Old 06-27-08, 07:23 AM   #1
CT Grillguy's Avatar
What could cause burning smell through vents?
Burning rubber smell strong for a few mins then gone. Has come back as very faint smell a couple of times. AC compressor going out? Belts are all new. How can I check if the AC belt is the culprit? I have read about the emergency brake return seizing up, but I doubt that would come through the vents while traveling.
Sorry, I posted something a day ago but this is more specific.
'97 LX450 factory lockers, 255/85's.
CT Grillguy is offline   Reply With Quote
Old 06-27-08, 09:58 AM   #2
ToyotaDon's Avatar
You say the belts are all new. Who replaced them and are they properly adjusted?
If it's definitely a burning rubber smell, then belts are where I would look first. You would likely have some noise associated with this, though.
It could also be burning oil, if you have any leaks onto the exhaust, or electrical burning, which could be any number of things.
Donal
Originally Posted by fish2live View Post
WTF - where have you been?? That's the most detailed post from someone with less than 300 posts I've ever seen...
Thanks TDon - stick around and help for a bit, won't you?
Originally Posted by Hilux View Post
Low post count ≠ Low intelligence
ToyotaDon is offline   Reply With Quote
Old 06-28-08, 02:50 PM   #3
sseaman's Avatar
did this start after the belts were replaced? Thats where i would start, make sure tension is correct, may need tightened or loosened, and verify they are routed properly.
91 FJ80 318k, spare tire mod, custom roof rack----SOLD
98 4runner 141k---SOLD
98 Avalon 149k
04 Sequoia 74k
sseaman is offline   Reply With Quote
Old 06-28-08, 04:09 PM   #4
Ludwig van Crunkthoven
raydouble's Avatar
Were the belts OEM or aftermarket?
Does the smell correspond with the A/C compressor clutch kicking on and off?
Something burning off headers/exhaust manifold.
Oil leak?
raydouble is offline   Reply With Quote
Property in Spain | Keyword Suggestion & Research | The eBay Song | Loans | Credit Card
