Old 06-22-08, 09:56 AM   #1
Flip Dog's Avatar
Lifted my 80
Here are some pictures before and after. Sorry for the crappy cell phone pictures.
My trusty helper. You could tell she was exited about this one.
Flip Dog is online now   Reply With Quote
Old 06-22-08, 10:02 AM   #2
Flip Dog's Avatar
I did the rear first
I kinda like the miniture tires on the big wagon.
The front is higher then the rear.
Old 06-22-08, 10:07 AM   #3
Flip Dog's Avatar
Has anyone fabbed up there own panhard bars, would it be unsafe to cut the stock bars and weld some burly tubing on to make them longer? My alignment is all messed up.
Old 06-22-08, 10:14 AM   #4
Lost
unwiredadventures's Avatar
TLCA# 18869
For the rear, this drop bracket should do it: 4+Plus Rear Panhard Rod Drop Bracket Kit
'97 Land Cruiser, Locked, OME J, Metaltech Sliders, Toyo MT 315/75/16, CDL, Kenwood D700, Laptop Mounted, Landtank seat mod. For me.
'97 LX450, Landtank seat mod. For my wife
Land Cruiser Laptop Setup | Trip Photos | Twitter
unwiredadventures is offline   Reply With Quote
Old 06-22-08, 12:30 PM   #5
BooKilla's Avatar
TLCA# 18193
Looks good. What kind of lift did you go with? It looks like an ome J.
The Boone
'85 4runner (sold)
'91 FJ80 (3fe powa)
'94 FZJ80 (lockered)
'98 4runner (sold)
"Buying parts I don't need, with money I don't have, to impress people I don't know."
Co-Founder of the Lake Oswego Militia
BooKilla is offline   Reply With Quote
Old 06-22-08, 12:39 PM   #6
jamisobe's Avatar
Slee - Toyota 80 Land Cruiser Series Suspension Arms
Slee - Toyota 80 Land Cruiser Series Suspension DIY Pieces
I used Slee's weld-in adjusters, but I know of someone who successfully lengthened their panhard rods by welding in their own extensions.
95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch
jamisobe is offline   Reply With Quote
Old 06-22-08, 12:50 PM   #7
Flip Dog's Avatar
yep, its a 863J in the rear with L shocks and 420 comp coils up front.
This started as a 3-4" lift and turned into like 6" I installed the 850J coils up front first but they were way lower in front than the rear so I ordered the 5" OME comps and MAF 3" control arm drop brackets to get back some of my castor. I have some OME castor bushings too.
I also needed a longer front brake line witch I am installing today, I havent drivin it sence I put on the lift. Cant wait.
As for the panhards, I would think it would be easy to measure-cut-weld-replace, but Ill probably end up ordering some.
Next, gears and tires. Any suggestions for gear ratio with 315's and a 3fe?
Old 06-22-08, 01:00 PM   #8
jamisobe's Avatar
I'd do 5.29's for sure. But some would say 4.88s. I believe that 4.88s with 315s will get your speedo close to correct. Otherwise there are other ways to correct your speedo.
Slee - Speedometer Correction
SuperLift TruSpeed Speedometer Recalibrator
Old 06-22-08, 01:07 PM   #9
jamisobe's Avatar
Incidentally, check this out: MIKRONITE
I will likely do this when I switch to 5.29s.
Old 06-22-08, 01:16 PM   #10
ThaiCruiser's Avatar
TLCA# 18321
4.88 should be enough if you don't have a plan on going any bigger than 35's.
'97 "Sage" FZJ80 40th #1885 ARB, OME "Heavy", 305/70 BFG M/Ts on Welds
'91 RN90 ARB, Warn M8000 265/70 16 SSRs
'85 RN65, in building mode
ThaiCruiser is offline   Reply With Quote
Old 06-22-08, 01:37 PM   #11
Doc
Still Lookin'
Doc's Avatar
TLCA# 17266
I really like that color on a wagon.... oh- and ditch the rest of your flares- it looks good!
And- 5.29's. The 3FE will thank you.
Eric P.
1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Doc is offline   Reply With Quote
Bad Credit Mortgages | Advertising | Car Insurance | Online MBA Degree | Ringtones
