Starter run-on, and on.
Anybody ever experience this...
3 times over the last few months, when I've started the truck, the starter kept running even after the truck was started. Turning the key off kills the engine, but the starter keeps running, and running. I put the key back in the ign switch, and turn to the on position, the engine fires up, and the starter is still running. This has gone on for 5 minutes or so, during which I am turning the ignition switch on and off. I've beat on the top of the starter also while this was happening, but that didn't work. I haven't yet figured out yet what gets it to stop, but it eventually does. I'm concerned that if my wife drives the truck and this happens, that she will drive with the starter engaged. Lately I have been starting the truck using the remote starter and it hasn't happened, yet. If that continues to work, I'll have to look at the ignition switch. So what do you guys think? Ignition switch, magnetic switch in the starter? __________________ Shaun 1996 FZJ80, Locked, F.O.R. 3" + 30mm. 35" Trxus, rear panhard drop, ARB Front, 150 Amp Sequoia Alt, Optima D31A Yellow w/Marine posts, 2/0 wire throughout. 134K Miles. 2005 LX470 - 54K - Stock - ![]() 2004 Cadillac CTS-V LS6-400HP, 6 Speed Manual. 44Kmiles |
A new starter and/or solenoid is what will fix this. Worn out ign sw is rare, but possible.
... __________________ D.F.Morse 1994 FZJ80 Kazumatized 74000 mi 1979 FJ-40 74000 mi Here endith the lesson |
Former Wheeler
It's the starter contacts inside the solenoid on top of the starter.
Simple fix and common as all get out. |
I'd say that either the starter relay, or starter solenoid is sticking. IMO, those are the only two possible causes, with the starter solenoid being first on the list.
Good luck. __________________ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Move along folks, nothing to see here! |
Thanks fellas. I'll call Dan tomorrow.
#6 | |
The quick brown fox .....
Stop driving it until this gets fixed. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
Noted. Thanks B.
#8 | |
x2,000 what B said. I was very close to having a similar situation, but I replaced the contacts before they started sticking.
Got the wrong plunger too...
__________________ Lane Anderson 1991 TRD FJ80, Red, 249.9k, 3FE Powa ----- Lifted, flareless, LineX, 31" BFGs, Slee stuff, Dual batts, HIRs, OBA, GPS, headlight buzzer, couple lights, clear/tinted lenses, 100 Series emblems, NLXTACY's garage opener, air horns, custom 3FE sticker __________________________________________
"If Chuck Norris drove a Land Cruiser, the resulting unstoppable force would destroy the earth." Quote:
Personals | Fast Loans | Duelmasters | Credit Counseling | Mobile Phones |
