Old 06-18-08, 03:51 AM   #1 (permalink)
NLXTACY's Avatar
TLCA# 19015
While trying to rid the P0401 CEL...I learned I am dumb
HELP!!!!!!!!
Well, I was reading through all the threads and figured I would give it a go to get rid of the CEL. In reading I came across RAVENTAI's thread about testing the EGR etc.:
IH8MUD™ Forums - View Single Post - Alternate EGR tests ( P0401 )
I also found this image in which the thread mentioning using a drill bit to run through the small tubes to remove the carbon buildup. On some images there were tons of carbon. Well on mine there was zero carbon. Looked clean. Like...too clean. I figured maybe there was a blockage, so I ran a drill bit...by hand...to see if there was blockage here:
So if you had to take a guess, what would be the ABSOLUTE WORST thing that could possibly happen while running a drill bit...
.....by hand
....in a small hole?
YUP, you guessed it. I RAN OUT OF BEER!!!!
.....and then dropped the drill bit down the hole!!!!!!
Soooo dumb. So here is what I have learned so far:
• The hole only goes in about three inches and then stops
• a 2.5" drill bit dropped, will fall all the way in, barely half an inch from the opening
• Removing the modulator and the EGR valve were a lot easier to remove then I though it was going to be
• Removing the EGR valve DOES NOT allow access to the drill bit as I had hoped
• The drill bit plugging the hole to the EGR Valve has ZERO affect on the driveability of the truck, cold or hot
• A dental pick lance will not get it out
• The drillbit is not wedged in, its just dropped in
So, is there ANYWAY to get this drill bit out WITHOUT having to remove the entire intake manifold?!?!!?
HELP AN IDIOT!!!!!
ふざけんなよ!
Old 06-18-08, 06:53 AM   #2 (permalink)
Ebag333's Avatar
TLCA# 18864
Try a magnet yet?
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 06-18-08, 08:05 AM   #3 (permalink)
Curran's Avatar
Ditto on the magnet.
TLCA # 14832
97 FZJ80, 6" Lift, Slee Armor, 35" TrXus, 12k Warn, Milford...
90 Xtracab 4x4
Curran is offline   Reply With Quote
Old 06-18-08, 08:07 AM   #4 (permalink)
Joe Egolf's Avatar
drill bit
How about another drill bit ,same size,with a dot of super glue on the butt end into the hole , let sit a sec and pull both out ??? Try Magnet first .
1981 BJ42
Joe Egolf is offline   Reply With Quote
Old 06-18-08, 08:09 AM   #5 (permalink)
Just turn the truck upside down and shake it.
86 Bronco is offline   Reply With Quote
Old 06-18-08, 08:15 AM   #6 (permalink)
SeanAndHis80's Avatar
TLCA# 19456
Originally Posted by Ebag333 View Post
Try a magnet yet?
If a powerful magnet alone does not do it, attach a nail to it and stick it down until you touch the drill bit.
97 40th lockersx3, Yellow top & Diehard PM-2. Pin7 mod, Georges LEDs & others, Revos, heated mirrors, massive inverter project underway. P0401 fixed. Currently at 180K+. more to come...
87 Supra Turbo - stock, 5-speed, targa roof, midnight blue. Currently at 125K+.
SeanAndHis80 is offline   Reply With Quote
Old 06-18-08, 08:16 AM   #7 (permalink)
Does anyone know the shape of this hole? Does it make an L turn inside the intake? I need to clean that port, but have been afraid of going too deep and puncturing a lung or something like that. Thx.
I second the 'shake it' method.
1993 TLC, stock, unlocked...street pig
TLCnoob is offline   Reply With Quote
Old 06-18-08, 08:32 AM   #8 (permalink)
TLCA# 19456
The tube is straight but the other end has a rubber hose attached.
Old 06-18-08, 08:45 AM   #9 (permalink)
Sweet, thx.
Old 06-18-08, 09:08 AM   #10 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
Straight line that passes through to the VSV on the underside of the intake. the is rubber vacuum hose on the other end that could be damaged by a drill bit if it were long enough so be careful,
as for how to get the drill bit out how about pulling off the vacuum line on the other side gravity should do the rest.
