Gang
94 locked 80 with black-hub fan clutch and 13k fluid, pin7mod
83 60 4" lift. Sold
McCain. Obama. Which one's the lesser evil?
hj60 is online now   Reply With Quote
Old 07-01-08, 05:34 AM   #9
Doc
Still Lookin'
Doc's Avatar
TLCA# 17266
You mean, YOURS is junk? Because the factory one is great if you keep it maintained. Have you tried cleaning and adjusting the factory brake? Mine was junk too... until I cleaned and adjusted it. Now it's great.
Eric P.
Old 07-01-08, 11:12 AM   #10
mylesprimo's Avatar
I cleaned mine to where it move properly, but I have an issue of when I go around turns it has a catching sound. It is the e-brake shoe slightly rubbing. Also it does not old as well as I would wish. How do I go about adjusting it to eliminate the rubbing, and get a better hold. I tried adjusting using the access hole on the rotor.
Old 07-01-08, 11:20 AM   #11
Doc
Still Lookin'
Doc's Avatar
TLCA# 17266
Did you remove the brake rotor?
If you did not remove the brake rotor you may have dirt/ mud/ debris build up behind the rotor, which is fouling the pads. (this was my problem- no amout of adjustment would make that go away, I had to remove the rotor, clean the assembly and pads, re-install- re-adjust, and now it works great).
Eric P.
Old 07-01-08, 11:42 AM   #12
Atoyot1031's Avatar
TLCA# 18402
See this thread that I recently resurrected:
http://forum.ih8mud.com/80-series-te...djustment.html
Mine didn't hold at all. After proper adjustments, it's the best parking brake I've ever had. As Doc mentioned, if you have noise (and are sure it's the brake), pull the rotor and clean. RTs directions are perfect for what you want. No $$$ needed.
Also use the advanced search feature for issues like this. That is how I found the above thread and saved myself a bunch of time!
Good luck!
"Macadamia nuts in mixed nuts?!? Now that's a high class nut mix..." -Anonymous quote heard during a CM08 lunch break in the worm hole on Kane Creek
Atoyot1031 is offline   Reply With Quote
Old 07-01-08, 12:36 PM   #13
mylesprimo's Avatar
I recently replaced the rear rotors and pads, and did that adjustment while doing the maintenance, but I still have the dragging around turns. Could it be I have loose bearings in my rear axle causing movement?
Old 07-01-08, 03:34 PM   #14
Atoyot1031's Avatar
TLCA# 18402
For diagnosis purposes, how do you know it's coming from the rear?
And how do you know it's coming from the parking brake?
If you did the adjustments, are you still experiencing problems with your parking brake or does it operate properly?
Web Advertising | Myspace Proxy | Web Advertising | Debt Consolidation | Myspace Proxy Directory
