Old 06-21-08, 06:21 PM   #1
Young and Dumb apparently
alkaline747trio's Avatar
3FE EFI Relay Ground Wire ??????
Is there a write up, post, or something showing how to replace the EFI ground wire on the 3FE? Which wire is it, where does it run, what kind of connections does it have?
'92 - 3FE POWER'D!
-- Slee 6"/OME 863J, Pro-Comp 14" ES3000/N74L, Gen. 2 Slee Front Control Arms, T-G Sliders, Ext. Diff. Breathers, Slee SS Brake Lines, 5.29s, Aussie Locker'd rear, 35" TrXus STS Street/38.5x11 Boggers Trail, 180k.
'85 Honda Accord - 55MPG!!!
-- No air filter, Custom Burple (blue and purple) Paint.
Upstate Cruisers
alkaline747trio is offline   Reply With Quote
Old 06-21-08, 06:58 PM   #2
informationjunky's Avatar
TLCA# 6149
Jon Helds stuff? http://gclcny.com/jh/images/Strife/EFIdiag.pdf
Georgia Cruisers
Upstate Cruisers
http://www.upstatecruisers.net/
TLCA 6149
86 FJ60 - first and RIP
95 FZJ 80 - second RIP
97 LX 450 - Current
locked, ARB, 850J's Front and 863's rear, slee drop blocks, 315's, and M12000, Devo sliders, Iron Pig rear bumper, skid on garge floor
98 LX 470 - wifes
informationjunky is offline   Reply With Quote
Old 06-21-08, 09:29 PM   #3
So it's just a short wire in the fuse box under the hood? Which wire is it, color/stripe? What kind of connectors do these wires use?
'92 - 3FE POWER'D!
Upstate Cruisers
Old 06-22-08, 03:14 AM   #4
I don't have the colors on this computer but can get them in the am. What problem are you having or what are you trying to accomplish?
J
jpw2 is offline   Reply With Quote
Old 06-22-08, 03:26 AM   #5
Stumble at cruising speed in OD.
'92 - 3FE POWER'D!
Upstate Cruisers
Old 06-22-08, 12:21 PM   #6
92 3fe EFI relay Terminal #1 brown is ground Chasis/body for relay coil, #2 red-yel is 12v+ from Efi fuse for hot side of relay load contacts this is the same circuit as ECU terminal#2(BATT+), #3 red 12v+ for relay coil from ECU terminal #3(MREL) This is where ECu controls the relay, #4 yel-red When energized relay provides12v+ to ECU terminals #1(+B1) and #7(+B) also to almost all Ecu controlled actuators(idle spd cont, O2 heaters, VSVs ect), Fuel pump through Circuit opening relay contacts. EFI relay load circuit can be monitored at the FP terminal in the diagnostic connector while problem happens to see if you are loosing voltage (this is a quick test, more accurate testing would involve monitor voltage at each component to check if the wire has problem between components or at splices in harness).
Does your problem happen once per drive or repeatedly once in OD? Anything other than OD affecting the problem?
J
Old 06-22-08, 02:34 PM   #7
TLCA# 8537
Look in Yahoo 3FE Groups files
Yahoo 3FE Group
You may have to join, but everybody there loves that engine.
I recall that part #s for individual wires in the relay socket are used to repair the socket. In my case, a new relay fixed all sorts of odd dying behaviors on an FJ62 , but that model's relay is stand alone type.
Joe aka 4XODDIC ( allow me to pronounce that for you: 4 By, Odd Eye, See! ) aka the One Eyed Guy
Owning Toyotas Since 1975
TLCA 8537
99-00 Tundra LTD 4X4; 01-90 Samurai; 07-88 TinTop Samurai; 08-97 LX450
4xoddic is offline   Reply With Quote
Old 06-22-08, 11:50 PM   #8
I'm a member of 3FE, and I couldn't find it after 30 minutes of searching.
Thanks jpw, what do I do to check that FP in the diag terminal? It happens in OD mainly, but has happened otherwise. Happens several times while driving, normally on longer trips than shorter, and wont happen unless im going 50ish or better.
'92 - 3FE POWER'D!
Upstate Cruisers
Old 06-23-08, 02:00 AM   #9
If you have a voltmeter monitoring the FP terminal voltage (should be at charging system voltage minus.-1.0v) will tell you if the efi or fuel pump/circuit opening relay are having an intermittent issue. This is a quick test as this the FP term is at one extreme of the circuit. It is not a all inclusive test as this circuit has many parallel branches that could have a problem and not show up at the FP term. A problem with either relay should show up as a momentary drop in voltage as problem happens.
J
Electricity | Loan | Car Restoration | Mortgage Calculator | Free Image Hosting
