Cigarette lighter question
The 80 has been sitting and draining the battery. I bought a cheap solar cell from Harbor Freight (case partially melted within an hour of exposure to the Phoenix sun) but it does not appear to be helping.
I know the lighter is disabled when the key is off. Does that mean electricity won't make it to the battery from a solar panel attached to the lighter when the truck is off? __________________ ARB Bullbar, Front OME 850J Rear Custom Slee springs approx.10% stiffer than OME 863 pin 7 mod & CDL, Kenwood DVD/Garmin NAV, Power inverter, auxfan, rt temp gauge mod & a bunch of other things…… |
Hong Kong Phooey
I would assume so. Your lighter is off when the ignition is off so the side of the fuse that your lighters harness is on does not have a connection to the hot battery side. That's how I see it.
__________________ GARETT 67 FJ40 - 350 - SM420 - SOA - ALL PRO HY-STEER - 4.88 - ARB F/R - 30 SPLINE LONGS - 35 MTR's - WARN XD9000 95 FZJ80 - 3 LOCK - LONGS - 4.88 - 285 TOYO's - OME J & L - LANDTANK CC & MAF MOD - ARB/WARN XD9000 - HANNA SLIDERS - 4X4 LABS REAR - SLEE SKIDS & MORE - ECLIPSE NAV - RUBICON TESTED! JEFFERSON STATE CRUISERS |
That's what I was afraid of.
Back to the drawing board. Thanks. __________________ ARB Bullbar, Front OME 850J Rear Custom Slee springs approx.10% stiffer than OME 863 pin 7 mod & CDL, Kenwood DVD/Garmin NAV, Power inverter, auxfan, rt temp gauge mod & a bunch of other things…… |
Hong Kong Phooey
Can probably cut the lighter end off and mount the leads to the battery if you know what side is positive and negative on the wire. Don't quote me on it since I don't know the schematic of your panel, but in theory it sounds right.
Adverse Credit Remortgage | Web Advertising | Homeowner Loans | Debt | Remortgage |