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is offline   Reply With Quote
Old 06-18-08, 09:37 AM   #11 (permalink)
The picture keeps getting clearer. Thanks.
Old 06-18-08, 09:57 AM   #12 (permalink)
jditom's Avatar
Dude I thought I was the only guy that does stuff like that!
Good Luck
1996 TLC, Cooper D. STT 305/70/16, CDL, 7 PIN, OME steer & 850/863, Bilstein HD, IPA fog. Slee's front bumper, skid plate, CC bushings, SS brake lines x 7, light/aux harness & speedo gear. Warn XD 9000, Hanna sliders. 4X4labs rear bumper. OEM sub tank & overhead console. Projection headlamps, clear lenses, rear tail LED, George's inside LED's. MagnFlow exhaust (cat back). Eclipse Nav.
jditom is offline   Reply With Quote
Old 06-18-08, 09:59 AM   #13 (permalink)
The Notorious BHM
Atticus's Avatar
Outstanding. I will monitor your progress.
"It was a blend from italy, not cheap, and absolutely superb!" - Judge Smails.
Atticus is online now   Reply With Quote
Old 06-18-08, 10:06 AM   #14 (permalink)
ed97fzj80's Avatar
TLCA# 15645
Winner!
ed97fzj80 is offline   Reply With Quote
Old 06-18-08, 12:23 PM   #15 (permalink)
NLXTACY's Avatar
TLCA# 19015
Try a magnet yet?
Yes tried the magnet, does nothing. I then tried magnetizing a paperclip and then a dental pick. No luck. The magnet is just not strong enough. Plus it doesnt help that the tube itself is metal
I am going to try this one tonight. I have a feeling this will be my best bet but what I am worried about it putting too much glue and possibly glueing EVERYTHING in there together
THIS IS EXACTLY what the said. I guess all think alike
I guess I COULD rent a crane....
For me it seems to just bottom out.
?????? Other end??????
To be honest I didn't even check to see if that tube went all the way through or not
BTW, thanks guys for the suggestions
ふざけんなよ!
Old 06-18-08, 12:37 PM   #16 (permalink)
goschbrandon's Avatar
How firmly wedged is the bit? Maybe use a shop vac to try and suck it out of the hole? The superglue on another drill bit idea seemed good too.
'73 baby blue fj40 [sold :(], '96 FZJ80 locked, 285 BFG ATs, CDL w/7pin, custom drawers, SROR sliders, OME med, extra 12V power, IPOR skidplate , 1951 M100 w/RTT, 1994 Camry DD
goschbrandon is offline   Reply With Quote
Old 06-18-08, 12:46 PM   #17 (permalink)
NLXTACY's Avatar
TLCA# 19015
No shop vac, that takes up valuable real estate.
Yeah the super glue trick is going to be my best shot I think. I will report back tonight. If that doesnt work then I guess I will see where that tube goes to and just give it a reach around.
Er...wait...
ふざけんなよ!
Old 06-18-08, 01:23 PM   #18 (permalink)
alia176's Avatar
dude, take a look at the other (manifold upside down) pics on the same thread , and notice the "other" side of this nipple. There's a hose attached to the other side of the nipple, so just remove that hose and let the bit fall out!
edit: yeah, what Raventai stated earlier..
'96 his
'97 hers
alia176 is offline   Reply With Quote
Old 06-18-08, 02:15 PM   #19 (permalink)
bpenn1980's Avatar
haha, man, I was afraid of doing the same exact thing. I ended up using some unsheathed copper wire to run through all my vac hoses figuring a little bend is a good thing and I could make it long enough to avoid dropping it in!
Try just a tiny dap of super glue on another drill bit. Set it down on the drill bit and let dry 1 minute. Even I tiny amount is very strong and should easily bear the weight of your drill bit.
Brad
1994 FZJ-80: Fully locked ; 99k; Temp Gauge Mod; PHH'd; Fan Clutch Mod (8,000cst & 105*); FIAMM dual tone horn, 100-series brake pads, diff breather extension, Pioneer DEH-P3900MP headunit, BFG AT 285's, ome 850/863, removed running boards, and more maintenance than is healthy
bpenn1980 is offline   Reply With Quote
Old 06-18-08, 03:15 PM   #20 (permalink)
You want to do what...?
e9999's Avatar
I would be cautious about the super glue bit. Not a great idea IMO, at least at first. Try first with something less likely to glue the bit in, perhaps? Like silicone glue?
