#61 | |
You might convince me otherwise, but not by referring me to a book that will likely confirm what I know. Post a link to a write up that explains why and how short, cone shaped secondaries increase exhaust scavenging at RPMs lower than 6k in street cars and trucks. __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch |
#62 |
Your welcome. I might go with 2.5 unless you are going to do some things that will be able to take advantage of the extra flow provided by a 3" diameter. Either way, I would try to use a Y collector for sure.
__________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch Last edited by jamisobe; 06-28-08 at 02:15 PM. |
#63 | |
ThinkTank Waterboy
No engine management needed with my MAF housing. Sorry for the hi jack, I was simply letting people know how I did mine and for what reasons. I had to leave town Friday night and didn't get a chance to take some pictures. If this thread is still active when I get back I'll do so then. __________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
#64 | |
YES F1 are shorter for high RPM and average hot street cars are longer. None the less stahl has made plenty of steped primary muscle car headers for pushrod v8s peaking hp wise around 6k rpm. You just dont care about steped primaries which are something that is done in addition to tuning primary length for the desired RPM.. Nor do you aknowledge what is the best way to get CFM in a full street legal exhaust. |
#65 | |
I just prefer a full standalone EMS with wideband, knock sensors, huge GM MAF in blow thru, EMS controlled boost (watchdog) and other cool stuff. I am probably planning on testing the PSI limits a bit more than others. I ran E85 fuel and 30psi on the street in AWD eclipse before with a full EMS. It takes a good while to get it all setup but is awesome for tuning and protecting the engine. |
#66 | |
I visited the Stahl Headers website and found this: STEPPED HEADERS Stahl headers are available in a stepped configuration (multiple tube sizes in the same pipe). The stepped primary usually increases either midrange or top end power, depending upon the base header tube size relativity to its power level. Step headers are not cost effective for most types of racing and we have never seen more than 1% power difference. A possible 1% power gain for very limited types of racing is quite a stretch when suggesting significant power gains for the set-up in general for muscle cars, etcetera. Sounds like snake oil to me, especially since we are talking about street vehicles for which Stahl would apparently not recommend "stepped headers" and we are discussing secondary tuning rather than the primary tuning. Try again, post a link to a write up that explains why and how short, cone shaped secondaries increase exhaust scavenging at RPMs lower than 6k in street cars and trucks. __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch |
#67 | |
SORRY but I dont consider things 2-3ft plus past the collector to be considered secondaries. With the steped primare reference... it is only "1% gain" however it is still a gain. Yes not worth pursuing at the header on an 80 series then again it was not my intent. It was to prove that gentle expansion of diameter increases power. We are way off from what I wanted to point out. It was simple.... going up to 3" gradually over a long conical section will out flow a short cheap necked adapter. Farther back as the exhaust has cooled and slowed the LONG conical expansion section will show much more power than a sharp step up to the cat back diameter. 3 Degree Transition They can even make a 2.25 to 3" that is quite long. This is one is how NOT to do it. |
#68 | ||
The Complete Performance Exhaust System Sanderson makes headers for V8s, but most of the principles are applicable. Worth a quick read. Here a couple of tid-bits I cherry picked from the short article:
__________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch Last edited by jamisobe; 06-28-08 at 05:08 PM. |
#69 | ||
![]() The Stahl website said that stepped headers were an outside shot in few forms of racing for no more than a 1% difference at best. You claimed that they were selling them all day long to put on street muscle cars. Please. __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch |
#70 |
Sanderson made no reference to how much of a change in diameter, how quicklly nor how far back. Being on the trail to someplace sandy (yet still in the US for now) I dont have my library of books with me.
I have seen studies where long conical increases to a larger diameter have increased output. As a general rule the way 99% of people change diameter when they install a larger cat back does infact reduce power. Most people use the short steps. Now look at a 3* or a 7* included angle transisiton... does this look like it creates a bunch of turbulence... I think not. They are crazy with their cruisers and patrols over there... Literally YouTube - with nissan patrol - qatar Last edited by LC80Ducati996; 06-28-08 at 05:19 PM. |
#71 | |
At least until you can come and link to a study that gives any credibility to what you are saying. So far, you have only diminished your own credibility as a reliable source by saying things that are not true while providing no sources for unconventional ideas you keep saying are true. Why should anyone believe you? __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch |
#72 | |
#73 | ||
steped primaries increased power.. yes only marginally.. but not my whole point anyway.. Oh and excuse me for being a bit busy training up for deployment and calling home to get right on finding the article I KNOW for a fact supports my actual statements and not someone elses distortions of them. RotorSports Exhausts The A'PEXi N-1 Exhaust Quote:
the metric measurements seperated by dashes indicate the diameters used. No transitions are abrubt.. I know for a fact I have seen it in more than one of my books back at home! Not going to taper the whole thing but still makes a case for why a 3-7* angle transition between stock front pieces and a 3" catback would perform well.. If 2.5" or 3" is still up in the air to a degree as I have yet to see a chasis dyno back to back of the two for a cruiser... I do know that if induction modifications are on your list such as head work you can easily get a modified 1FZ into needs a 3" system hp range. Straight up stock 2.5" is probably fine. Last edited by LC80Ducati996; 06-28-08 at 07:02 PM. |
Samsung | Mobile Phone | Problem Mortgage | Credit Cards | Deals On Products |
