Location: Edmonton Alberta Canada, Maidstone Sask. Canada
part time kit installed and won't come out of 4wd
i have the part time kit in my 92 cruiser and the t case is stuck in 4wd. (the center diff lock switch actuates the 4wd). i press the button to shut off the 4wd (CDL) and the light wont go out and it is still in 4wd. i probed the wires for the cdl motor and i have power going to it when the button is pressed on and no power when the bottom is off.
Last edited by muddmadness; 06-27-08 at 03:27 PM. Reason: add the year of the truck |
Have your tried just driving in reverse forwards and backwards a short distance to release possible bind in the drivetrain? I'm not familiar with the 'part time kit', so someone else will probably have a more helpful answer if there isn't a simple solution.
__________________ Columbia, SC 71 FJ40 little Swampers, cheap lockers, big winch 72 FJ40 stocker with PTO winch 85 FJ60 lawn ornament 87 FJ60 w/ H55F |
yes i tried that in hi and low. now luck. thanks
IH8MUD Tour Guide
maybe the motor itself is gunked up on the center diff? I think it was tools who posted pics of his actuator motor rebuild if you do a search.
__________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". Last edited by concretejungle; 06-28-08 at 08:36 PM. |
Thats exactly what happens to mine sometimes and going forward and backwards releases it. It is possible that the actuator motor might be sticky. Let us know how you go...
__________________ Dan 92 FZJ80, 5sp, Part-Time Kit, 4" Lift, Locked, 305 muds....(Selling soon) 97 HDJ80, 5sp, 1HD-FT.....Turbo-diesel multivalve music to my ears! |
Much more if you not have hubs in and you are over a good traction surface.
not quite sure what you mean. should i lock in my hubs and try it on a hard surface going back and forth?
No, I'm pretty sure he means that-
1. having the hubs locked & 2. driving on a high-traction surface will both magnify the problem of the t-case getting stuck in 4WD due to bind. If you have manual locking hubs though, unlocking them, and driving in any direction should release the bind in the t-case if that's the problem. If that's not doing it, then maybe it is the actuator for the CDL motor sticking. __________________ Columbia, SC 71 FJ40 little Swampers, cheap lockers, big winch 72 FJ40 stocker with PTO winch 85 FJ60 lawn ornament 87 FJ60 w/ H55F |
You want to do what...?
did you just install the kit before that? (TC kit or hubs?)
__________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD souped up DR650 |
#10 |
the part time kit doesn't affect the CDL operation in terms of mechanically. The CDL impacts the front output shaft which isn't messed with during the ptt kit installation. In terms of electrically, did you plug in the two harnesses that you unplugged during the PTT kit install?
So, figure out why the cdl isn't moving one way or the other. Do some searches on ToolsRUs and center diff lock to get some more troubleshooting ideas or check the FAQ section on this topic. Good luck and let us know what you find out. __________________ TLCA # 15941 KE5LED Currently working PA |
#11 |
it has been working for a couple years and now it stoped.
#12 |
Ahh, that tid bit helps out a lot. Your subject heading made it sound like it was a recent install. Sounds like it's time to dive into the CDL actuator.
#13 | |
IH8MUD Tour Guide
that is what i was thinkin' the whole time.
__________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". |
#14 |
Ramblin Wreck
Are you sure it is actually in 4wd and the indicator light/sensor is not malfunctioning?
__________________ Bailey Quintrell '74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage '93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's '97 FZJ80 '98 UZJ100-OEM RR locker ΣΧ
#15 |
yes i'm sure. the motor dosent make any sounds. the indicator light works. has anyone had trouble with the transmission relay? i have the wiring diagram and ive tried a couple tests. i tried sending power to the motor and its not moving. i think my next step will be to lower the tranny and t case and take out the motor. any hints to check the motor before i dive into it.
#16 | |
#17 |
can you send the link to that website?
#18 |
Here .. use the search tool to find the thread ..
#19 |
IH8MUD Tour Guide
Mortgage Calculator | Online Loans | Refinance | Internet Advertising | Debt |
