Old 06-28-08, 01:16 AM   #1
Mark's 4WD Speedo Correction Install... ?
Has anyone seen a write-up on an install for the Mark's 4wd speedo correction. I DID search on here and Slee's site and have not found anything. It's a fairly simply install, I was just curious where you guys mounted your conversion box and where/if you drilled a hole in your tunnel. Someone had mentioned that you could use an existing hole or rubber plug??? Anyhow, thanks for the help.
'97 FJZ80, Slee 6", 37x14x17 Irok's, Trail Gear beadlocks, Arb w/ M12000
Little Evil is offline   Reply With Quote
Old 06-28-08, 07:08 PM   #2
Student of IH8MUD
Ted44's Avatar
TLCA# 15598
You can download the instructions exactly as they come with the unit from Slee's site.
There is indeed an existing rubber plug in the tranny tunnel on the US Passenger side up under the center of the dash. Pull back the carpet and you'll see it.
The unit is truly plug and play and works great.
Slee - Speedometer Correction
ted
1995 FZJ 80, Factory Lockers, George's LEDs, 285/75R 16 Cooper Discoverer STTs, Mark's 4WD Speedo Correction, Kaymar Spare Carrier, Newfields and axles from CV Unlimited. DD w/ 201K and trail rash.
"There's only one basic human right, the right to do as you damn well please. And with it comes the only basic human duty, the duty to take the consequences." - P.J. O'Rourke
Ted44 is offline   Reply With Quote
Old 06-28-08, 11:42 PM   #3
Hong Kong Phooey
TOY350's Avatar
TLCA# 4939
Ted is correct. I ran the wires through the rubber hole as well and it is one the few actual Plug and Play mods. Works great, the hardest part was finding where to mount the box. I ended up putting above the hole with zip ties, it's out of the way and no holes needed to be drilled.
GARETT
67 FJ40
- 350 - SM420 - SOA - ALL PRO HY-STEER - 4.88 - ARB F/R - 30 SPLINE LONGS - 35 MTR's - WARN XD9000
95 FZJ80 - 3 LOCK - LONGS - 4.88 - 285 TOYO's - OME J & L - LANDTANK CC & MAF MOD - ARB/WARN XD9000 - HANNA SLIDERS - 4X4 LABS REAR - SLEE SKIDS & MORE - ECLIPSE NAV - RUBICON TESTED!
JEFFERSON STATE CRUISERS
Originally Posted by cruiserdan View Post
That particular rock is a screaming bitch and if I had my way I would dynamite the sonofabitch and use the left-over pieces to fill up the hole.
TOY350 is offline   Reply With Quote
Old 06-29-08, 12:36 AM   #4
Cool. I'll give it a shot soon as I get home. I heard nothing but good about this product. What tire sizes are you guys running?
Old 06-29-08, 12:39 AM   #5
Hong Kong Phooey
TOY350's Avatar
TLCA# 4939
33's with 4.88's.
GARETT
67 FJ40
Old 06-29-08, 07:38 AM   #6
I ran the wires thru the rubber plug on the passenger side and mounted the unit vertically along the front edge of the center console.
Mike
1997 FZJ80, white, Slee 5.5", 315/75R16 MT, locked, CDL, SROR sliders, tube bumpers with receivers for winch, custom exhaust, custom internal tire mount, Snorkel, Sirius receiver, Mark's Box, Eezi-Awn 1600.
Bikeman is offline   Reply With Quote
Old 06-29-08, 08:08 AM   #7
Good to know!
Thanks!
LC80Ducati996 is offline   Reply With Quote
Mortgages | Mobile Phones | Loan | Flores | Loans
