Old 06-29-08, 06:49 PM   #1
Tires Rotation question prior to going on long trip
Hey guys,
I have a coupon from "Meineke service center"..they gave free tire rotations. However, when I brought the rig in, the manager told me it will need "balance" also or it will vibrate.
I thought, you bastard! just like those buy one get half off and free craps.
Is it true, can I just rotate front to back and back to front without balance. It has been balance at the dealer two months prior, still has fresh metal tabs attach the the rims.
where are you hurting?
DocLX450 is offline   Reply With Quote
Old 06-29-08, 06:55 PM   #2
breathed's Avatar
A balanced wheel is balanced irregardless of it's position on the vehicle. The Meineke manager was trying to scam you. A proper 4 tire rotation would move a rear tire to the front axle, opposite side and a front tire to the rear on the same side. Tire rotation with the spare is a little different. Your owners manual should show you both procedures.
97 LC 139k, lockers, cup holder, CDL w/ cdan pin 7 mod
NRA Life Member
breathed is online now   Reply With Quote
Old 06-29-08, 07:56 PM   #3
On top of the world...
Lka1988's Avatar
Originally Posted by DocLX450 View Post
...the manager told me it will need "balance" also or it will vibrate...
<snip>
Then your tires don't need to be balanced. The Meineke guy is trying to sell you on BS you don't need. Tell him to shove off and rotate your tires.
Lane Anderson
1991 TRD FJ80, Red, 252k, 3FE Powa
Lifted, bumpered, Slee'd, flareless, LineX, 31" BFGs, Dual batts, CB, HIRs, OBA, GPS, OEM CHMSL, roof lights, kickin' sound system, 2-seater - 10 MPG!!
__________________________________________
Originally Posted by eskimochaos
we have concluded that the LC is the toughest most over-engineered leather-lined tank ever forged and that it is used to rescue villagers by the UN in the toughest terrain on a daily basis
Lka1988 is offline   Reply With Quote
Old 06-29-08, 10:46 PM   #4
I fingured this guy was trying to hit me up with another 20 bucks. Thanks guys.
So rotation is : the rear driver goes to the front passenger side. The front goes back right.
Old 06-29-08, 10:51 PM   #5
Lka1988's Avatar
Here's what we do at work:
Cross the rears forward, fronts straight back. Unless they're directional...
Lane Anderson
Old 06-30-08, 08:04 AM   #6
mainemike's Avatar
TLCA# 17772
are you sure you have to rotate at all? If they were just balanced at the dealer, did they rotate as well?
that coupon is simply a way to get warm bodies thru the door... and then they have ways to extract your cold credit card....
FWIW, I haven't rotated my tires for 30,000 miles, following landtanks's lead. So far I see no uneven wear. This is the only truck I've ever tried this on, and the tires seem happy.
1996 FZJ80 not-locked, Emu 861/862, ARB, Slee sliders and skids, 285 Nitto TGs, Scan Gauge, hopefully exploring somewhere in North America.
www.purplelizard.com
mainemike is offline   Reply With Quote
Old 07-01-08, 10:27 PM   #7
hondaguy6513's Avatar
AWD vehicles wear the tires much more evenly than front or rear drive vehicles do. But, you cannot "over-rotate" your tires.
As far as rotation pattern you will find that different people do it different ways, I was always taught to cross to the power, ie the tires that were on the non-drive axle and are going to the drive axle cross, the tires coming off the drive axle go straight back(or forward as the case may be) and on awd vehicles I do the old school x cross rotate, opposite corners.
hondaguy6513 is offline   Reply With Quote
Old 07-02-08, 08:12 AM   #8
Chevinater77's Avatar
mine are uni-directional should i have em dismount re-mount then balance?
Its not a Passion, its an Obsession
Cruiser~95 stock 80 series, Goodyear Forterra Triple-Treds, Samco sport PHH.
Princess Ride~2008 Toyota Tundra Crewmax limited
Chevinater~ 77 Chevy 3/4 ton 350/350/203 with 44 front 14ff rear, 4.56s, 6 inchs 35x12.5x16.5 bfg m/t
Chevinater77 is offline   Reply With Quote
Old 07-03-08, 09:50 AM   #9
mainemike's Avatar
TLCA# 17772
Not unless you see a terrible amount of wear, which points to needing an alignment. Directional tires are rotated front to back on the SAME side of the vehicle. They should have an arrow molded into the sidewall.
What tires are they? I wasn't aware of a directional tire for the 80. I've had them on Subaru's, but didn't think they manufactured them in larger sizes.
Old 07-03-08, 09:57 AM   #10
Lka1988's Avatar
I've seen directional MUD tires. In the 315/65R20 flavor.
Lane Anderson
Promotional Codes | Mortgage | Loans | Mortgage Calculator | Loans
