Old 06-21-08, 05:52 PM   #1
Dynamat question
I ordered 100sq/ft of Dynamat (actually one of its knockoffs). I plan on doing all four doors, and the rear cargo compartment in preparation for installing a new stereo/speakers/sub woofer. Where exactly on the doors should I apply it for best effect? I ask because in my mind, it would make sense to put it on the outer skin of the door to minimize sound bleed-through both ways, but from all the pictures I see of professional audio installs, the installer put dynamat on the innermost skin (piece the door panel clips to). How should I go about this? Thanks!
'97 Lexus LX450 - CDL/7 Pin | Factory cup holder | Black LX wheels | 305/70 Toyo M/T | Optima Redtop | Auto-Up mod | George's LEDs | 1.5" Spacers |
F0RSAKEN is offline   Reply With Quote
Old 06-21-08, 07:27 PM   #2
Highspeed's Avatar
the short answer is: put it everywhere you can. I recommend using the dynamat to create a 100% barrier like the stock plastic behind the door panel. it's a little extra work but well worth it if you're investing big $$$ on your system. It also reduces road noise a lot. Cut sections to fit and then on the sections where you don't want it to stick just stick some to itself on the back. if that doesn't make sense just pm me and I'll explain over the phone.
1993 FZJ80 - stock, locked, abs, leather, working on baseline for now
02 Tacoma 4x4 as DD and work truck
Highspeed is offline   Reply With Quote
Old 06-22-08, 12:29 AM   #3
No, I understand perfectly. So should I worry about sticking any inside the door, on the outer skin? Thanks for the reply!
Old 06-22-08, 12:34 AM   #4
NLXTACY's Avatar
When we did my friends car we did ANYWHERE we could stick it. This meant on the door just under the panel AND putting it in the outdoor skin as well. We just rolled it up, slid it through an opening and went to town. Car makes me think of what the inside of a coffin would sound like. Assuming the radio is off
70 FJ40-sold, worst day of my life
79 TOY 4WD pup-stolen, 2nd worst day of my life
91 4Runner 4WD-burned to ground, 3rd worst day of my life
83 FJ60- suckiest day of my life
97 LX450, 216k, non-locked. Expedition vehicle in progress
Originally Posted by Brentbba View Post
Nah! I'll just overanalyze it for about 3-4 weeks, put up 5 posts about it, then not make up my mind.
Old 06-22-08, 01:02 AM   #5
come play with us forever
IronYuppy's Avatar
TLCA# 17705
Before I did mine I read-up on a few "audiophile" how-to forums. There were, of course, as many opinions as there were members, but the consensus seems to be that you need to focus on the inner door skins, basically replacing the factory plastic vapour barrier. Cover all the holes in the door as described above.
You will be somewhat limited on where you can place the sheets inside the door's outer skin, because things like the window regulators get in the way. I focused on using the acoustic sheeting behind each speaker, as recommended in one of the forums I read.
FWIW, 100sq/ft is more than enough to do your entire truck, including the cargo area, with enough left over to line the outer door skins near the speakers and any other easy-to-reach areas. I "doubled up" on large flat areas such as the cargo area floor and the footwells. 100sq/ft won't be enough to do the roof, but that's probably overkill. Still, if I ever have the need to re/re my headliner I'll probably dynamat the roof at that time. Couldn't hurt.
I also went to the local race shop and bought a roll of sound deadener for the footwells. It's basically asphalt sheeting. It's not adhesive, so it can't be placed on vertical surfaces, but it's ideal for floors. Fits between the Dynamat and the OEM carpet. Way cheaper than the adhesive stuff.
BTW, this is the adhesive stuff I used:
B-Quiet sound deadening materials - B-Quiet Extreme
Worked out to be CAD$1.40 sq/ft at the price break of 100sq/ft. It's good stuff and less than half the price of Dynamat.
'94 lockered FZJ80
"I vote for Iron Yuppie" - Decavo
"I am not here for your cold gross chicken, I am here for your love." - Vanna White, in 'Venus God of Love'
"I Hate your America!" - Guambomb
"I wish one of the voices in your head would tell you to shut the hell up." - Warren De Montegue
"I have a poem. This one I call 'Lynch's Moustache': Lynch's moustache looks stupid.
What a dumb idiot to have a moustache like that. Why don't you go wax your ass?!" - McGuirk
IronYuppy is offline   Reply With Quote
Old 06-22-08, 03:19 AM   #6
Originally Posted by IronYuppy View Post
FWIW, 100sq/ft is more than enough to do your entire truck...
100 ft^2 = 10 ft x 10 ft. Your entire truck, questionable, but
YMMV.
mkfour is offline   Reply With Quote
Old 06-22-08, 07:01 AM   #7
BuckeyeFan's Avatar
I did like NLX and put it on the inside of the skin and replaced the vapor barrier. Supposed to have some thermal insulation value as well. Gives the doors a more solid thunk when they shut. Get some Windex and clean off the inside of the sheet metal first.
1997 LC - Dune & Moon, unlocked, landtank MAF & auto-up, CDL/Pin 7, JDM Cupholder with synthetic rail lube, Eclipse 5510
BuckeyeFan is offline   Reply With Quote
Old 06-22-08, 02:50 PM   #8
Highspeed's Avatar
ya, forgot to say make sure it's super clean. I use denatured alcohol to remove grease/dirt and a heat gun when applying the material.
Ringtones | Loans | Savings Accounts | Loans | Loans