But first check the other side per RT?
'97: 89K, 3xlock, Custom HD roo bar for sale, see Classifieds for SnT, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 112K, the better half's...
DD Accord
souped up DR650
Old 06-18-08, 03:20 PM   #21 (permalink)
Moreover. Even if you have that passage was plugged up it would never under any circumstances cause P401 only P402.
Bitten up 97 FJZ80 runs good though
Alex Kogan is offline   Reply With Quote
Old 06-18-08, 03:23 PM   #22 (permalink)
chitown40's Avatar
TLCA# 14424
I got $5 that the super glue only bonds the second drill bit to the tube and NLXTACY also ends up bonding skin in the process. I'd really consider what Raventai and alia176 said before I start with bonding agents.
2002 4Runner Sport Edition - Stock
1997 FZJ80 -- SOLD
1986 FJ60 -- SOLD
1977 FJ40 -- SOLD
TLCA #14424
chitown40 is offline   Reply With Quote
Old 06-18-08, 04:01 PM   #23 (permalink)
NLXTACY's Avatar
TLCA# 19015
Like I said, I am dumb. My luck I would wind up super glueing my hand to my pants zipper. Hard to explain that to your 10 year old son...again. :(
I will definitely be going with RAVENTAI/ALIA176's suggest first. Hopefully its a 5 second fix and then I will then learn to be less dumb.
As far as the code. yeah I just wanted to cover all my bases with the easy stuff first.
ふざけんなよ!
Old 06-18-08, 04:04 PM   #24 (permalink)
Red Beard's Avatar
Don't worry man, I've done stupider things, on my John Deere Tractor, a cottar pin fell into the dipstick hole, long story..
Don't worry. With a little bit of MacGuyver, you can fix it. Just make a super strong magnet and fish it out. I have a extendable magnet just for this reason, its not super strong, but I could make it strong. I'm sure you can buy them that way too. As once you get the bit close enough, you can just magnetize it to the wall with another magnet and then slowly fish it out. You'll get it man, don't worry.
IH8RUST
'92 FJ80 - 3FE - with stuff on it
ROTW
Red Beard is offline   Reply With Quote
Old 06-18-08, 04:09 PM   #25 (permalink)
I just peed my shorts
........but seriously, I wonder if that drill bit down there might get him some more MPGs?
A visitor from the past
Hilux is offline   Reply With Quote
Old 06-18-08, 04:11 PM   #26 (permalink)
NLXTACY's Avatar
TLCA# 19015
Originally Posted by Red Beard View Post
a cottar pin fell into the dipstick hole, long story...
Such a tired p0rn plotline.
Well magnet wont work. The tube is 1/8". No magnet is getting there. I'm sure it will work out.
ふざけんなよ!
Old 06-18-08, 04:43 PM   #27 (permalink)
98 SNAKE EATER's Avatar
Disconnect hose on the bottom and blow some compressed air through it...
If that doesn't work, try some thin welding wire and push it through from the bottom...
98 SNAKE EATER is offline   Reply With Quote
Old 06-19-08, 02:56 AM   #28 (permalink)
GA Trevor's Avatar
You get it out yet, seems like something I would do
GA Trevor is offline   Reply With Quote
Old 06-19-08, 04:52 AM   #29 (permalink)
alia176's Avatar
bunch little school girls out here, we all need closure damn it
'96 his
'97 hers
Old 06-19-08, 10:03 AM   #30 (permalink)
TLCA# 8537
Trade Secret:
Per McPherson College Automotive Restoration Technology MC Technology | Facilities guru: oldtimers' solution to losing X (part) in the transmission was to turn the Model T over, usually in a ditch.
And no, I'm not that old, but I did ride in a rumble seat with Alex Haley once.
Joe aka 4XODDIC (allow me to pronounce that for you: 4 By, Odd Eye, See!) aka the One Eyed Guy
Owning Toyotas Since 1975
TLCA 8537
99-00 Tundra LTD 4X4; 01-90 Samurai; 07-88 TinTop Samurai
4xoddic is offline   Reply With Quote
